Re: [ALPHA 2] Ultimate Quiz MOD v2.1.1 Progress
Postby V-X » Fri Jun 28, 2013 5:34 am
Hello or your can find the latest version of this mode?
:D
V-X
New version out now!
Postby battye » Sun Jul 28, 2013 2:47 pm
The new version is now out. Here is a copy of the post I made at phpBB.com:
https://www.phpbb.com/community/viewtop ... #p13353769
battye wrote:Sorry for the delays, I know how long this has taken and I do apologise. I have now completed v2.1.2. If anyone notices any buggy behaviour, please let me know.
There are plenty of new features in this version, the main ones being:
  • Time limits on quizzes (with ACP customisable exclusion limits)
  • bbCode allowable on quiz questions
  • Group Rewards (if a user completes all quizzes in a category to a pre-determined percentage score, they will be moved into a usergroup defined in the ACP)
  • Group Permissions (to allow only certain groups to access quizzes in a category)
  • Minor UI customisations
  • UMIL installer
Thanks to Dugi for his assistance with group permissions and the UI customisations.
I have tested this through AutoMOD and had no issues, so hopefully nobody else has any installation problems.
v2.1.2: Download Link
Here are some screenshots of the system:
Any comments, questions and suggestions are welcome :)
Thanks for your patience, I apologise again for the delays.
Re: [ALPHA] Ultimate Quiz MOD v2.1.2 Progress
Postby Clenzowen » Sat Jan 04, 2014 2:35 pm
Hello
Hello
I have on my forum, if I'm not mistaken, the version Ultimate_Quiz_MOD_v200_beta3b
how to update to your new version?
can you help me please
Clenzowen
Frequent Poster
Frequent Poster
Postby battye » Mon Jan 06, 2014 2:19 pm
Clenzowen wrote:Hello
Hello
Hi Clenzowen
Sorry, there is no update scripts between v2.0.0 and v2.1.2 - they use a different database schema :(
Postby Clenzowen » Sat Mar 01, 2014 6:16 pm
Hello
I had a concern on the forum I completely redo.
I just finished installing the mod ultimate quiz and I get an error ..
when I want to create a new category I have the following message
SQL ERROR [ mysqli ]
Incorrect integer value: 'Sports' for column 'quiz_category_name' at row 1 [1366]
SQL
INSERT INTO phpbb_quiz_categories (quiz_category_name) VALUES ('Sports')
BACKTRACE
FILE: (not given by php)
LINE: (not given by php)
CALL: msg_handler()
FILE: [ROOT]/includes/db/dbal.php
LINE: 757
CALL: trigger_error()
FILE: [ROOT]/includes/db/mysqli.php
LINE: 189
CALL: dbal->sql_error()
FILE: [ROOT]/includes/acp/acp_quiz.php
LINE: 86
CALL: dbal_mysqli->sql_query()
FILE: [ROOT]/includes/functions_module.php
LINE: 507
CALL: acp_quiz->main()
FILE: [ROOT]/adm/index.php
LINE: 74
CALL: p_master->load_active()
and my page quiz.php
it's empty I do not see anything on quiz
can u help me please
Clenzowen
Frequent Poster
Frequent Poster
Postby battye » Mon Mar 03, 2014 2:50 am
Hi Clenzowen, are you using the latest version?
Just wanted to make sure, because line 86 of acp_quiz.php in the latest version doesn't make reference to inserting a new category and the line that does should be adding much more than just the category name which is what the error above implies:
Postby Clenzowen » Mon Mar 03, 2014 6:04 am
I just edit this message, see the next message
Clenzowen
Frequent Poster
Frequent Poster
Postby Clenzowen » Mon Mar 03, 2014 8:31 pm
good evening
so, I deleted the mod and I left the mod Ultimate Quiz MOD 'Version 2.1.2
I do not have the choice for permissions, why
why I do not have the same view that you
Clenzowen
Frequent Poster
Frequent Poster
Postby battye » Sat Mar 08, 2014 12:57 am
Hi Clenzowen, what you're seeing is correct.
I'm still running an older version of UQM here which explains why the one here looks a bit different :P :oops:
Postby Clenzowen » Sat Mar 08, 2014 6:49 am
hello
ok but
In the admin when I want to edit the category panel, I can not put value in front of "Minimum percentage."
I have no choice in front of "Destination usergroup"
It's the same thing for "Permitted groups"
Can you help me please
Clenzowen
Frequent Poster
Frequent Poster
Postby battye » Sun Mar 09, 2014 2:31 pm
Hi Clenzowen, do you have any Cash MOD/Point MODs installed?
Secondly, do you have any custom usergroups made. If so, what are their names (the names of the usergroups)?
Postby usertestusertest » Fri Mar 14, 2014 12:56 am
Would be great to see those implemented:
hywel wrote:I've successfully installed the MOD, everything's working but unfortunately there are various features missing. Here's what I really think is missing:
  • quiz introduction text
  • question forms like true/false, input answer and multiple choice
  • users can/cannot play their own quizzes
  • quiz save and resume
  • "best results" stat
  • "most played" stat
  • "most correct answers" stat
  • "highest percentage of correct answers" stat
And here's what I'd like to see, beside the declared features (unfortunately missing from the actual version):
  • users shouldn't be allowed to play a quiz more than once
  • naming the quiz on the same page where you add questions
usertestusertest
Re: [BETA 3] Ultimate Quiz MOD v2.0.0 Progress
Postby korayaksu61 » Fri Sep 30, 2016 3:26 pm
battye wrote:I'm pleased to announce the release of Beta 4 :D
Thanks to mtrs and quahappy for their fantastic support and suggestions throughout the creation of Beta 4 :)
The full list of additions and changes can be found at viewtopic.php?p=99041#p99041
The main new features are a "survey results" feature and a "passworded categories" feature.
The upgrade instructions can be found in the DIY area of the MOD install file (don't forget to reupload all quiz related files and purge the cache in the ACP). For new users installing UQM, there is a UMIL package which you can use (thank you to mtrs for his assistance with this).
Download v2.0.0 Beta 4
RAR: http://www.cmxmods.net/downloads/Ultima ... Beta_4.rar
ZIP: http://www.cmxmods.net/downloads/Ultima ... Beta_4.zip
Hello there;
I installed seamlessly into this mode. I also did my settings. I only have this problem. I can not find a page that shows results after being tested. I wonder if you have a time limit on this plugin? I click on the link to find retest results. It gives me the following error:
You are seeing this error because one of several events might have occurred:
- A cheating attempt may have been detected. You cannot leave a quiz and later re-enter it without going through the save process.
- You have tried to resubmit a quiz that you have exceeded the time limit on
- You have already played this quiz, and the admin does not allow multiple attempts.
Please can you help me by telling that where exam results displayed?
korayaksu61
Previous
Return to Web Design
Who is online
Users browsing this forum: No registered users and 0 guests
cron
