Second, I've been struggling with a couple of errors I'm getting with this mod, and would appreciate any help/advice you have to offer.
When going to the Quiz Packs screen in the ACP I'm getting these warnings:
Warning: file_get_contents(http://xxxxxxxxx/phpBB2/admin/quiz_packs/QP_UQM_Trivia.qp): failed to open stream: HTTP request failed! HTTP/1.1 404 Not Found in /xxxxxx/xxxxxx/xxxxxx/xxxxxx/phpBB2/admin/admin_quiz_packs.php on line 97
Warning: file_get_contents(http://xxxxxxxx/phpBB2/admin/quiz_packs/QP_UQM_Trivia.qp): failed to open stream: HTTP request failed! HTTP/1.1 404 Not Found in /xxxxx/xxxxxx/xxxxxxx/xxxxxx/phpBB2/admin/admin_quiz_packs.php on line 97Interestingly, the link to the file shows up in the Quiz Packs section, and if I cut and paste the path into my browser I can access the file just fine, so why is the Mod getting a 404??
Clicking the filename link in the Quiz Pack section results in another warning, and a blank screen below it:
Warning: file_get_contents(http://spwaw.com/phpBB2/admin/quiz_packs/QP_UQM_Trivia.qp): failed to open stream: HTTP request failed! HTTP/1.1 404 Not Found in /xxxxx/xxxxx/xxxxx/xxxx/phpBB2/admin/admin_quiz_packs.php on line 157Code: Select all
Warning: file(): php_network_getaddresses: getaddrinfo failed: Name or service not known (is your IPV6 configuration correct? If this error happens all the time, try reconfiguring PHP using --disable-ipv6 option to configure) in /xxxx/xxxxxxxxx/xxxxxx/xxxxx/phpBB2/admin/admin_quiz.php on line 400
Warning: file(http://www.cmxmods.net/quiz_latest.txt): failed to open stream: Success in /xxxx/xxxxx/xxxxxxx/xxxx/phpBB2/admin/admin_quiz.php on line 400
