Hi All,
Sorry i took so long to get to yas but i was away for awhile.
On the Note of Adware in Bearshare, there is one big stuff up in this program that is easily disabled. Its got something to do with BearShare sharing a file its not meant to, the Win.INI file ... one way to get rid of this problem is to disable the web browser in Bearshare by going to :
Setup
Uploads
Then Uncheck the box that says " Activate the Built in Web Server "
Note: the stuff up was with bearshare 4.0.0 , 4.0.1 (sorry about that)
Ok as for the SPYWARE on bearshare there are two known Spyware programs that you should tend to imediately They Are :
1.
SaveNow : Which is installed no matter what, even tho you have the option not to install it ... what you do is delete that folder (which is c:\Program Files\SaveNow ) then run your Adware or Spyware
remover (I personally used Adaware for this and it did the job ), There should be 2 registry Keys for SaveNow and 1 installer File for SaveNow.
(Should you decide to un-install BearShare, The Above spyware components are left on your computer. )
And if you get the " Lite Version " (free) there is another spyware component that comes with it and its called Weather Watch (or similar) ( nothing major but i got when i installed the free version of bearshare, i just deleted the folder and ran adaware again).
For more info goto :
https://netfiles.uiuc.edu/ehowes/www/soft23a.htm
( To See If Any P2P Program You are using has Been Infested With SpyWare Or Not.)
OR
http://www.oit.duke.edu/ats/support/spy ... share.html
( To See What Spyware Is In Bearshare )
