Hello,
probably this has been asked before but I try it again anyway...
Battye, can you explain me the correct procedure (if there is any) to update the released version 1.2.0 on phpbb with this new 1.3.0 ?
Thanks in advance!
update version 1.2.0 ---> 1.3.0
TO update the database, run quiz_updater.php
There are no code changes required, so just overwrite all of the quiz files to make the file updates
I have done just as you describe above when updating from 1.20 to 1.31, but for some reason the quiz-page in the administrationpanel says:battye wrote:TO update the database, run quiz_updater.php
and I can't find any place to set a time limit... Besides this I have some fields with no explantion to them in the administrationpanel as you can see on the attached image... What did I do wrong?The latest version of the Ultimate Quiz MOD: 1.2.0
- ScreenHunter_1.jpg (22.89 KiB) Viewed 5260 times
Regarding latest version, that is only to reflect the latest stable version. 1.3.1 is still considered Beta.
Will fix the time limit problem.so just overwrite all of the quiz files to make the file updates
Okaybattye wrote:Regarding latest version, that is only to reflect the latest stable version. 1.3.1 is still considered Beta.
Do you mean that I have to overwrite all of the quiz files to fix the time limit problem? Cause I already did that... And what does the 2 lines with no explanation mean? Or is just me who can't understand this..?battye wrote:Will fix the time limit problem.so just overwrite all of the quiz files to make the file updates
/Tommy
Two lines with no explaination?
It sounds like maybe you haven't overwritten lang_quiz.php
Oops...battye wrote:Two lines with no explaination?
And the lines were as follows:
Give the Quiz Bot a name (the name Quiz Packs are submitted under):
Set a time limit for each question. If this time limit is exceeded, the user will not see their results. Set to 0 for unlimited time.Thank you very much for bearing with me
/Tommy
From memory, seconds. But it might be minutes
