phpBB 2.0.15 Update
phpBB has released 2.0.15, the "summer needs to be hot" release. CricketMX.com has already updated, if your forum is still running 2.0.14, follow the instructions listed below to upgrade. If you run 2.0.13 or lower visit http://www.phpbb.com for more code changes and other upgrade methods.
phpBB 2.0.14 to phpBB 2.0.15 Code Changes
These are the Changes from phpBB 2.0.14 to phpBB 2.0.15 summed up into a little Mod. This might be very helpful if you want to update your Board and have installed a bunch of Mods. Then it's normally easier to apply the Code Changes than to install all Mods again.
When you find a 'AFTER, ADD'-Statement, the Code have to be added after the last line quoted in the 'FIND'-Statement.
When you find a 'BEFORE, ADD'-Statement, the Code have to be added before the first line quoted in the 'FIND'-Statement.
When you find a 'REPLACE WITH'-Statement, the Code quoted in the 'FIND'-Statement have to be replaced completely with the quoted Code in the 'REPLACE WITH'-Statement.
After you have finished this tutorial, you have to upload the install/update_to_latest.php file, execute it and then delete it from your webspace.
  • admin/admin_forums.php
  1. FIND - Line 236
    	if( $mode == "addforum" )
    		list($cat_id) = each($HTTP_POST_VARS['addforum']);
    AFTER, ADD
    		$cat_id = intval($cat_id);
  • admin/admin_smilies.php
  1. FIND - Line 450
    			$smile_code = ( isset($HTTP_POST_VARS['smile_code']) ) ? $HTTP_POST_VARS['smile_code'] : $HTTP_GET_VARS['smile_code'];
    			$smile_url = ( isset($HTTP_POST_VARS['smile_url']) ) ? $HTTP_POST_VARS['smile_url'] : $HTTP_GET_VARS['smile_url'];
    			$smile_emotion = ( isset($HTTP_POST_VARS['smile_emotion']) ) ? $HTTP_POST_VARS['smile_emotion'] : $HTTP_GET_VARS['smile_emotion'];
    AFTER, ADD
    			$smile_code = trim($smile_code);
    			$smile_url = trim($smile_url);
    			$smile_emotion = trim($smile_emotion);
  • admin/pagestart.php
  1. FIND - Line 62
    	redirect("index.$phpEx?sid=" . $userdata['session_id']);
    AFTER, ADD
    if (!$userdata['session_admin'])
    	redirect(append_sid("login.$phpEx?redirect=admin/&admin=1", true));
  • db/postgres7.php
  1. FIND - Line 126
    			$query = preg_replace('#(.*WHERE.*)(username|user_email|ban_email) = \'(.*)\'#ise', "\"\\1LOWER(\\2) = '\" . strtolower('\\3') . \"'\"", $query);
    REPLACE WITH
    //			$query = preg_replace('#(.*WHERE.*)(username|user_email|ban_email) = \'(.*)\'#ise', "\"\\1LOWER(\\2) = '\" . strtolower('\\3') . \"'\"", $query);
  • groupcp.php
  1. FIND - Line 340
    			if ( !($row = $db->sql_fetchrow($result)) )
    REPLACE WITH
    			if ( !($row = $db->sql_fetchrow($result)) || $row['is_auth_mod'] == 0 )
  • includes/bbcode.php
  1. FIND - Line 127
    	global $lang, $bbcode_tpl;
    AFTER, ADD
    	$text = preg_replace('#(script|about|applet|activex|chrome):#is', "\\1:", $text);
  2. FIND - Line 197
    	// [img]image_url_here[/img] code..
    	// This one gets first-passed..
    	$patterns[] = "#\[img:$uid\](.*?)\[/img:$uid\]#si";
    REPLACE WITH
    	$patterns[] = "#\[img:$uid\]([^?].*?)\[/img:$uid\]#i";
  3. FIND - Line 210
    	// [url=xxxx://www.phpbb.com]phpBB[/url] code..
    	$patterns[] = "#\[url=([\w]+?://[^ \"\n\r\t<]*?)\](.*?)\[/url\]#is";
    	$replacements[] = $bbcode_tpl['url3'];
    	// [url=www.phpbb.com]phpBB[/url] code.. (no xxxx:// prefix).
    	$patterns[] = "#\[url=((www|ftp)\.[^ \"\n\r\t<]*?)\](.*?)\[/url\]#is";
    REPLACE WITH
    	$patterns[] = "#\[url=([\w]+?://[^ \"\n\r\t<]*?)\]([^?].*?)\[/url\]#i";
    	$patterns[] = "#\[url=((www|ftp)\.[^ \"\n\r\t<]*?)\]([^?].*?)\[/url\]#i";
  4. FIND - Line 619
    function make_clickable($text)
    AFTER, ADD
    	$text = preg_replace('#(script|about|applet|activex|chrome):#is', "\\1&#058;", $text);
  • includes/sessions.php
  1. FIND - Line 27
    function session_begin($user_id, $user_ip, $page_id, $auto_create = 0, $enable_autologin = 0)
    REPLACE WITH
    function session_begin($user_id, $user_ip, $page_id, $auto_create = 0, $enable_autologin = 0, $admin = 0)
  2. FIND - Line 158
    		SET session_user_id = $user_id, session_start = $current_time, session_time = $current_time, session_page = $page_id, session_logged_in = $login
    		WHERE session_id = '" . $session_id . "'
    			AND session_ip = '$user_ip'";
    	if ( !$db->sql_query($sql) || !$db->sql_affectedrows() )
    		$session_id = md5(uniqid($user_ip));
    		$sql = "INSERT INTO " . SESSIONS_TABLE . "
    			(session_id, session_user_id, session_start, session_time, session_ip, session_page, session_logged_in)
    			VALUES ('$session_id', $user_id, $current_time, $current_time, '$user_ip', $page_id, $login)";
    REPLACE WITH
    		SET session_user_id = $user_id, session_start = $current_time, session_time = $current_time, session_page = $page_id, session_logged_in = $login, session_admin = $admin
    		list($sec, $usec) = explode(' ', microtime());
    		mt_srand((float) $sec + ((float) $usec * 100000));
    		$session_id = md5(uniqid(mt_rand(), true));
    			(session_id, session_user_id, session_start, session_time, session_ip, session_page, session_logged_in, session_admin)
    			VALUES ('$session_id', $user_id, $current_time, $current_time, '$user_ip', $page_id, $login, $admin)";
  3. FIND - Line 180
    	{// ( $userdata['user_session_time'] > $expiry_time && $auto_create ) ? $userdata['user_lastvisit'] : (
    		$last_visit = ( $userdata['user_session_time'] > 0 ) ? $userdata['user_session_time'] : $current_time;
    AFTER, ADD
    		if (!$admin)
  4. FIND - Line 189
    		$userdata['user_lastvisit'] = $last_visit;
    		$sessiondata['autologinid'] = ( $enable_autologin && $sessionmethod == SESSION_METHOD_COOKIE ) ? $auto_login_key : '';
    REPLACE WITH
    		$sessiondata['autologinid'] = (!$admin) ? (( $enable_autologin && $sessionmethod == SESSION_METHOD_COOKIE ) ? $auto_login_key : '') : $sessiondata['autologinid'];
  5. FIND - Line 204
    	$userdata['session_page'] = $page_id;
    	$userdata['session_start'] = $current_time;
    	$userdata['session_time'] = $current_time;
    AFTER, ADD
    	$userdata['session_admin'] = $admin;
  6. FIND - Line 294
    					$sql = "UPDATE " . SESSIONS_TABLE . "
    						SET session_time = $current_time, session_page = $thispage_id
    REPLACE WITH
    					// A little trick to reset session_admin on session re-usage
    					$update_admin = (!defined('IN_ADMIN') && $current_time - $userdata['session_time'] > ($board_config['session_length']+60)) ? ', session_admin = 0' : '';
    						SET session_time = $current_time, session_page = $thispage_id$update_admin
  • includes/smtp.php
  1. FIND - Line 109
    	if( !$socket = fsockopen($board_config['smtp_host'], 25, $errno, $errstr, 20) )
    REPLACE WITH
    	if( !$socket = @fsockopen($board_config['smtp_host'], 25, $errno, $errstr, 20) )
  • includes/usercp_viewprofile.php
  1. FIND - Line 36
    $profiledata = get_userdata($HTTP_GET_VARS[POST_USERS_URL]);
    AFTER, ADD
    if (!$profiledata)
    	message_die(GENERAL_MESSAGE, $lang['No_user_id_specified']);
  • language/lang_english/lang_main.php
  1. FIND - Line 1021
    $lang['An_error_occured'] = 'An Error Occurred';
    $lang['A_critical_error'] = 'A Critical Error Occurred';
    AFTER, ADD
    $lang['Admin_reauthenticate'] = 'To administer the board you must re-authenticate yourself.';
  • login.php
  1. FIND - Line 55
    	if( ( isset($HTTP_POST_VARS['login']) || isset($HTTP_GET_VARS['login']) ) && !$userdata['session_logged_in'] )
    REPLACE WITH
    	if( ( isset($HTTP_POST_VARS['login']) || isset($HTTP_GET_VARS['login']) ) && (!$userdata['session_logged_in'] || isset($HTTP_POST_VARS['admin'])) )
  2. FIND - Line 80
    					$session_id = session_begin($row['user_id'], $user_ip, PAGE_INDEX, FALSE, $autologin);
    REPLACE WITH
    					$admin = (isset($HTTP_POST_VARS['admin'])) ? 1 : 0;
    					$session_id = session_begin($row['user_id'], $user_ip, PAGE_INDEX, FALSE, $autologin, $admin);
  3. FIND - Line 162
    	if( !$userdata['session_logged_in'] )
    REPLACE WITH
    	if( !$userdata['session_logged_in'] || (isset($HTTP_GET_VARS['admin']) && $userdata['session_logged_in'] && $userdata['user_level'] == ADMIN))
  4. FIND - Line 211
    		make_jumpbox('viewforum.'.$phpEx, $forum_id);
    		$template->assign_vars(array(
    			'USERNAME' => $username,
    			'L_ENTER_PASSWORD' => $lang['Enter_password'],
    REPLACE WITH
    		$s_hidden_fields .= (isset($HTTP_GET_VARS['admin'])) ? '<input type="hidden" name="admin" value="1" />' : '';
    			'L_ENTER_PASSWORD' => (isset($HTTP_GET_VARS['admin'])) ? $lang['Admin_reauthenticate'] : $lang['Enter_password'],
  • viewtopic.php
  1. FIND - Line 1110
    		$message = str_replace('\"', '"', substr(@preg_replace('#(\>(((?>([^><]+|(?R)))*)\<))#se', "@preg_replace('#\b(" . $highlight_match . ")\b#i', '<span style=\"color:#" . $theme['fontcolor3'] . "\"><b>\\\\1</b></span>', '\\0')", '>' . $message . '<'), 1, -1));
    REPLACE WITH
    		$message = str_replace('\"', '"', substr(@preg_replace('#(\>(((?>([^><]+|(?R)))*)\<))#se', "@preg_replace('#\b(" . str_replace('\\', '\\\\', $highlight_match) . ")\b#i', '<span style=\"color:#" . $theme['fontcolor3'] . "\"><b>\\\\1</b></span>', '\\0')", '>' . $message . '<'), 1, -1));
  • admin/admin_ug_auth.php
  1. FIND - Line 553
    		message_die(GENERAL_MESSAGE, $message);
    else if ( ( $mode == 'user' && ( isset($HTTP_POST_VARS['username']) || $user_id ) ) || ( $mode == 'group' && $group_id ) )
    BEFORE, ADD
    		$sql = 'SELECT user_id FROM ' . USER_GROUP_TABLE . "
    			WHERE group_id = $group_id";
    		$group_user = array();
    			$group_user[$row['user_id']] = $row['user_id'];
    		$db->sql_freeresult($result);
    		$sql = "SELECT ug.user_id, COUNT(auth_mod) AS is_auth_mod
    			FROM " . AUTH_ACCESS_TABLE . " aa, " . USER_GROUP_TABLE . " ug
    			WHERE ug.user_id IN (" . implode(', ', $group_user) . ")
    				AND aa.group_id = ug.group_id
    				AND aa.auth_mod = 1
    			GROUP BY ug.user_id";
    		if ( !($result = $db->sql_query($sql)) )
    			message_die(GENERAL_ERROR, 'Could not obtain moderator status', '', __LINE__, __FILE__, $sql);
    			if ($row['is_auth_mod'])
    				unset($group_user[$row['user_id']]);
    		if (sizeof($group_user))
    			$sql = "UPDATE " . USERS_TABLE . "
    				SET user_level = " . USER . "
    				WHERE user_id IN (" . implode(', ', $group_user) . ")";
    				message_die(GENERAL_ERROR, 'Could not update user level', '', __LINE__, __FILE__, $sql);
  • includes/usercp_register.php
  1. FIND - Line 414
    			if (strtolower($username) != strtolower($userdata['username']))
    REPLACE WITH
    			if (strtolower($username) != strtolower($userdata['username']) || $mode == 'register')
Make sure you make the following change to retain administrator priviledges when edting certain permissions:
FIND (around line 546)
REPLACE WITH
WHERE user_id IN (" . implode(', ', $group_user) . ") AND user_level = " . MOD;
