I got it sorry!
But how can I delete a case, so that others ant see!!
Jury MOD
battye check your PMs!!!!!
How do i close a case!
Uhh, I can't remember. As I said it's been a few years since I made this.
I'll get back to you over the next hour or so, I'll need to have a look at the code.
ok thanks!!
jury.php?mode=viewcomments
ok...... but how do i delete it so the case doesnt show on jury.php
If I recall, I never added a remove case function.
You can delete the case directly through the database though, would you like me to explain how that is done?
Yes
Do you have phpMyAdmin installed?
yeah
Are you using phpBB Fully Modded?
YES!
Ah, that might cause some problems. Many MOD's refuse to work with phpBBFM because of the vast amount of modifications. Let's hope this isn't the case with the Jury MOD.
Okay, to remove a case, try this (but BACKUP YOUR DATABASE first, or at the least, backup the phpbb_jury table)
Go to phpMyAdmin
Navigate to the phpbb_jury table.
Click "Browse" in the top left of the right frame.
Find the case you want to remove.
Click the delete button (it is a cross)
Once this is removed, it will stop it appearing. As I said, backup your database first... just in case this doesn't work.
Go to phpMyAdmin
Great MODs never go away!
One question, when you've time... do you remember if there's any easy way to navigate through the screens? I ask because the "Submit a case" button doesn't seem to appear.
I can work around it by using the /jury.php?mode=add extension, but I wasn't sure if I'd missed anything in the code that prevented the "Submit" link from showing?
- quahappy
- Happy, not Quappy
First I've heard of this MOD but found the information here: http://www.cmxmods.net/v2/mods/jury_mod/
Looks very interesting and one my members would had a field day with lol! Was going to take a look and install it at my test site but the download link no longer exists. battye?
If you don't ask...
