Page 1 of 2
Rabbit 1.3 Special Edition
Posted: Thu Sep 01, 2005 10:00 pm
by String
I've been working for a while on the KM's Rabbit client with the goal
of add some bit...Enjoy it if you like the changes:
(Wow a changeLog !!)
1) MxSock.dll is no more required
2) The .exe now is only about 180k instead of 600k (due to MFC library)
3) Win XP theme is supported now
4) A REAL tab control... like that in FireFox
5) A splitter bar beetwen chat view e user list so you can resize it..
6) Added about box dialog
7) Some bitmap , few changes you will not notice
That's all for now , bye bye
ATTACHMENT REMOVED BY STRING
Posted: Fri Sep 02, 2005 3:34 am
by Layzie Bone
what is this program's purpose?
Posted: Fri Sep 02, 2005 10:20 am
by String
The only purpose i see in it is to sploil a working one...
I have removed i since many people told me they aren't able to get
the tab control working, even though everything is fine on my pc.
But now i know there is something wrong with RT_MANIFEST (XP theme supprt) so it wont work whenever the XP theme is on (out of my pc).
So i decided to remove it, and i APOLOGIZE to the author of the program
and to the others. I wasn't meant to do such a bad thing.
Posted: Fri Sep 02, 2005 11:49 am
Thanks for posting String, I hope you are able to get it working in the near future, it sounds like a very useful program!
Rabbit broken by me
Posted: Fri Sep 02, 2005 10:10 pm
by String
Now i guess i have fixed at least one of my mistakes...
Give it a try (feel like you are a beta tester) e cross you finger !!!
Posted: Sat Sep 03, 2005 2:52 am
"This application has failed to start because MFC71.DLL was not found. Re-installing the application may fix this problem."
Posted: Sat Sep 03, 2005 9:13 pm
by Protoman X
You can get MFC71.DLL from all sorts of programs
RoboMX for example has it.
Rabbit SE2
Posted: Thu Sep 08, 2005 4:00 pm
by String
i'm back...
i've added a bit to the rabbit SE... just look below and find out yourself
what is new ! I hope you will enjoy but this is only a test (yet).
I not sure i will keep working on it.
Attachement deleted
Posted: Fri Sep 09, 2005 12:04 am
Thanks for the update String
Posted: Fri Sep 09, 2005 12:22 am
by Layzie Bone
now that is useful, does it translate what you type into the room into the selected language?
Posted: Fri Sep 09, 2005 10:39 am
by String
Sorry, this is not supported yet, but it's quite easy to do.
Now it only translates the text in the channel...
Posted: Fri Sep 09, 2005 10:43 am
Does it use an online translator or did you build one yourself?
Posted: Fri Sep 09, 2005 6:09 pm
by String
Online Translator...I know it's quite useless but i can't build
i translator myself..
Posted: Sat Sep 10, 2005 2:25 am
That's pretty cool, nice work mate!
Posted: Sat Sep 10, 2005 10:39 pm
by String
Ok.... This is Rabbit SE2...final version
Right click with the mouse on the input box or text box...
