Some Bugs - Maybe ? - MOD v133
Keefy
when you click to delete or edit or move a quiz then the information screen just sticks there, for example if you delete a quiz you get a information screen up to say your quiz has successfully been deleted.
Is it possible that whenever you get the information screen up that after 5 seconds or whatever it will then automatically go back to the main quiz index.
When i go to Edit a Quiz thats multiple choice, the answers are still there but none of the boxes for the correct answer is ticked.
Is this a bug with the multiple choice ?
Not got a true or flase one to check if they are still ticked on the correct answer.
The input answer quiz ones are still showing if you try to edit that.
EDIT:-
Just noticed if i try to edit a quiz i made using the input box, on a ten question quiz that the 1st 4 questions have moved from there original place when i input them.
I have a quiz where you minus a letter from the previous last answer to get the answer for example leaving the questions out:-
tripe
trip
tip
ti
i
then i start with a 5 letter again
spine
pine
pin
pi
p
when ive gone back to edit the order is wrong for the 1st 4 only showing.
tip
ti
trip
tripe
i
spine
pine
pin
pi
p
Sorry for the delay in replying.
These are all pretty minor bugs, some aren't even bugs at all (ie. the lack of the redirect).
In the future, I will try to resolve some of these. Thanks for bringing them to my attention :)
