PDF Converter
Posted: Thu Jul 13, 2006 6:29 am
PDF Converter
Convert MS Office, Images, Web Pages, Vector Graphic Formats files to PDF
convert PDF to Microsoft Word
http://www.freepdfconvert.com/Here, you can convert most commonly used Microsoft Office, Open Office, graphic images, vector graphic formats to PDF (e.g. convert DOC to PDF) and back from PDF to MS Word DOC format. Our Online PDF Converter and document creator is quick and reliable, and the interface is so intuitive that you won't find it hard to figure it out how to convert your files.
Example: you need to convert a Power Point (PPT) file into PDF. Use the "Browse" button to locate the source file on your local PC, select it, then click the "Convert" button. Done.
