Download link: wcb-0.5b2.zipver 0.5 Beta1(22-07-08) B&M
compiled for XP with Dev-Cpp and mingw32 ( open source C++ IDE and compiler) --> no need of $$Microsoft Visual Studio .
- Modified some pieces of the source code to compile with mingw32.
- Fixed a memory leak with crash Handler.
- Added a menu parameter to disable Browse Users Files (reduce CPU and Memory Usage) :
Menu Channel/Disable Browse Users Files.
- Add a Timer Event for the Plugins. This Timer Event is Sent every 2 seconds.
see the new c sample plugin to declare and use it ( ontimer ).
- You can use now Delphi to create Plugins (see the Delphi sample plugin).
This version has been released from the 0.4b KingMacro source code.
here a new release of WCB 0.5 :
WCB 0.5 Beta2(27-07-08) B&M
- fixed bug with SaveSettings ( when you started WCB, every 2 seconds the file settings.dat was updated).
The plugins threads are here.
