Digimoto
- Layzie Bone
- Mr. Computergeek Salad Guy
If you got a problem with your car and you dont feel like forking out $60 to have thier "fine" experts to run a diagnostics test. Visit http://www.digimoto.com the software is about $100 comes with the cables and all, the software is only for ODBII, all cars and lightweight trucks after 1996 are rquired to be ODBII compliant. You can get practically all sensor readings and run a automated dyno test (you will need to provide specific information about your car's tires and such). If your car was made before 1996 you might want to check that it is OBDII compliant.
