Jury MOD
Shaistav
Ok mate, I checked out your MODs website... I went to phpBB 2+ version mods, and I dont know how to install the MOD, Jury...
If you have a MSN, can you guide me from there, or if a yahoo then on messenger there.
Thanks. waiting for your reply.
Shaistav
battye check your PMs!!!!!
I will help you through the forum :)
Where are you have trouble?
Shaistav
To put it in the FTP, which folders where?
I'll just warn you, this MOD hasn't been updated since mid-2005. Use at your own risk (but in all likelihood it will be fine) :)
Have you done this yet:
COPY jury.php TO jury.php
COPY jury_install.php TO jury_install.php
COPY language/lang_english/lang_jury.php TO language/lang_english/lang_jury.php
COPY templates/subSilver/jury_add_body.tpl TO templates/subSilver/jury_add_body.tpl
COPY templates/subSilver/jury_body.tpl TO templates/subSilver/jury_body.tpl
COPY templates/subSilver/jury_case_closed TO templates/subSilver/jury_case_closed.tpl
COPY templates/subSilver/jury_index_body.tpl TO templates/subSilver/jury_index_body.tpl
COPY templates/subSilver/jury_view_comments_body.tpl TO templates/subSilver/jury_view_comments_body.tpl
??? Do you know what that means?
Shaistav
Nopes
Do you have an FTP client?
Shaistav
Yes
Do you know how to use it? What is the name of the FTP client?
Shaistav
I know how to use it mate...
I just dont know which files to put in which folders!!!
For example, you would put the file lang_jury.php from the zip you downloaded, into the language/lang_english/ folder on your FTP.
Does that make sense?
Shaistav
I did all tbut then it says table does not exsist
Did you run the file jury_install.php
This will install the database side of it
Shaistav
i did
it says successful too!
Fantastic news! :)
Shaistav
It is working but it says no Cases
how do i add a case
and so that others can too!
