shoutbox problem
NICOI69
SQL Error : 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1
after i installed the shoutbox
On which page? The shoutbox installer or the index?
NICOI69
i get it when i try and log into my forum
http://www.nicos.kicks-ass.net/index.php
NICOI69 wrote:i get it when i try and log into my forum
Do you have a test account so I can see it first hand?
NICOI69
no all i have is my account and thats what i see
Okay, well, if it's occuring on the login.php page, it must be another MOD, because shoutbox.php doesn't affect login.php :?
NICOI69
i used this one ShoutboxMOD013
NICOI69
i made a account for you
username = test
password = testing
I get a blank screen when trying to login. Definately not a shoutbox problem. Have you installed any other MOD's lately?
NICOI69
no i got a blank to then i tried again and it worked
NICOI69
Could not query shoutbox table
DEBUG MODE
SELECT * FROM phpbb_shoutbox ORDER BY shoutbox_id DESC LIMIT
Line : 293
File : index.php
NICOI69 wrote:no i got a blank to then i tried again and it worked
I'm getting a blank page every time I try. :?
NICOI69
changed pass
NICOI69
sorry for taking up your time this is just getting me really confused
NICOI69
message_die(GENERAL_ERROR, 'Could not query shoutbox table', '', __LINE__, __FILE__, $shoutbox_sql);
i deleted this and the forum came up but no shoutbox.
