Failed to open stream errors
Bernie
First, thanks for creating this mod!
Second, I've been struggling with a couple of errors I'm getting with this mod, and would appreciate any help/advice you have to offer.
When going to the Quiz Packs screen in the ACP I'm getting these warnings:
Warning: file_get_contents(http://xxxxxxxxx/phpBB2/admin/quiz_packs/QP_UQM_Trivia.qp): failed to open stream: HTTP request failed! HTTP/1.1 404 Not Found in /xxxxxx/xxxxxx/xxxxxx/xxxxxx/phpBB2/admin/admin_quiz_packs.php on line 97
Warning: file_get_contents(http://xxxxxxxx/phpBB2/admin/quiz_packs/QP_UQM_Trivia.qp): failed to open stream: HTTP request failed! HTTP/1.1 404 Not Found in /xxxxx/xxxxxx/xxxxxxx/xxxxxx/phpBB2/admin/admin_quiz_packs.php on line 97
This indicates to me that I've got permissions on something set wrong, but I've reset all the permissions for that file and directory, and the appropriate directories above it, yet I still get the error. And yes, I've checked the filename for spelling errors too.
Interestingly, the link to the file shows up in the Quiz Packs section, and if I cut and paste the path into my browser I can access the file just fine, so why is the Mod getting a 404??
Clicking the filename link in the Quiz Pack section results in another warning, and a blank screen below it:
Warning: file_get_contents(http://spwaw.com/phpBB2/admin/quiz_packs/QP_UQM_Trivia.qp): failed to open stream: HTTP request failed! HTTP/1.1 404 Not Found in /xxxxx/xxxxx/xxxxx/xxxx/phpBB2/admin/admin_quiz_packs.php on line 157
Two other warnings are also popping up on the Quiz configuration screen in the ACP, directly above the form:
Warning: file(): php_network_getaddresses: getaddrinfo failed: Name or service not known (is your IPV6 configuration correct? If this error happens all the time, try reconfiguring PHP using --disable-ipv6 option to configure) in /xxxx/xxxxxxxxx/xxxxxx/xxxxx/phpBB2/admin/admin_quiz.php on line 400
Warning: file(http://www.cmxmods.net/quiz_latest.txt): failed to open stream: Success in /xxxx/xxxxx/xxxxxxx/xxxx/phpBB2/admin/admin_quiz.php on line 400
AFAIK my IPV6 configuration is fine, and I'd rather not mess with it. We do plan on upgrading to PHP5 in the future, probably over the summer, but not right now.
Hi, I think this error is simply because your PHP configuration doesn't allow the use of file, file_get_contents, or any other function that allows PHP to access files.
The good news is, that it doesn't affect the way the MOD runs overall, it just means you:
  1. Won't be able to the see the "latest version" line in the ACP.
  2. Won't be able to install quiz packs
The first point is not a major problem, and the second one is only a problem if you planned to use quiz packs (I think there are only a dozen or so floating around anyway).
Welcome to the forum, hope to see you around OT Forum :)
Bernie
battye wrote:Hi, I think this error is simply because your PHP configuration doesn't allow the use of file, file_get_contents, or any other function that allows PHP to access files.
Greetings,
I disagree. I've never had a problem like this before and my system does indeed allow file access using the file_get_contents function of PHP.
Many areas of our system, most notably our reference library, use that function, and are working perfectly.
Thanks for the reply though, and again, thanks for creating this interesting Mod.
If you make a file (test.php):
echo file_get_contents(http://spwaw.com/phpBB2/admin/quiz_packs/QP_UQM_Trivia.qp);
And run it, does it work?
Bernie
battye wrote:If you make a file (test.php):
Hmmm...
It was working, but now it's not, and I see that the areas which use that function in other parts of the system are also not working correctly.
I'll have to look into this!
Thanks. :)
