update version 1.2.0 ---> 1.3.0
fruttolo
Hello,
probably this has been asked before but I try it again anyway...
Battye, can you explain me the correct procedure (if there is any) to update the released version 1.2.0 on phpbb with this new 1.3.0 ?
Thanks in advance!
TO update the database, run quiz_updater.php
There are no code changes required, so just overwrite all of the quiz files to make the file updates :)
TommyV
battye wrote:TO update the database, run quiz_updater.php
I have done just as you describe above when updating from 1.20 to 1.31, but for some reason the quiz-page in the administrationpanel says:
The latest version of the Ultimate Quiz MOD: 1.2.0
and I can't find any place to set a time limit... Besides this I have some fields with no explantion to them in the administrationpanel as you can see on the attached image... What did I do wrong?
Regarding latest version, that is only to reflect the latest stable version. 1.3.1 is still considered Beta.
Will fix the time limit problem.
TommyV
battye wrote:Regarding latest version, that is only to reflect the latest stable version. 1.3.1 is still considered Beta.
Okay ;-)
Do you mean that I have to overwrite all of the quiz files to fix the time limit problem? Cause I already did that... And what does the 2 lines with no explanation mean? Or is just me who can't understand this..? :oops:
/Tommy
Two lines with no explaination?
It sounds like maybe you haven't overwritten lang_quiz.php
TommyV
battye wrote:Two lines with no explaination?
Oops... :oops: :oops: :oops: I forgot I was using danish so just copying over the files of course didn't take care of the danish language...
And the lines were as follows:
Give the Quiz Bot a name (the name Quiz Packs are submitted under):
Set a time limit for each question. If this time limit is exceeded, the user will not see their results. Set to 0 for unlimited time.
Is the time limit days, minutes or...? ;-)
Thank you very much for bearing with me ;-)
/Tommy
From memory, seconds. But it might be minutes :)
TommyV
battye wrote:From memory, seconds. But it might be minutes :)
Okay. Thank you very much :-)
