Format c:Red XIII wrote:i did that and still no gothis is beginning to piss me off
[WinMX] what can i do?
- Boozybaz
- Alcoholic
haha OMG what planet are you on???
i have used all windows since 95, 98 is good for what it is and does but come on you gotta go with the flow and update when updates come out
2k was crap
ME i actually liked and would go bhack to
but XP is easily the best and easiest to use, although it takes a while to adjust 2
2k was crap
If you had xp there would still be options to try to fix this problem, but with 98 there isn't much more you can do to try to fix it.
One and a half years on 98 is a pretty good life. It's time reformat. You can put it off, but there will be more strange problems coming down the road.
I've used the following:
95, 98, ME, XP Home. The one that I think is best is Windows ME, really it is!
I had Windows 3.1 all the way up to XP Pro. I've used all of them. I had success with Win ME, I wouldn't say that it was great but it was stable on my machine when all my friends had problems with it. My recommendation is that you go with XP. It is a really stable OS if you take care of it. When it crashes, it crashes cause I make it crash. IE still has it's problems though.
- Boozybaz
- Alcoholic
ME is very good in my opinion..
XP home is ok but the hassle of activation is a bitch unless you get a original copy
XP pro is amazing i have a copy of XP pro no activation on the tracker all i gotta do is seed it and your away
- Red XIII
- Sultan Ruler Of The Poles!
ME sucked when i tried using it on my moms comp for a while, ive been using 98 for like 5 years now o.o idk ill put XP on here when i think ill absolutely need to format.
- septic544
- Greenhorn
Dno if this will make me look stupid or ne fin but o well.... someone came into my room when i had it open a while back and asked me this... i told them to get the RICHED32.DLL and this person came back and told me this has cured the problem.... hope this helps
Great to see ya Sep!!
