Page 5 of 5
Re: Event Calendar RSVP
Posted: Sun Mar 21, 2010 9:58 am
I'm really sorry havocwreaker, I've had a really busy fortnight. I promise that later this week we'll finish this off... my to-do list is growing quite quickly:
http://forums.cricketmx.com/viewtopic.p ... 29#p100229
Posted: Sat Mar 27, 2010 7:08 am
I'm back now havocwreaker
Could you please post your full
make_rsvp.php file (as it is right now) here in code tags.
Posted: Mon Apr 05, 2010 2:33 am
by havocwreaker
As requested:
$phpbb_root_path = (defined('PHPBB_ROOT_PATH')) ? PHPBB_ROOT_PATH : './';
// Start session management
$user->session_begin();
$auth->acl($user->data);
$user->setup('viewforum');
$alert_id = request_var('alert', 0);
// html
echo '<html>';
echo '<head><title>RSVP Page</title>';
echo ' <style type="text/css">
.graph {
background-color: #C8C8C8;
border: solid 1px black;
.graph td {
font-family: verdana, arial, sans serif;
.graph thead th {
border-bottom: double 3px black;
padding: 1em;
.graph tfoot td {
border-top: solid 1px #999999;
font-size: x-small;
text-align: center;
padding: 0.5em;
color: #666666;
.bar {
background-color: white;
text-align: right;
border-left: solid 1px black;
padding-right: 0.5em;
width: 400px;
.bar div {
border-top: solid 2px #0077DD;
background-color: #004080;
border-bottom: solid 2px #002266;
text-align: right;
color: white;
float: left;
padding-top: 0;
height: 1em;
body {
</style>';
echo '</head>';
echo '<body bgcolor="#CADCEB">';
if( $alert_id > 0 )
$rsvp_sql = 'SELECT COUNT(rsvp_id) AS count_rsvp,
SUM(rsvp_yes_no) AS yes_rsvp, alert_id
FROM phpbb_alerts_rsvp
WHERE alert_id = ' . $row['alert_id'];
$rsvp_result = $db->sql_query($rsvp_sql);
$rsvp_row = $db->sql_fetchrow($rsvp_result);
$rsvp_total = $rsvp_row['count_rsvp'];
$rsvp_yes = $rsvp_row['yes_rsvp'];
$rsvp_yes = ($rsvp_yes >= 0) ? $rsvp_yes : 0;
$rsvp_no = $rsvp_total - $rsvp_yes;
$rsvp_no = ($rsvp_no >= 0) ? $rsvp_no : 0;
$rsvp_yes_percent = number_format(($rsvp_yes / $rsvp_total), 0);
$rsvp_no_percent = number_format(($rsvp_no / $rsvp_total), 0);
echo '<form action="' . append_sid('make_rsvp.'.$phpEx, 'mode=submit') . '" method="post">';
echo '<h3>RSVP:</h3><br />';
echo '<input type="radio" name="rsvp" value="1" /> Yes <br />';
echo '<input type="radio" name="rsvp" value="0" /> No <br /><br />';
echo '<h3>Explanation:</h3>';
echo '<input type="text" name="explain" maxlength="255" />';
echo '<input type="hidden" name="alert_id" value="' . $alert_id . '" />';
echo '</form>';
echo '<h3>Statistics:</h3>';
echo '<br /><br /><table width="530" class="graph" cellspacing="6" cellpadding="0">
<thead>
<tr><th colspan="3">RSVP statistics</th></tr>
</thead>
<tbody>
<tr>
<td>Yes</td><td class="bar"><div style="width: ' . $rsvp_yes_percent . '%"></div>' . $rsvp_yes . '</td><td>' . $rsvp_yes_percent . '%</td>
</tr>
<tr>
<td>No</td><td class="bar"><div style="width: ' . $rsvp_no_percent . '%"></div>' . $rsvp_no . '</td><td>' . $rsvp_no_percent . '%</td>
</tr>
</tbody>
<tfoot>
<tr><td colspan="3">This shows the number of people to have submitted their RSVP.</td></tr>
</tfoot>
</table>';
else if( request_var('mode', '') == 'submit' && request_var('alert_id', 0) > 0 )
$rsvp_array = array(
'alert_id' => request_var('alert_id', 0),
'user_id' => $user->data['user_id'],
'username' => $user->data['username'],
'rsvp_text' => request_var('explain', ''),
'rsvp_yes_no' => request_var('rsvp', 0),
'rsvp_time' => time(),
$rsvp_sql = 'INSERT INTO phpbb_alerts_rsvp ' . $db->sql_build_array('INSERT', $rsvp_array);
echo 'Your RSVP has been submitted to the database';
else
echo 'Invalid id';
// html
echo '</body>';
echo '</html>';
Posted: Mon Apr 05, 2010 4:09 am
FIND
if( $alert_id > 0 )
REPLACE WITH
if( $alert_id > 0 )
WHERE alert_id = ' . $alert_id;
(the only change is on that final line, to $alert_id)
That should remove that SQL database error you were getting?
Happy Easter
Posted: Tue Apr 06, 2010 1:15 am
by havocwreaker
File updated. I can't review to see if it works since the developers broke the forum. I will verify once it is running smooth again.
Posted: Tue Apr 20, 2010 4:04 am
by havocwreaker
Site is working as it should now. I apologize for taking so long to get back to you but I was prepping for an event. I didn't get to use the alert mod you mode though.
It's active now. Would you care to continue helping me get it so that it works for regions or states?
