Page 2 of 4
Re: [BETA 3] Calendar Alerts MOD v0.0.3
Posted: Sat Mar 20, 2010 4:51 pm
Thanks plasmino, I've updated the first post
Posted: Fri Jul 16, 2010 8:19 pm
by pluto
Hello,
When I want to cancel a deletion warning, I get this error:
Général error
template->_tpl_load_file(): File ./styles/acidtech/template/.html does not exist or is empty
Thank you to you.
Posted: Wed Jul 28, 2010 8:44 pm
by Marije
Hi, great mod!
Perfect for me, who always forgets everything haha
I have 2 questions
Is there a dutch translation?
And can i edit it somehow to make it only for the admin, not the other users?
Posted: Mon Aug 02, 2010 6:27 pm
by Marije
Does anyone know these anwers?
Posted: Tue Aug 03, 2010 10:18 am
Hi, sorry for the delay in replying. I don't think there is Dutch, every translation I know of is in this post:
http://forums.cricketmx.com/viewtopic.php?f=63&t=4746
And when you say make it only for the admin, do you mean you want alerts to appear only to admins or you want both the "add alerts" page in the UCP
and the alerts on the index to only appear to admins? Just let me know which it is - it is a fairly easy change to implement and I will tell you which code you will need to edit
Thanks for registering at CMX Marije, welcome to the forum
Posted: Tue Aug 03, 2010 11:42 am
by Marije
Thanx for the reply
I want it to be only for admin, both the page in UCP to add an alert, and to see the alert.
Posted: Wed Aug 04, 2010 11:56 am
by pluto
pluto wrote:Hello,
Général error
Thank you to you.
Hello,
Person for the solution ?
Thank you very much.
Posted: Wed Aug 04, 2010 2:25 pm
Hi pluto, have you uploaded ucp_alerts.html to styles/acidtech/template/
Posted: Wed Aug 04, 2010 2:40 pm
by pluto
Yes, this file "ucp_alerts.html" is indeed in: styles/acidtech/template/
Thank you.
Posted: Wed Aug 04, 2010 2:42 pm
What about confirm_body.html?
Posted: Wed Aug 04, 2010 2:45 pm
by pluto
confirm_body.html is OK also, It's just the cancellation
Otherwise the mod to work perfectly
Edit: I did a test on your forum and when I delete an alert and click cancel I get a blank page.
Posted: Thu Aug 05, 2010 5:00 am
Try this:
open ucp_alerts.php and find:
if (confirm_box(true))
$sql = "DELETE FROM " . ALERTS_TABLE . "
WHERE alert_id = " . request_var('delete', 0) . "
AND user_id = " . (int) $user->data['user_id'];
$db->sql_query($sql);
// Clear the cache
$cache->destroy('sql', ALERTS_TABLE);
trigger_error( sprintf($user->lang['UCP_ALERTS_DELETE_SUCCESS'], "<a href='" . append_sid($this->u_action) . "'>", "</a>") );
After add:
Now try it, you should get the message 'Test' (if this works then I will give you the redirect code
Posted: Thu Aug 05, 2010 8:28 pm
by pluto
Indeed, when I click the little X to delete the word "test" appears
Thank you.
Posted: Fri Aug 06, 2010 3:36 pm
Now replace the line:
With
redirect(append_sid("{$phpbb_root_path}ucp.$phpEx", "i=alerts&mode=alerts"));
Does that fix it?
Posted: Fri Aug 06, 2010 4:07 pm
by pluto
No sorry, nothing happens, this has no effect
Note: I do not have the phrase "Are you sure you want to delete this alert?"
