Quiz Link only with subsilver
fred12345
Hi, can you help? I only get the quiz link wiith the subsilver template. I've several others available to members of the forum with aqua as the default.
What do I need to do to get the link visible in the other templates? I've checked and all the files have been downloaded to the other templates.
My forum is at http://www.othockey.co.uk/phpbb/
I've created a temp membership for you to use, with the info below.
USERNAME - tempacct
PASSWORD - temp1234
In the MOD install file it says to edit templates/subSilver/overall_header.tpl
You simply need to apply these changes to every other template too (so if you used subBlack, you'd edit templates/subBlack/overall_header.tpl).
That will add the link to your other templates :)
fred12345
Thanks, that works fine
