Profit isn't working
NFM
I just installed version 1.3.3 on my PHP 2.0.21 forum and I can adjust the tax, and the amount lost per incorrect answer, but whenever I choose a number for profit it comes up as 0.
Also, I installed the "quiz pack" that came with the mod and I can't see the quiz anywhere.
NFM
Quick update to this...
I've also noticed that it won't let me select (Yes) to "Users can only play each quiz once"....honestly, it doesn't let me select either as the radio button doesn't show up until I click it, and then when I click submit it disappears again.
NFM
I think it's an SQL error...where can I find the SQL queries for this mod?
Sorry, I missed this thread :oops:
The SQL queries can be found in quiz_install.php
NFM
Okay, I feel stupid...I know the SQL is written in PHP in that file...but I don't know how to type it out properly for PHPMyAdmin. I need to drop and recreate the tables that have to do with those two problems...I think that will fix it. The one for the profit, loss, and tax...and the one for the "Play Once" Any way you can show me what I need?
It's the early hours of the morning for me, so I will have a look through the file and paste the SQL queries here for you tomorrow :)
NFM
Thank you....I'm at work anyway...makes it easier for me too.
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Play_Once', '1');
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Cash_Incorrect', '1');
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Cash_Correct', '1');
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Cash_Tax', '2');
NFM
I tried running those and got this error
Error in SQL query INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Play_Once', '1');
Click here to return to phpBBMyAdmin board.
Click here to return to Admin Control Panel board.
DEBUG MODE
SQL Error : 1062 Duplicate entry 'Quiz_Play_Once' for key 1
And I still get "0" for profit when you look at the Quiz.php page on my forums. So it's still not letting me enter in a profit per correct answer.
