SQL Error : 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1
after i installed the shoutbox
shoutbox problem
On which page? The shoutbox installer or the index?
Do you have a test account so I can see it first hand?
Okay, well, if it's occuring on the login.php page, it must be another MOD, because shoutbox.php doesn't affect login.php
I get a blank screen when trying to login. Definately not a shoutbox problem. Have you installed any other MOD's lately?
Could not query shoutbox table
DEBUG MODE
SELECT * FROM phpbb_shoutbox ORDER BY shoutbox_id DESC LIMIT
Line : 293
File : index.php
DEBUG MODE
Line : 293
File : index.php
I'm getting a blank page every time I try.NICOI69 wrote:no i got a blank to then i tried again and it worked
