Having some issues with Quiz MOD
Posted: Sun Sep 18, 2005 9:43 am
by wakasm
I am fairly sure I installed everything correctly. I made the changes to the 10 files that I was supposed to... the SQL installation is fine....
But when I go to my admin panel - there is no text at all... just input fields and buttons. This goes for all the options.
I am using the latest version of phpbb 2.0.17
I only have the cash MOD installed
Subsilver
Thanks for the help!
Posted: Sun Sep 18, 2005 10:02 am
It sounds like you haven't edited lang_admin.php
Make sure you made the changes to all of the languages you use
Posted: Mon Sep 19, 2005 12:19 am
by wakasm
I have added this to the language_admin before the //style
Is there something else I might have missed? I will include screenshots in my next post so you can see what is going on....
// Quiz Admin
$lang['qq_submit_text'] = 'Submit';
$lang['spec_quiz'] = 'Special Quiz User?';
$lang['mod_quiz_user'] = 'Quiz Moderator';
$lang['norm_quiz_user'] = 'Normal Quiz User';
$lang['ban_quiz_user'] = 'Banned From Quizzes';
$lang['qq_quiz'] = 'Question';
$lang['qa_quiz'] = 'Answer';
$lang['qfa_quiz'] = 'Fake Answer';
$lang['Admin_quiz_verification_set'] = 'Admin Verification is set to ';
$lang['No_quiz_verify'] = 'No quizzes awaiting validation';
$lang['Rejected_quizzes'] = 'Click to view rejected quizzes';
$lang['Quiz_config_update'] = 'Quiz Configuration Updated';
$lang['Quiz_category_update'] = 'Category added successfully';
$lang['Quiz_ver_1'] = 'Quiz added successfully<br />Click ';
$lang['Quiz_ver_2'] = 'here';
$lang['Quiz_ver_3'] = ' to return to the previous page';
$lang['Quiz_ver_4'] = 'Quiz denied successfully<br />Click ';
$lang['qq'] = 'Choose how many questions you would like per quiz';
$lang['one_qcat'] = 'If you only use one category turn this setting on';
$lang['Yes_quiz'] = 'Yes';
$lang['desco_quiz'] = 'Description';
$lang['setto_quiz'] = 'Setting';
$lang['No_quiz'] = 'No';
$lang['admin_qsubmit'] = 'If you would prefer that only Administrators can submit quizzes, check this to Yes.';
$lang['admin_verify'] = 'If you wish to verify quizzes before they are displayed, check this to Yes.';
$lang['Quiz_cash_ison'] = '<b>Cash Mod Installation</b><br />If you wish to enable cash rewards and deductions and have the Cash Mod installed, check yes on this option';
$lang['qcf'] = 'Which field do you wish the earnings or losses to be made out to?';
$lang['quiz_cost_play'] = 'Select the amount of money it costs to play a quiz';
$lang['quiz_cash_cor'] = 'Select the amount of money the user gets per correct answer';
$lang['cash_quiz_loss'] = 'Select the amount of money the user loses per incorrect answer';
$lang['cash_play_once'] = 'Check this to On, if you wish that users can play each quiz, only one time.';
$lang['quiz_timing'] = 'Select whether you wish time limits to be on or off.';
$lang['guest_cant'] = 'Check to on if you wish to disable guests from from playing quizzes.';
$lang['quiz_word_accept'] = 'Accept';
$lang['quiz_word_reject'] = 'Reject';
$lang['quiz_config_updated'] = 'Quiz configuration updated successfully!';
$lang['subcat_add_ok_quiz'] = 'Subcategory added successfully!';
$lang['quiz_cat_delete_ok'] = 'Category deleted';
$lang['quiz_cat_edit_ok'] = 'Category edited successfully';
$lang['quiz_add_cat_button'] = 'Add Category';
$lang['quiz_sub_add_button'] = 'Add Subcategory';
$lang['quiz_word_subcategories'] = 'Subcategories';
$lang['quiz_word_categories'] = 'Category';
$lang['adm_quiz_word'] = 'Quiz';
$lang['adm_auth_word'] = 'Author';
$lang['adm_rej_word'] = 'Reject';
$lang['adm_acc_word'] = 'Accept';
$lang['adm_min_conf'] = 'Minimum post requirement to play quizzes (0 for none)';
$lang['adm_mod_del_conf'] = 'Allow moderators to edit / delete quizzes';
$lang['adm_no_guest_conf'] = 'Check to on if you wish to disable guests from from playing quizzes.';
$lang['adm_timeonoff_conf'] = 'Select whether you wish time limits to be on or off.';
$lang['adm_survey_prog_conf'] = 'Do you wish the Ultimate Quiz MOD to double as a survey program?';
$lang['adm_timelim_conf'] = 'In whole minutes, choose how long each user has to complete a quiz.';
$lang['adm_choose_desc'] = 'Write a descritption for the category';
$lang['adm_choose_nms'] = 'Choose a name for this category';
$lang['adm_choose_snms'] = 'Choose a name for this subcategory';
$lang['adm_choose_pid'] = 'Select the id of the parent category';
$lang['adm_delete_cat'] = 'Delete this category?<br />This cannot be undone!';
Posted: Mon Sep 19, 2005 12:58 am
by wakasm
Posted: Mon Sep 19, 2005 9:03 am
Do you use Categories Hierachy?
Posted: Mon Sep 19, 2005 5:21 pm
by wakasm
I am not sure what that is, so I am going to say no.
Posted: Thu Sep 22, 2005 2:46 pm
Ok.
It may sound simple, but you have made sure you uploaded the edited lang_admin.php?
Posted: Thu Sep 22, 2005 7:53 pm
by wakasm
Bah, I am so frustrated. I figured it out.
For some reason.... Part of the code was missing. I went through on every line and the missing code caused the whole piece of code not to work.
Not sure how that happend with features like...
"Copy and Paste"
but yeah. Sorry for being stupid.
Great support though!
Posted: Fri Sep 23, 2005 12:00 am
Phew, lucky you got it working.
Posted: Sat Oct 21, 2006 1:41 am
by drakky
my acp doesn't look like that , quiz does not have it's own section , what am i missing please?
Posted: Sat Oct 21, 2006 12:13 pm
It doesn't look like the screenshots, because this post is over a year old (hence the version he is using is over a year old)
