If you own a forum, and use 2.0.11 or below, follow the instructions below to update to 2.0.12. Remember you will need to download the upgrade package for the update_to_latest.php file. You upload this to your forum root / install directory (eg forums.com/install) and run. Make sure you apply the code changes too, as this script only updates the database.
phpBB 2.0.11 to phpBB 2.0.12 Code Changes
These are the Changes from phpBB 2.0.11 to phpBB 2.0.12 summed up into a little Mod. This might be very helpful if you want to update your Board and have installed a bunch of Mods. Then it's normally easier to apply the Code Changes than to install all Mods again.
When you find a 'AFTER, ADD'-Statement, the Code have to be added after the last line quoted in the 'FIND'-Statement.
When you find a 'BEFORE, ADD'-Statement, the Code have to be added before the first line quoted in the 'FIND'-Statement.
When you find a 'REPLACE WITH'-Statement, the Code quoted in the 'FIND'-Statement have to be replaced completely with the quoted Code in the 'REPLACE WITH'-Statement.
When you find a 'DELETE'-Statement, the Code have to be deleted.
After you have finished this tutorial, you have to upload the update_to_latest.php file, execute it and then delete it from your webspace.
Ok, lets start:
- admin/admin_db_utilities.php
FIND - Line 696
REPLACE WITH
$tables = array('auth_access', 'banlist', 'categories', 'config', 'disallow', 'forums', 'forum_prune', 'groups', 'posts', 'posts_text', 'privmsgs', 'privmsgs_text', 'ranks', 'search_results', 'search_wordlist', 'search_wordmatch', 'sessions', 'smilies', 'themes', 'themes_name', 'topics', 'topics_watch', 'user_group', 'users', 'vote_desc', 'vote_results', 'vote_voters', 'words');Code: Select all
$tables = array('auth_access', 'banlist', 'categories', 'config', 'disallow', 'forums', 'forum_prune', 'groups', 'posts', 'posts_text', 'privmsgs', 'privmsgs_text', 'ranks', 'search_results', 'search_wordlist', 'search_wordmatch', 'sessions', 'smilies', 'themes', 'themes_name', 'topics', 'topics_watch', 'user_group', 'users', 'vote_desc', 'vote_results', 'vote_voters', 'words', 'confirm');
- admin/index.php
FIND - Line 562
AFTER, ADD
"L_NO_GUESTS_BROWSING" => $lang['No_users_browsing']) ); }Code: Select all
// Check for new version $current_version = explode('.', '2' . $board_config['version']); $minor_revision = (int) $current_version[2]; $errno = 0; $errstr = $version_info = ''; if ($fsock = @fsockopen('www.phpbb.com', 80, $errno, $errstr)) { @fputs($fsock, "GET /updatecheck/20x.txt HTTP/1.1\r\n"); @fputs($fsock, "HOST: www.phpbb.com\r\n"); @fputs($fsock, "Connection: close\r\n\r\n"); $get_info = false; while (!@feof($fsock)) { if ($get_info) { $version_info .= @fread($fsock, 1024); } else { if (@fgets($fsock, 1024) == "\r\n") { $get_info = true; } } } @fclose($fsock); $version_info = explode("\n", $version_info); $latest_head_revision = (int) $version_info[0]; $latest_minor_revision = (int) $version_info[2]; $latest_version = (int) $version_info[0] . '.' . (int) $version_info[1] . '.' . (int) $version_info[2]; if ($latest_head_revision == 2 && $minor_revision == $latest_minor_revision) { $version_info = '<p style="color:green">' . $lang['Version_up_to_date'] . '</p>'; } else { $version_info = '<p style="color:red">' . $lang['Version_not_up_to_date']; $version_info .= '<br />' . sprintf($lang['Latest_version_info'], $latest_version) . sprintf($lang['Current_version_info'], '2' . $board_config['version']) . '</p>'; } } else { if ($errstr) { $version_info = '<p style="color:red">' . sprintf($lang['Connect_socket_error'], $errstr) . '</p>'; } else { $version_info = '<p>' . $lang['Socket_functions_disabled'] . '</p>'; } } $version_info .= '<p>' . $lang['Mailing_list_subscribe_reminder'] . '</p>'; $template->assign_vars(array( 'VERSION_INFO' => $version_info, 'L_VERSION_INFORMATION' => $lang['Version_information']) );
- common.php
FIND - Line 56
REPLACE WITH
$test = array('HTTP_GET_VARS' => NULL, 'HTTP_POST_VARS' => NULL, 'HTTP_COOKIE_VARS' => NULL, 'HTTP_SERVER_VARS' => NULL, 'HTTP_ENV_VARS' => NULL, 'HTTP_POST_FILES' => NULL);Code: Select all
$test = array('HTTP_GET_VARS' => NULL, 'HTTP_POST_VARS' => NULL, 'HTTP_COOKIE_VARS' => NULL, 'HTTP_SERVER_VARS' => NULL, 'HTTP_ENV_VARS' => NULL, 'HTTP_POST_FILES' => NULL, 'phpEx' => NULL, 'phpbb_root_path' => NULL); -
FIND - Line 75
AFTER, ADD
else if (@ini_get('register_globals') == '1' || strtolower(@ini_get('register_globals')) == 'on') { // PHP4+ pathCode: Select all
$not_unset = array('HTTP_GET_VARS', 'HTTP_POST_VARS', 'HTTP_COOKIE_VARS', 'HTTP_SERVER_VARS', 'HTTP_SESSION_VARS', 'HTTP_ENV_VARS', 'HTTP_POST_FILES', 'phpEx', 'phpbb_root_path'); -
FIND - Line 92
REPLACE WITH
unset($input['input']); while (list($var,) = @each($input)) { unset($$var); }Code: Select all
unset($input['input']); unset($input['not_unset']); while (list($var,) = @each($input)) { if (!in_array($var, $not_unset)) { unset($$var); } } -
FIND - Line 207
REPLACE WITH
$client_ip = ( !empty($HTTP_SERVER_VARS['REMOTE_ADDR']) ) ? $HTTP_SERVER_VARS['REMOTE_ADDR'] : ( ( !empty($HTTP_ENV_VARS['REMOTE_ADDR']) ) ? $HTTP_ENV_VARS['REMOTE_ADDR'] : $REMOTE_ADDR );Code: Select all
$client_ip = ( !empty($HTTP_SERVER_VARS['REMOTE_ADDR']) ) ? $HTTP_SERVER_VARS['REMOTE_ADDR'] : ( ( !empty($HTTP_ENV_VARS['REMOTE_ADDR']) ) ? $HTTP_ENV_VARS['REMOTE_ADDR'] : getenv('REMOTE_ADDR') );
- includes/functions.php
FIND - Line 80
REPLACE WITH
$username = htmlspecialchars(rtrim(trim($username), "\\")); $username = substr(str_replace("\\'", "'", $username), 0, 25); $username = str_replace("'", "\\'", $username);Code: Select all
$username = substr(htmlspecialchars(str_replace("\'", "'", trim($username))), 0, 25); $username = phpbb_rtrim($username, "\\"); $username = str_replace("'", "\'", $username); -
FIND - Line 83
AFTER, ADD
return $username; }Code: Select all
// added at phpBB 2.0.12 to fix a bug in PHP 4.3.10 (only supporting charlist in php >= 4.1.0) function phpbb_rtrim($str, $charlist = false) { if ($charlist === false) { return rtrim($str); } $php_version = explode('.', PHP_VERSION); // php version < 4.1.0 if ((int) $php_version[0] < 4 || ((int) $php_version[0] == 4 && (int) $php_version[1] < 1)) { while ($str{strlen($str)-1} == $charlist) { $str = substr($str, 0, strlen($str)-1); } } else { $str = rtrim($str, $charlist); } return $str; } -
FIND - Line 608
REPLACE WITH
$debug_text .= '</br /><br />Line : ' . $err_line . '<br />File : ' . $err_file;Code: Select all
$debug_text .= '</br /><br />Line : ' . $err_line . '<br />File : ' . basename($err_file);
- includes/page_tail.php
FIND - Line 38
REPLACE WITH
'PHPBB_VERSION' => '2' . $board_config['version'],Code: Select all
// 'PHPBB_VERSION' => '2' . $board_config['version'],
- includes/template.php
FIND - Line 233
REPLACE WITH
$filename = phpbb_realpath($this->root . '/' . $filename);Code: Select all
$filename = ($rp_filename = phpbb_realpath($this->root . '/' . $filename)) ? $rp_filename : $filename;
- includes/usercp_avatar.php
FIND - Line 54
AFTER, ADD
{ global $board_config, $userdata;Code: Select all
$avatar_file = basename($avatar_file); -
FIND - Line 69
AFTER, ADD
function user_avatar_gallery($mode, &$error, &$error_msg, $avatar_filename) { global $board_config;Code: Select all
$avatar_filename = str_replace(array('../', '..\\', './', '.\\'), '', $avatar_filename); if ($avatar_filename{0} == '/' || $avatar_filename{0} == "\\") { return ''; } -
FIND - Line 235
AFTER, ADD
$move_file = 'copy'; }Code: Select all
if (!is_uploaded_file($avatar_filename)) { message_die(GENERAL_ERROR, 'Unable to upload file', '', __LINE__, __FILE__); }
- includes/usercp_register.php
FIND - Line 462
REPLACE WITH
$avatar_mode = ( !empty($user_avatar_name) ) ? 'local' : 'remote';Code: Select all
$avatar_mode = (empty($user_avatar_name)) ? 'remote' : 'local';
- language/lang_english/lang_admin.php
FIND
BEFORE, ADD
// // That's all Folks! // -------------------------------------------------Code: Select all
// // Version Check // $lang['Version_up_to_date'] = 'Your installation is up to date, no updates are available for your version of phpBB.'; $lang['Version_not_up_to_date'] = 'Your installation does <b>not</b> seem to be up to date. Updates are available for your version of phpBB, please visit <a href="http://www.phpbb.com/downloads.php" target="_new">http://www.phpbb.com/downloads.php</a> to obtain the latest version.'; $lang['Latest_version_info'] = 'The latest available version is <b>phpBB %s</b>.'; $lang['Current_version_info'] = 'You are running <b>phpBB %s</b>.'; $lang['Connect_socket_error'] = 'Unable to open connection to phpBB Server, reported error is:<br />%s'; $lang['Socket_functions_disabled'] = 'Unable to use socket functions.'; $lang['Mailing_list_subscribe_reminder'] = 'For the latest information on updates to phpBB, why not <a href="http://www.phpbb.com/support/" target="_new">subscribe to our mailing list</a>.'; $lang['Version_information'] = 'Version Information';
- templates/subSilver/admin/index_body.tpl
FIND - Line 80
AFTER, ADD
</table> <br />Code: Select all
<h1>{L_VERSION_INFORMATION}</h1> {VERSION_INFO} <br />
- templates/subSilver/overall_footer.tpl
FIND - Line 8
REPLACE WITH
Powered by phpBB {PHPBB_VERSION} line, with phpBB linked to www.phpbb.com. If you refuse to include even this then support on our forums may be affected. The phpBB Group : 2002 // --> Powered by <a href="http://www.phpbb.com/" target="_phpbb" class="copyright">phpBB</a> {PHPBB_VERSION} © 2001, 2002 phpBB Group<br />{TRANSLATION_INFO}</span></div>Code: Select all
Powered by phpBB line, with phpBB linked to www.phpbb.com. If you refuse to include even this then support on our forums may be affected. The phpBB Group : 2002 // --> Powered by <a href="http://www.phpbb.com/" target="_phpbb" class="copyright">phpBB</a> © 2001, 2005 phpBB Group<br />{TRANSLATION_INFO}</span></div>
- templates/subSilver/simple_footer.tpl
FIND - Line 8
REPLACE WITH
Powered by phpBB {PHPBB_VERSION} line, with phpBB linked to www.phpbb.com. If you refuse to include even this then support on our forums may be affected. The phpBB Group : 2002 // --> Powered by <a href="http://www.phpbb.com/" target="_phpbb" class="copyright">phpBB</a> {PHPBB_VERSION} © 2001,2002 phpBB Group</span></div>Code: Select all
Powered by phpBB line, with phpBB linked to www.phpbb.com. If you refuse to include even this then support on our forums may be affected. The phpBB Group : 2002 // --> Powered by <a href="http://www.phpbb.com/" target="_phpbb" class="copyright">phpBB</a> © 2001, 2005 phpBB Group</span></div>
- viewtopic.php
FIND - Line 498
AFTER, ADD
unset($words); $highlight = urlencode($HTTP_GET_VARS['highlight']);Code: Select all
$highlight_match = phpbb_rtrim($highlight_match, "\\");
