Re: [ALPHA 2] Ultimate Quiz MOD v2.1.1 Progress
Postby V-X » Fri Jun 28, 2013 5:34 am
Hello or your can find the latest version of this mode?
:D
V-X
New version out now!
Postby battye » Sun Jul 28, 2013 2:47 pm
The new version is now out. Here is a copy of the post I made at phpBB.com:
https://www.phpbb.com/community/viewtop ... #p13353769
battye wrote:Sorry for the delays, I know how long this has taken and I do apologise. I have now completed v2.1.2. If anyone notices any buggy behaviour, please let me know.
There are plenty of new features in this version, the main ones being:
  • Time limits on quizzes (with ACP customisable exclusion limits)
  • bbCode allowable on quiz questions
  • Group Rewards (if a user completes all quizzes in a category to a pre-determined percentage score, they will be moved into a usergroup defined in the ACP)
  • Group Permissions (to allow only certain groups to access quizzes in a category)
  • Minor UI customisations
  • UMIL installer
Thanks to Dugi for his assistance with group permissions and the UI customisations.
I have tested this through AutoMOD and had no issues, so hopefully nobody else has any installation problems.
v2.1.2: Download Link
Here are some screenshots of the system:
Any comments, questions and suggestions are welcome :)
Thanks for your patience, I apologise again for the delays.
Re: [ALPHA] Ultimate Quiz MOD v2.1.2 Progress
Postby Clenzowen » Sat Jan 04, 2014 2:35 pm
Hello
Hello
I have on my forum, if I'm not mistaken, the version Ultimate_Quiz_MOD_v200_beta3b
how to update to your new version?
can you help me please
Clenzowen
Postby battye » Mon Jan 06, 2014 2:19 pm
Clenzowen wrote:Hello
Hello
Hi Clenzowen
Sorry, there is no update scripts between v2.0.0 and v2.1.2 - they use a different database schema :(
Postby Clenzowen » Sat Mar 01, 2014 6:16 pm
Hello
I had a concern on the forum I completely redo.
I just finished installing the mod ultimate quiz and I get an error ..
when I want to create a new category I have the following message
SQL ERROR [ mysqli ]
Incorrect integer value: 'Sports' for column 'quiz_category_name' at row 1 [1366]
SQL
INSERT INTO phpbb_quiz_categories (quiz_category_name) VALUES ('Sports')
BACKTRACE
FILE: (not given by php)
LINE: (not given by php)
CALL: msg_handler()
FILE: [ROOT]/includes/db/dbal.php
LINE: 757
CALL: trigger_error()
FILE: [ROOT]/includes/db/mysqli.php
LINE: 189
CALL: dbal->sql_error()
FILE: [ROOT]/includes/acp/acp_quiz.php
LINE: 86
CALL: dbal_mysqli->sql_query()
FILE: [ROOT]/includes/functions_module.php
LINE: 507
CALL: acp_quiz->main()
FILE: [ROOT]/adm/index.php
LINE: 74
CALL: p_master->load_active()
and my page quiz.php
it's empty I do not see anything on quiz
can u help me please
Clenzowen
Postby battye » Mon Mar 03, 2014 2:50 am
Hi Clenzowen, are you using the latest version?
Just wanted to make sure, because line 86 of acp_quiz.php in the latest version doesn't make reference to inserting a new category and the line that does should be adding much more than just the category name which is what the error above implies:
Postby Clenzowen » Mon Mar 03, 2014 6:04 am
I just edit this message, see the next message
Clenzowen
Postby Clenzowen » Mon Mar 03, 2014 8:31 pm
good evening
so, I deleted the mod and I left the mod Ultimate Quiz MOD 'Version 2.1.2
I do not have the choice for permissions, why
why I do not have the same view that you
Clenzowen
Postby battye » Sat Mar 08, 2014 12:57 am
Hi Clenzowen, what you're seeing is correct.
I'm still running an older version of UQM here which explains why the one here looks a bit different :P :oops:
Postby Clenzowen » Sat Mar 08, 2014 6:49 am
hello
ok but
In the admin when I want to edit the category panel, I can not put value in front of "Minimum percentage."
I have no choice in front of "Destination usergroup"
It's the same thing for "Permitted groups"
Can you help me please
Clenzowen
Postby battye » Sun Mar 09, 2014 2:31 pm
Hi Clenzowen, do you have any Cash MOD/Point MODs installed?
Secondly, do you have any custom usergroups made. If so, what are their names (the names of the usergroups)?
Postby usertestusertest » Fri Mar 14, 2014 12:56 am
Would be great to see those implemented:
hywel wrote:I've successfully installed the MOD, everything's working but unfortunately there are various features missing. Here's what I really think is missing:
  • quiz introduction text
  • question forms like true/false, input answer and multiple choice
  • users can/cannot play their own quizzes
  • quiz save and resume
  • "best results" stat
  • "most played" stat
  • "most correct answers" stat
  • "highest percentage of correct answers" stat
And here's what I'd like to see, beside the declared features (unfortunately missing from the actual version):
  • users shouldn't be allowed to play a quiz more than once
  • naming the quiz on the same page where you add questions
usertestusertest
Re: [BETA 3] Ultimate Quiz MOD v2.0.0 Progress
Postby korayaksu61 » Fri Sep 30, 2016 3:26 pm
battye wrote:I'm pleased to announce the release of Beta 4 :D
Thanks to mtrs and quahappy for their fantastic support and suggestions throughout the creation of Beta 4 :)
The full list of additions and changes can be found at viewtopic.php?p=99041#p99041
The main new features are a "survey results" feature and a "passworded categories" feature.
The upgrade instructions can be found in the DIY area of the MOD install file (don't forget to reupload all quiz related files and purge the cache in the ACP). For new users installing UQM, there is a UMIL package which you can use (thank you to mtrs for his assistance with this).
Download v2.0.0 Beta 4
RAR: http://www.cmxmods.net/downloads/Ultima ... Beta_4.rar
ZIP: http://www.cmxmods.net/downloads/Ultima ... Beta_4.zip
Hello there;
I installed seamlessly into this mode. I also did my settings. I only have this problem. I can not find a page that shows results after being tested. I wonder if you have a time limit on this plugin? I click on the link to find retest results. It gives me the following error:
You are seeing this error because one of several events might have occurred:
- A cheating attempt may have been detected. You cannot leave a quiz and later re-enter it without going through the save process.
- You have tried to resubmit a quiz that you have exceeded the time limit on
- You have already played this quiz, and the admin does not allow multiple attempts.
Please can you help me by telling that where exam results displayed?
korayaksu61
Postby cakoceag874 » Sun Jun 20, 2021 1:53 pm
NMD
Adidas Shoes
Nike Cyber Monday 2019
Wholesale Adidas
Jordan 33 shoes
Foamposites
Jordan 26
Jordan AJ 1
Nike SB
Jordan Concord
Nike Huaraches
Jordan 24
Jordan 11
Jordans 32
Cheap Wholesale Nike Shoes Free Shipping
Nike Air Force
Cheap Adidas Shoes
Nike Air Force Ones
Nike Shoes
Pandora Charms
Nike Wholesale Distributors
Pandora Jewelry Official Site
Cheap Jordans From China
Cheap Nike Shoes From China
Nikes Shoes
NHL Jerseys
Nike Shoes
Cheap NFL Jerseys
Jordan 4 Retro
Christian Louboutin
Nike Shoes
Wholesale Jordans
Nike Zoom Pegasus 35
Nike Slides
Nike Wholesale Suppliers
Wholesale Jordans
Air Jordan 23
Jordan 22
Pandora Jewelry
Jordans 12
Air Jordan 33
Nike Outlet Store
Retro 12
Jordan 27
Jordan 11 Low
Nike Jordan
Adidas Yeezy Boost 350 V2
Raptors Jersey
Wholesale Jerseys
Jordans 31
Pandora Jewelry
Nike Running Shoes
Huarache
Air Jordan 29
Nike Jordan 1
Nike Wholesale
Cheap NHL Jerseys
Nike Clearance
Huaraches
Nike 270
Jordan Retros
Nike Epic React
Air Max 720
Nike Shoes Outlet Store Online Shopping
Jordans 28
Jordan 34
Nike Running Shoes For Women
Adidas Yeezy Official Website
Louboutin Shoes
Nike Sneakers
Nike Wholesale
Jordans 15
Pandora Charms
Air Jordan 20
Jordan Retro 11
Jordan 6s
Nike Free
Jordan 16
Jordan 35
MLB Jerseys
Air Max
Cheap Jordans
Pandora Jewelry
Cheap Nikes From China
Nike Outlet Store Online
Nike AF1
Nike Factory Store
Adidas Store
Nike Outlet Store
Air Jordan 33
Nike Metcon
Nike Air Force 1
Air Jordan
Pandora Rings Official Site
Air Jordan Shoes
Jordans 30
Jordan 18
Dior Jordan
Nike Women's Shoes
Jordan 1
Lebron James Sneakers
Roshe
Nike Shoes For Mens
Jordans Wholesale
Nikes Shoes
Custom Jerseys
Adidas Outlet
Nike Blazer
Nike Outlet
Michael Jordan Shoes
Red Bottom Shoes
Adidas Wholesale China
Nike Air Force 1
Kids Jordans
Jordan 2
Nike Air Force 1 High
Air Jordan 19
Off White Nike
Pandora Bracelet Charms
Baby Jordans
Jordan Retro 12
Cheap Jordan Shoes
Nike Shoes
Cheap Wholesale Nike Shoes And Clothing
New Jordans
Nike
Nike Flex
Nike Store
Jordan 17
Air Max 270
What The Jordan 5s
New Nikes Shoes
Air Jordan 13
Nike Outlet
Pandora Jewelry
Nike Air Max
Nike Zoom Fly
NFL Jerseys
Jordan 25
Fjallraven Kanken Official Site
Nike Air Max 720
Pandora Ring
Adidas Shoes For Men
Jordan retro 14
Jordans 13
Nike Cortez
Nike Outlet Store
Nike Shoes
Jordan 21
Cheap Jordan Shoes
Nike Air Force 1 Women
Nike Acg Shoes
cakoceag874
Previous
