I'm trying this right now. It appears to work. Also, my client connects much faster (a second or two at most) having blocked those IP ranges. Amazing.[/quote]Over on the filebreech forum 'Six' wrote:I was reading the WinMX newsgroup this morning and found something I thought was quite interesting. A user reported that blocking the IP ranges of 209.11.134.* and 209.10.143.* in his firewall (he uses Kerio, but others also have this option) has improved his primary connection, because the 'fakers' use those port ranges. The improvement comes from freeing up the bandwidth normally used by the fakers, thus allowing legitimate users to feed off of them.
It was also reported that filtering searches by adding -Shared to the bottom search box also helps because the fakers tend to share from C:\My Shared Folder, although it wasn't mentioned if this was for audio or video filtering. Through my own experimentation I've found that c:\My Music (note the lower case 'c' for the drive letter) is also being used as a fake shared folder and that -Shared -Music works even better for filtering both audio and video searches. Of course the filtering will exclude quite a few legitimate sources from searches, but queuing, doing a search for alternatives, clearing the top search box and searching again using the HASH alone should remedy that.
Using my secondary (dial up) connection, a normal 'MP3 Audio - Any Bitrate/Any Connection' search for Lil Jon yields several thousands of results with varying frequencies between 320 and 128000, but using the filter I received only 489 results (all except for a couple were seemingly legitimate with a 'normal' frequency of 44100).
A normal video search for both Dodgeball and Shark Tale also turns up an extreme number of results, but a filtered search yielded only 94 and 100 results respectively, with no outlandish numbers under the Status/Server column as is common with fakes.
Try using the filter yourself, especially if you're after newer releases. It could save you from some headaches.
Filtering fakes
I'm interested in this, also, where can I download Kerio? I have Sygate but I don't want to continue using it.
I like Kerio
- Helpful Hands
Thats what firewalls are suposed to do , they work better when set up correctly
- Helpful Hands
Hmm the last words of a madman, RIP Reds XP
quicksilver wrote:Hmm the last words of a madman, RIP Reds XP
- Helpful Hands
I have been doing a bit of research recently and was studying the flooders IP ranges and one whole range stood out as worth blocking
the 61.0.0.0 to 61.255.255.255 range .
This is being used by Sony Sanyo and Panasonic to flood WinMx from, and is the single most important range I can see being used.
There are some others run by Globix and Media Sentry in the 204 and 209 ranges (they like to shift around a bit to keep you on your toes
I dont often get any material from Japan, and I,m sorry that innocent folk within that range will suffer but WinMx is under attack
and the enemy is doing a lot of the attacking from there ,so I would urge you if you can to block that range and see the dramatic drop in flooding.
For those interested, Peer Guardian and Protowall will cover theses ranges too but they seem to not be doing the entire range, and thats
how the flooders are able to keep being effective .
Maybe this is of some interest: http://groups.google.ca/groups?hl=en&lr ... 102a4fef6e
http://mxcontrol.sourceforge.net/module ... =1&thold=0
http://mxcontrol.sourceforge.net/module ... oad&cid=23
If I have some more time, I will modify the patch to automatically update the list of blocked IP's from the web. I might also include the channellist patch and an automatic filter to sort out files with odd bitrates and filenames that are likely to be "fake" (configurable)
Only if I have time though, lol.
