Warning messages
Posted: Mon Apr 30, 2007 6:03 pm
by m8trix
I just installed you quiz game and I am getting these warning messages at the ACP/ Quiz
Warning: file() [function.file]: URL file-access is disabled in the server configuration in /misc/20/261/195/384/9/user/web/m8trixnation.com/phpBB2/admin/admin_quiz.php on line 400
Warning: file(http://www.cmxmods.net/quiz_latest.txt) [function.file]: failed to open stream: no suitable wrapper could be found in /misc/20/261/195/384/9/user/web/m8trixnation.com/phpBB2/admin/admin_quiz.php on line 400
and on the quiz packs
Warning: file_get_contents() [function.file-get-contents]: URL file-access is disabled in the server configuration in /misc/20/261/195/384/9/user/web/m8trixnation.com/phpBB2/admin/admin_quiz_packs.php on line 97
Warning: file_get_contents(http://www.m8trixnation.com/phpBB2/admi ... _Trivia.qp) [function.file-get-contents]: failed to open stream: no suitable wrapper could be found in /misc/20/261/195/384/9/user/web/m8trixnation.com/phpBB2/admin/admin_quiz_packs.php on line 97
and
Warning: file_get_contents() [function.file-get-contents]: URL file-access is disabled in the server configuration in /misc/20/261/195/384/9/user/web/m8trixnation.com/phpBB2/admin/admin_quiz_packs.php on line 157
Warning: file_get_contents(http://www.m8trixnation.com/phpBB2/admi ... _Trivia.qp) [function.file-get-contents]: failed to open stream: no suitable wrapper could be found in /misc/20/261/195/384/9/user/web/m8trixnation.com/phpBB2/admin/admin_quiz_packs.php on line 157
since I am novice at this I am trying to make heads or tail of these warnings. Can you help.
Much thanks in adavance for any help.
Posted: Mon Apr 30, 2007 8:43 pm
by m8trix
I am also getting this error and warning message when I attempted to make my test quiz and ran it
Warning: include() [function.include]: Unable to access ./includes/functions_cash.php in /misc/20/261/195/384/9/user/web/m8trixnation.com/phpBB2/quiz.php on line 952
Warning: include(./includes/functions_cash.php) [function.include]: failed to open stream: No such file or directory in /misc/20/261/195/384/9/user/web/m8trixnation.com/phpBB2/quiz.php on line 952
Warning: include() [function.include]: Failed opening './includes/functions_cash.php' for inclusion (include_path='.:/usr/share/pear') in /misc/20/261/195/384/9/user/web/m8trixnation.com/phpBB2/quiz.php on line 952
The Nations Forum Forum Index
General Error
Unable to execute cash name query
DEBUG MODE
SQL Error : 1146 Table '2611953849.CASH_TABLE' doesn't exist
SELECT cash_name FROM CASH_TABLE WHERE cash_dbfield = 'user_points'
Line : 959
File : quiz.php
Posted: Wed May 02, 2007 8:22 pm
by nesman
It looks like something in the configuration on your host's server.
This error says that your version of php isn't allowed to open a remote file like this. That's why the next error happens.
Php.net suggests that this can only be disabled by your host unless you can change your php.ini. Otherwise, I'd have suggested to adjust your .htaccess.
http://www.php.net/manual/en/ref.filesy ... -url-fopen
Posted: Sat May 05, 2007 3:46 pm
by m8trix
Thanks for that. I really appreciate the info.
Posted: Wed May 09, 2007 7:49 pm
by Noneya Beeswax
I just installed the quiz, and have an error message.
Query 17 did not execute correctly
DEBUG MODE
SQL Error : 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'WHERE config_name = 'Quiz_Cash_Currency'' at line 1
UPDATE phpbb_config SET config_value = WHERE config_name = 'Quiz_Cash_Currency'
Line : 84
File : admin_quiz.php
For note: I don't have the Cash MOD installed, and don't particularly want to. I have have not enabled the cash since is isn't used.
Posted: Wed May 09, 2007 10:01 pm
by Noneya Beeswax
I also have an error message at the top of the header on the "Veiwers online"
Warning: Cannot modify header information - headers already sent by (output started at /home/chopp/public_html/viewonline.php:2) in /home/chopp/public_html/includes/page_header.php on line 533
( header ('Cache-Control: private, pre-check=0, post-check=0, max-age=0');) is that line
Warning: Cannot modify header information - headers already sent by (output started at /home/chopp/public_html/viewonline.php:2) in /home/chopp/public_html/includes/page_header.php on line 535
(header ('Expires: 0'); ) is that line
Warning: Cannot modify header information - headers already sent by (output started at /home/chopp/public_html/viewonline.php:2) in /home/chopp/public_html/includes/page_header.php on line 536
(is that line of code)
Posted: Sun May 13, 2007 9:53 pm
by nesman
Well, if you comment out that line the error will go away, but I can't promise you won't see new errors from it. :) I'll have to defer to Battye on this one.
