Virtual Laser Keyboard
What is it?
The Virtual Laser Keyboard (VKB)
uses both infrared and laser technology to generate an invisible field and project a full-size virtual QWERTY keyboard on any surface.
You can use the VKB (Virtual PC Keyboard) with both your laptop and PC or with a compatible mobile device, Smartphone and PDA.
The I-Tech VKB reacts exactly like a real keyboard.
Direction technology based on optical recognition enables the user to tap the images of the keys, complete with realistic tapping sounds(!), which feeds into the compatible PDA, Smartphone, laptop or PC.
Virtual Laser Keyboard Features:
# Personal Digital Assistants (PDA's)
# Cellular Telephones
# Laptops
# Tablet PCs
# Space saving Computers
# Clean Rooms
# Industrial Environments
# Test Equipment
# Sterile and Medical Environments
# Transport (Air, Rail, Automotive)
# When using the VKB settings can be changed either via your laptop, your PC or your compatible Smartphone and PDA:
# Sound: controllable Virtual Keyboard sound effects (keyclicks)
# Connection: Connection to the appropriate Laptop/PC port
# Intensity: Intensity of the projected Virtual Keyboard
# Timeouts: coordinated timeouts to conserve the Virtual Keyboard's battery life
# Sensitivity: adjustable sensitivity of the Virtual Keyboard
# Auto-repeat: Allows the VKB to automatically repeat a key based on prescribed parameters
http://www.virtual-laser-keyboard.com/
wow that's 8) ..I would like to try that out.
It would leave an awesome wear pattern on your desk.
