Page 1 of 2
Create an ads to the right side of viewforum/viewtopic
Posted: Thu Jun 14, 2007 5:51 pm
by Leon
I want to create an ad place (with same style as prosilver around it)
Just like in this image below:
I do not want to edit it in the header/footer
so all pages get it, only viewforum/viewtopic
Inex page gona have another similar thing in it so
Posted: Sat Jun 16, 2007 11:29 am
Would you be happy with putting it in a table, or do you wish to maintain the tableless CSS which IIRC is in place in proSilver?
Posted: Sat Jun 16, 2007 12:18 pm
by Grinch
I may be able to come up with something if I can get some free time.
Posted: Sun Jun 17, 2007 3:58 am
by Leon
battye wrote:Would you be happy with putting it in a table, or do you wish to maintain the tableless CSS which IIRC is in place in proSilver?
Any way is fine, but the closer to original phpBB code the better...
Also, i think this mod has "the box code"
http://startrekguide.com/forum/viewtopi ... =84&t=2711
Posted: Sun Jun 17, 2007 4:09 pm
Okay, if you don't mind a table (it will be borderless, so you won't know the difference at a glance) it should be fairly easy.
Would you be able to PM me the contents of these files?
styles/proSilver/templates/viewforum_body.html and styles/proSilver/templates/viewtopic_body.html
Posted: Sun Jun 17, 2007 11:33 pm
by Leon
Done
Posted: Tue Jun 19, 2007 2:10 pm
Okay, we'll experiment with viewforum.
Find
<!-- IF S_HAS_SUBFORUM -->
<!-- IF not S_IS_BOT -->
<ul class="linklist">
<li class="rightside"><a href="{U_MARK_FORUMS}">{L_MARK_FORUMS_READ}</a></li>
</ul>
BEFORE ADD
FIND
<!-- IF .topicrow and not S_DISPLAY_ACTIVE -->
<div class="topic-actions">
<!-- IF S_IS_POSTABLE and not S_IS_BOT -->
<div class="buttons">
BEFORE ADD
</td>
<td>####AD CODE HERE####</td>
</tr>
</table>
Let me know how that goes
Apologies if the layout doesn't work, simply undo the changes if that is the case
Posted: Fri Jun 22, 2007 12:22 pm
How did this work out?
Posted: Thu Jun 28, 2007 7:26 pm
by Leon
One of my HDD has crached at home,
or it is begining to.
So i test this in the comming week when my
home computer is up and running again...
Lycky me that it is one the c: disk with no
importent things on it anymore =P
Posted: Fri Jun 29, 2007 8:14 am
Ouch, bad luck mate!
Glad to hear there was no important information on your C: drive.
Posted: Sun Jul 08, 2007 2:58 am
by Leon
It almost worked, as you can see it dosen't uses the full width then
Posted: Sun Jul 08, 2007 5:36 am
Instead of
Try
<table width="100%" border="0">
<tr>
<td>
Posted: Sun Jul 08, 2007 4:26 pm
by Leon
Yes it seems to work now, i gona test it for a few days with different browsers etc,
and then i tell you the results, and you can publish it as a full RC2 mod at phpbb.com or something
Posted: Sun Jul 08, 2007 5:33 pm
by Leon
Some changes:
Find:
<!-- BEGIN topicrow -->
Before add:
<tr>
<td VALIGN="TOP">
Find:
<!-- END topicrow -->
After add:
</td>
<td VALIGN="TOP" WIDTH="170" ALIGN="CENTER">
<!-- Banner Start -->
### YOUR BANNER HERE ###
<!-- Banner END -->
</td>
</tr>
</table>
Posted: Sun Jul 08, 2007 5:37 pm
by Leon
That works greate on the normal viewforum.php
But if you look at the category, it dosen't look so good =/
Like this:
Normal viewforum:
http://www.adminklubben.se/viewforum.php?f=2
Works fine
Looking at the categories:
http://www.adminklubben.se/viewforum.php?f=28
Ads gets under
Is it possibly to exclude the ads to be shown in the categories ?
like:
<!-- if_category_dont_show --> <!-- end if -->
something like all other strange new code bb3 has...
