what about the future for UQM?
jpd
I would like to know If it could be possible one day to make quizzes with pictures? I mean that a small picture (for example, taken from smartor album) could be shown instead of a question?
I 'll get a lot of use of it : education testing for students of biology with pictures of microscopy
jpd
I 've installed the last release of UQM (1.1.0) and I encounter thsi problem :
SQL Error : 1054 Unknown column 'quiz_category' in 'where clause'
Line : 47
File : functions_quiz.php
help me!
Hi, bbCode will be standard, likely in 1.1.1. That includes pictures.
Regarding the error, did you run quiz_install.php?
jpd
yes of course I did the install
Does your line 47 match this area:
function category_quizzes($id)
global $db;
$sql = "SELECT * FROM " . QUIZ_GENERAL_TABLE . " WHERE quiz_category = '" . intval($id) . "'";
	message_die(GENERAL_ERROR, '', 'Could not obtain quiz category data', __LINE__, __FILE__);
return $db->sql_numrows($result);
