WCB
Mind released an update for WCB.
Here's WCB v0.4.1 .. updated by mind. This version was updated to accommodate ZCS test rooms and fixes a memory leak with the crash handler. Also, ontimer was added in so it will work with all the plugins.
WCB 0.4.1 changelog
Fixed loading channel list causing a segfault
Fixed settings being saved every two seconds
Added OnTimer (identical to the one in 0.5)
Fixed memory leak in crash handler
Thanks for the update Mind.
WCB v0.4.2
Release date: September 11, 2009
Changed the peer caches from caches.mxstuff.org to caches.winmxworld.net.
Download link
WCB-0.4.2.zip
(60.72 KiB) Downloaded 2348 times
Thanks for the update Raven. :)
]2aven
In Memory Of Raven
In Memory Of Raven
Ty for posting the update :)
Here are some plugins that I use in WCB. I got them from Raven's (R.I.P.) old mxmadness forum before she shut it down.
WCB FileFinder.zip
With this plugin you can search for files in your room.
(25.53 KiB) Downloaded 2148 times
Type !find + search term to search for files in the room. !find Metallica as an example.
WCB plugin FindChan for WCS.zip
With this plugin you can search for chat rooms in your room. It was made for WCS hosted chat rooms.
(3.22 KiB) Downloaded 2205 times
WCB plugin FindChan for ZCS.zip
With this plugin you can search for chat rooms in your room. It was made for ZCS hosted chat rooms.
(3.2 KiB) Downloaded 2116 times
Type !findchan + room name or !findtopic + room topic to search for chat rooms in your room.
WCB OnJoin Plugin.zip
With this plugin you can add an onjoin & onpart message when someone enters or leaves your room in the onjoin.txt and onpart.txt files.
(3.33 KiB) Downloaded 2156 times
WCB plugin OnEnter Plugin.zip
Whenever WCB enters the room it'll display the text in the onenter.txt. I use it to log my bot in automatically.
(3.04 KiB) Downloaded 2113 times
shakes
Hi newbie here,I would like to know if there is anyway of sending the results of !findfile in private message :?
result settings /message #c4#$NAME$#c2# has #c5#$FILE$#c2# shared (#c1#$SIZE$#c2#).
something like that.
You do it like this: /message $USERNAME$ #c4#$NAME$#c2# has #c5#$FILE$#c2# shared (#c1#$SIZE$#c2#).
Røçkåfë££ë® §kåñK
Unfortunately in WCB all "scripts" are made as plugins loaded into WCB so you would need the sourcecode for that particular plugin to edit and recompile.
You don't have to recompile it to add /message $USERNAME$ #c4#$NAME$#c2# has #c5#$FILE$#c2# shared (#c1#$SIZE$#c2#) to the file finder plugin.
All you need to do is go to the file finder options in WCB and add it to the Results Format:.
Røçkåfë££ë® §kåñK
My bad sorry! I dont actually use this particular plugin and therefore assumed there was little to any settings options.
