2.0.12 Update
Bugs and potential security vulnerabilities have been fixed in phpBB 2.0.12. As usual, if you find any errors when using the forum, report them in this topic.
If you own a forum, and use 2.0.11 or below, follow the instructions below to update to 2.0.12. Remember you will need to download the upgrade package for the update_to_latest.php file. You upload this to your forum root / install directory (eg forums.com/install) and run. Make sure you apply the code changes too, as this script only updates the database.
phpBB 2.0.11 to phpBB 2.0.12 Code Changes
These are the Changes from phpBB 2.0.11 to phpBB 2.0.12 summed up into a little Mod. This might be very helpful if you want to update your Board and have installed a bunch of Mods. Then it's normally easier to apply the Code Changes than to install all Mods again.
When you find a 'AFTER, ADD'-Statement, the Code have to be added after the last line quoted in the 'FIND'-Statement.
When you find a 'BEFORE, ADD'-Statement, the Code have to be added before the first line quoted in the 'FIND'-Statement.
When you find a 'REPLACE WITH'-Statement, the Code quoted in the 'FIND'-Statement have to be replaced completely with the quoted Code in the 'REPLACE WITH'-Statement.
When you find a 'DELETE'-Statement, the Code have to be deleted.
After you have finished this tutorial, you have to upload the update_to_latest.php file, execute it and then delete it from your webspace.
Ok, lets start:
  • admin/admin_db_utilities.php
  1. FIND - Line 696
    			$tables = array('auth_access', 'banlist', 'categories', 'config', 'disallow', 'forums', 'forum_prune', 'groups', 'posts', 'posts_text', 'privmsgs', 'privmsgs_text', 'ranks', 'search_results', 'search_wordlist', 'search_wordmatch', 'sessions', 'smilies', 'themes', 'themes_name', 'topics', 'topics_watch', 'user_group', 'users', 'vote_desc', 'vote_results', 'vote_voters', 'words');
    REPLACE WITH
    			$tables = array('auth_access', 'banlist', 'categories', 'config', 'disallow', 'forums', 'forum_prune', 'groups', 'posts', 'posts_text', 'privmsgs', 'privmsgs_text', 'ranks', 'search_results', 'search_wordlist', 'search_wordmatch', 'sessions', 'smilies', 'themes', 'themes_name', 'topics', 'topics_watch', 'user_group', 'users', 'vote_desc', 'vote_results', 'vote_voters', 'words', 'confirm');
  • admin/index.php
  1. FIND - Line 562
    			"L_NO_GUESTS_BROWSING" => $lang['No_users_browsing'])
    AFTER, ADD
    	// Check for new version
    	$current_version = explode('.', '2' . $board_config['version']);
    	$minor_revision = (int) $current_version[2];
    	$errno = 0;
    	$errstr = $version_info = '';
    	if ($fsock = @fsockopen('www.phpbb.com', 80, $errno, $errstr))
    		@fputs($fsock, "GET /updatecheck/20x.txt HTTP/1.1\r\n");
    		@fputs($fsock, "HOST: www.phpbb.com\r\n");
    		@fputs($fsock, "Connection: close\r\n\r\n");
    		$get_info = false;
    		while (!@feof($fsock))
    			if ($get_info)
    				$version_info .= @fread($fsock, 1024);
    				if (@fgets($fsock, 1024) == "\r\n")
    					$get_info = true;
    		@fclose($fsock);
    		$version_info = explode("\n", $version_info);
    		$latest_head_revision = (int) $version_info[0];
    		$latest_minor_revision = (int) $version_info[2];
    		$latest_version = (int) $version_info[0] . '.' . (int) $version_info[1] . '.' . (int) $version_info[2];
    		if ($latest_head_revision == 2 && $minor_revision == $latest_minor_revision)
    			$version_info = '<p style="color:green">' . $lang['Version_up_to_date'] . '</p>';
    			$version_info = '<p style="color:red">' . $lang['Version_not_up_to_date'];
    			$version_info .= '<br />' . sprintf($lang['Latest_version_info'], $latest_version) . sprintf($lang['Current_version_info'], '2' . $board_config['version']) . '</p>';
    		if ($errstr)
    			$version_info = '<p style="color:red">' . sprintf($lang['Connect_socket_error'], $errstr) . '</p>';
    			$version_info = '<p>' . $lang['Socket_functions_disabled'] . '</p>';
    	$version_info .= '<p>' . $lang['Mailing_list_subscribe_reminder'] . '</p>';
    	$template->assign_vars(array(
    		'VERSION_INFO'	=> $version_info,
    		'L_VERSION_INFORMATION'	=> $lang['Version_information'])
  • common.php
  1. FIND - Line 56
    	$test = array('HTTP_GET_VARS' => NULL, 'HTTP_POST_VARS' => NULL, 'HTTP_COOKIE_VARS' => NULL, 'HTTP_SERVER_VARS' => NULL, 'HTTP_ENV_VARS' => NULL, 'HTTP_POST_FILES' => NULL);
    REPLACE WITH
    	$test = array('HTTP_GET_VARS' => NULL, 'HTTP_POST_VARS' => NULL, 'HTTP_COOKIE_VARS' => NULL, 'HTTP_SERVER_VARS' => NULL, 'HTTP_ENV_VARS' => NULL, 'HTTP_POST_FILES' => NULL, 'phpEx' => NULL, 'phpbb_root_path' => NULL);
  2. FIND - Line 75
    else if (@ini_get('register_globals') == '1' || strtolower(@ini_get('register_globals')) == 'on')
    	// PHP4+ path
    AFTER, ADD
    	$not_unset = array('HTTP_GET_VARS', 'HTTP_POST_VARS', 'HTTP_COOKIE_VARS', 'HTTP_SERVER_VARS', 'HTTP_SESSION_VARS', 'HTTP_ENV_VARS', 'HTTP_POST_FILES', 'phpEx', 'phpbb_root_path');
  3. FIND - Line 92
    	unset($input['input']);
    	while (list($var,) = @each($input))
    		unset($$var);
    REPLACE WITH
    	unset($input['not_unset']);
    		if (!in_array($var, $not_unset))
    			unset($$var);
  4. FIND - Line 207
    $client_ip = ( !empty($HTTP_SERVER_VARS['REMOTE_ADDR']) ) ? $HTTP_SERVER_VARS['REMOTE_ADDR'] : ( ( !empty($HTTP_ENV_VARS['REMOTE_ADDR']) ) ? $HTTP_ENV_VARS['REMOTE_ADDR'] : $REMOTE_ADDR );
    REPLACE WITH
    $client_ip = ( !empty($HTTP_SERVER_VARS['REMOTE_ADDR']) ) ? $HTTP_SERVER_VARS['REMOTE_ADDR'] : ( ( !empty($HTTP_ENV_VARS['REMOTE_ADDR']) ) ? $HTTP_ENV_VARS['REMOTE_ADDR'] : getenv('REMOTE_ADDR') );
  • includes/functions.php
  1. FIND - Line 80
    	$username = htmlspecialchars(rtrim(trim($username), "\\"));
    	$username = substr(str_replace("\\'", "'", $username), 0, 25);
    	$username = str_replace("'", "\\'", $username);
    REPLACE WITH
    	$username = substr(htmlspecialchars(str_replace("\'", "'", trim($username))), 0, 25);
    	$username = phpbb_rtrim($username, "\\");
    	$username = str_replace("'", "\'", $username);
  2. FIND - Line 83
    	return $username;
    AFTER, ADD
    // added at phpBB 2.0.12 to fix a bug in PHP 4.3.10 (only supporting charlist in php >= 4.1.0)
    function phpbb_rtrim($str, $charlist = false)
    	if ($charlist === false)
    		return rtrim($str);
    	$php_version = explode('.', PHP_VERSION);
    	// php version < 4.1.0
    	if ((int) $php_version[0] < 4 || ((int) $php_version[0] == 4 && (int) $php_version[1] < 1))
    		while ($str{strlen($str)-1} == $charlist)
    			$str = substr($str, 0, strlen($str)-1);
    		$str = rtrim($str, $charlist);
    	return $str;
  3. FIND - Line 608
    			$debug_text .= '</br /><br />Line : ' . $err_line . '<br />File : ' . $err_file;
    REPLACE WITH
    			$debug_text .= '</br /><br />Line : ' . $err_line . '<br />File : ' . basename($err_file);
  • includes/page_tail.php
  1. FIND - Line 38
    	'PHPBB_VERSION' => '2' . $board_config['version'],
    REPLACE WITH
    //	'PHPBB_VERSION' => '2' . $board_config['version'],
  • includes/template.php
  1. FIND - Line 233
           		$filename = phpbb_realpath($this->root . '/' . $filename);
    REPLACE WITH
           		$filename = ($rp_filename = phpbb_realpath($this->root . '/' . $filename)) ? $rp_filename : $filename;
  • includes/usercp_avatar.php
  1. FIND - Line 54
    	global $board_config, $userdata;
    AFTER, ADD
    	$avatar_file = basename($avatar_file);
  2. FIND - Line 69
    function user_avatar_gallery($mode, &$error, &$error_msg, $avatar_filename)
    	global $board_config;
    AFTER, ADD
    	$avatar_filename = str_replace(array('../', '..\\', './', '.\\'), '', $avatar_filename);
    	if ($avatar_filename{0} == '/' || $avatar_filename{0} == "\\")
    		return '';
  3. FIND - Line 235
    				$move_file = 'copy';
    AFTER, ADD
    			if (!is_uploaded_file($avatar_filename))
    				message_die(GENERAL_ERROR, 'Unable to upload file', '', __LINE__, __FILE__);
  • includes/usercp_register.php
  1. FIND - Line 462
    			$avatar_mode = ( !empty($user_avatar_name) ) ? 'local' : 'remote';
    REPLACE WITH
    			$avatar_mode = (empty($user_avatar_name)) ? 'remote' : 'local';
  • language/lang_english/lang_admin.php
  1. FIND
    // That's all Folks!
    BEFORE, ADD
    // Version Check
    $lang['Version_up_to_date'] = 'Your installation is up to date, no updates are available for your version of phpBB.';
    $lang['Version_not_up_to_date'] = 'Your installation does <b>not</b> seem to be up to date. Updates are available for your version of phpBB, please visit <a href="http://www.phpbb.com/downloads.php" target="_new">http://www.phpbb.com/downloads.php</a> to obtain the latest version.';
    $lang['Latest_version_info'] = 'The latest available version is <b>phpBB %s</b>.';
    $lang['Current_version_info'] = 'You are running <b>phpBB %s</b>.';
    $lang['Connect_socket_error'] = 'Unable to open connection to phpBB Server, reported error is:<br />%s';
    $lang['Socket_functions_disabled'] = 'Unable to use socket functions.';
    $lang['Mailing_list_subscribe_reminder'] = 'For the latest information on updates to phpBB, why not <a href="http://www.phpbb.com/support/" target="_new">subscribe to our mailing list</a>.';
    $lang['Version_information'] = 'Version Information';
  • templates/subSilver/admin/index_body.tpl
  1. FIND - Line 80
    </table>
    <br />
    AFTER, ADD
    <h1>{L_VERSION_INFORMATION}</h1>
    {VERSION_INFO}
    <br />
  • templates/subSilver/overall_footer.tpl
  1. FIND - Line 8
    	Powered by phpBB {PHPBB_VERSION} line, with phpBB linked to www.phpbb.com. If you refuse
    	to include even this then support on our forums may be affected.
    	The phpBB Group : 2002
    Powered by <a href="http://www.phpbb.com/" target="_phpbb" class="copyright">phpBB</a> {PHPBB_VERSION} &copy; 2001, 2002 phpBB Group<br />{TRANSLATION_INFO}</span></div>
    REPLACE WITH
    	Powered by phpBB line, with phpBB linked to www.phpbb.com. If you refuse
    Powered by <a href="http://www.phpbb.com/" target="_phpbb" class="copyright">phpBB</a> &copy; 2001, 2005 phpBB Group<br />{TRANSLATION_INFO}</span></div>
  • templates/subSilver/simple_footer.tpl
  1. FIND - Line 8
    Powered by <a href="http://www.phpbb.com/" target="_phpbb" class="copyright">phpBB</a> {PHPBB_VERSION} &copy; 2001,2002 phpBB Group</span></div>
    REPLACE WITH
    Powered by <a href="http://www.phpbb.com/" target="_phpbb" class="copyright">phpBB</a> &copy; 2001, 2005 phpBB Group</span></div>
  • viewtopic.php
  1. FIND - Line 498
    	unset($words);
    	$highlight = urlencode($HTTP_GET_VARS['highlight']);
    AFTER, ADD
    	$highlight_match = phpbb_rtrim($highlight_match, "\\");
Thanks
Oh man, I hate upgrading. I'll get to this later I think.
