Please be aware that this is to be considered an unsecure site. Before using this site I would suggest you use another room name and password and change both (using notepad ) before putting the script in your file .
http://www.mxtools.net/353/config.php
I have tried it and it works fineJust save the file it generates in your winmx folder called chcfg<config file number>.txt (where the config number is anything between 1 and 1000) then in your channel type in /loadcfg <config file number> your channel should then be set up.
When opening a channel you can also simply put the channel number in as the room name (eg call the room 100 and it will load config file 100 when it opens) so you dont have to worry about entering the name every time.
Note: This script uses level 150 for admins and sets up commands to give them access to most commands, however it doesn't give them access to commands such as rename the channel and change the topic because most admins dont need this access, if they need this access just give them a level 230 password by adding /mklogin 230 <password> to the bottom of the config file
