Displaying posts to external page hiding my content
Posted: Tue Jan 04, 2011 1:45 am
Hello, I followed the tutorial on http://blog.phpbb.com/2009/11/09/how-to ... nal-pages/ to get my main page to display the latest 5 posts from a "News" section on my forums, and it is displaying correctly, however nothing else on the page is visible after the news feed. No text, images, tables, anything are able to be displayed while this code is active for some reason and I cannot figure it out. I noticed another user posted the same problem in a separate thread but it never seemed to have gotten resolved. Has anyone found out any other solutions to this since then?
Here is my code
This code is inside of a table cell in my "news table", however taking it out of the table and just displaying it in the body does not resolve the issue. I am planning on adding quite a bit of content underneath this News table where the forum is being fed to. Is there some way replace the page_footer() call inside the php block with something else and still have the feed work?
I tried removing page_footer(); from the main php code and adding <?php page_footer(); ?> at the very bottom of my page, however all that did was display the forum feed on the very bottom of the page instead of in my News table.
Any help is appreciated, thanks!
Here is my code
* home.php
* September 29, 2009
$phpbb_root_path = (defined('PHPBB_ROOT_PATH')) ? PHPBB_ROOT_PATH : './forums/';
// Start session management
$user->session_begin();
$auth->acl($user->data);
$user->setup('viewforum');
* posts and topics */
global $db, $auth;
switch($type)
case 'forum':
$type = 'forum_id';
break;
case 'topic':
$type = 'topic_id';
break;
default:
// no restrictions
$out_where = '';
if( $size_gen_id > 0 )
if( $type == 'topic_id' )
unset($gen_id);
$gen_id = $topic_id_list;
$j = 0;
$j++;
return $out_where;
$search_limit = 5;
$forum_id = array(4, 4);
$topic_id = array(20, 50);
$posts_ary = array(
'SELECT' => 'p.*, t.*, u.username, u.user_colour',
'FROM' => array(
POSTS_TABLE => 'p',
'LEFT_JOIN' => array(
array(
'FROM' => array(USERS_TABLE => 'u'),
'ON' => 'u.user_id = p.poster_id'
array(
AND t.topic_approved = 1',
$post_author = get_username_string('full', $posts_row['poster_id'], $posts_row['username'], $posts_row['user_colour']);
$post_date = $user->format_date($posts_row['post_time']);
$post_link = append_sid("{$phpbb_root_path}viewtopic.$phpEx", 'f=' . $posts_row['forum_id'] . '&t=' . $posts_row['topic_id'] . '&p=' . $posts_row['post_id']) . '#p' . $posts_row['post_id'];
'POST_AUTHOR' => $post_author,
'POST_DATE' => $post_date,
'POST_LINK' => $post_link,
'body' => 'newstemplate.html'
page_footer();
