2.0.14 Update
As battye has a habit of posting this sort of thing here I thought I'd do it for him, in his absence. (He must be back soon, right?) Anyhoo.... here we go, what follows is adapted from battye's previous posts plus a huge 'code' posting from the official guide (from which I've snipped only a few dozen lines of the leading blurb about who did what, to whom and using what weapon).....
Bug fixes and what have you for versions below phpBB 2.0.14. As usual, if you find any errors, report them in this topic.
If you own a forum, and use 2.0.13 or below, follow the instructions below to update to 2.0.14. Remember you will need to download the upgrade package for the update_to_latest.php file. You upload this to your forum root / install directory (eg forums.com/install) and run. Make sure you apply the code changes too, as this script only updates the database.
## MOD Title: phpBB 2.0.13 to phpBB 2.0.14 Code Changes
## MOD Author: Acyd Burn < N/A > (Meik Sievertsen) N/A
## Before Adding This MOD To Your Forum, You Should Back Up All Files Related To This MOD
#-----[ OPEN ]---------------------------------------------
admin/admin_styles.php
#-----[ FIND ]---------------------------------------------
# Line 78
			include($phpbb_root_path. "templates/" . $install_to . "/theme_info.cfg");
#-----[ REPLACE WITH ]---------------------------------------------
			include($phpbb_root_path. "templates/" . basename($install_to) . "/theme_info.cfg");
# Line 742
			$fp = @fopen($phpbb_root_path . 'templates/' . $template_name . '/theme_info.cfg', 'w');
			$fp = @fopen($phpbb_root_path . 'templates/' . basename($template_name) . '/theme_info.cfg', 'w');
admin/page_header_admin.php
# Line 38
	$useragent = (isset($_SERVER["HTTP_USER_AGENT"]) ) ? $_SERVER["HTTP_USER_AGENT"] : $HTTP_USER_AGENT;
	$useragent = (isset($HTTP_SERVER_VARS['HTTP_USER_AGENT'])) ? $HTTP_SERVER_VARS['HTTP_USER_AGENT'] : getenv('HTTP_USER_AGENT');
admin/page_footer_admin.php
# Line 36
	'PHPBB_VERSION' => '2' . $board_config['version'],
	'PHPBB_VERSION' => ($userdata['user_level'] == ADMIN && $userdata['user_id'] != ANONYMOUS) ? '2' . $board_config['version'] : '',
db/postgres7.php
# Line 125
			$query = preg_replace("/LIMIT ([0-9]+),([ 0-9]+)/", "LIMIT \\2 OFFSET \\1", $query);
#-----[ AFTER, ADD ]---------------------------------------------
			$query = preg_replace('#(.*WHERE.*)(username|user_email|ban_email) = \'(.*)\'#ise', "\"\\1LOWER(\\2) = '\" . strtolower('\\3') . \"'\"", $query);
includes/page_header.php
# Line 38
# Line 469
if (!empty($_SERVER['SERVER_SOFTWARE']) && strstr($_SERVER['SERVER_SOFTWARE'], 'Apache/2'))
if (!empty($HTTP_SERVER_VARS['SERVER_SOFTWARE']) && strstr($HTTP_SERVER_VARS['SERVER_SOFTWARE'], 'Apache/2'))
includes/sessions.php
# Line 53
		$session_id = '';
	$page_id = (int) $page_id;
# Line 92
					// No match; don't login, set as anonymous user
					$login = 0;
					$enable_autologin = 0;
					$user_id = $userdata['user_id'] = ANONYMOUS;
					$sql = 'SELECT * FROM ' . USERS_TABLE . ' WHERE user_id = ' . ANONYMOUS;
					$userdata = $db->sql_fetchrow($result);
					$db->sql_freeresult($result);
# Line 105
				// Autologin is not set. Don't login, set as anonymous user
				$login = 0;
# Line 244
	// Does a session exist?
#-----[ BEFORE, ADD ]---------------------------------------------
	$thispage_id = (int) $thispage_id;
modcp.php
# Line 130
		message_die(GENERAL_MESSAGE, 'Topic_post_not_exist');
	$topic_row = $db->sql_fetchrow($result);
	if (!$topic_row)
# Line 150
		message_die(GENERAL_MESSAGE, 'Forum_not_exist');
	if (!$topic_row)
privmsg.php
# Line 566
	if ( !$board_config['allow_html'] )
		if ( $user_sig != '' && $privmsg['privmsgs_enable_sig'] && $userdata['user_allowhtml'] )
	if ( !$board_config['allow_html'] || !$userdata['user_allowhtml'])
		if ( $user_sig != '')
# Line 1531
		if ( !$html_on )
			if ( $user_sig != '' || !$userdata['user_allowhtml'] )
		if ( !$html_on || !$board_config['allow_html'] || !$userdata['user_allowhtml'] )
			if ( $user_sig != '' )
search.php
# Line 200
				$search_author = str_replace('*', '%', trim($search_author));
				if (preg_match('#^[\*%]+$#', trim($search_author)) || preg_match('#^[^\*]{1,2}$#', str_replace(array('*', '%'), '', trim($search_author))))
					$search_author = '';
# Line 269
				if (preg_match('#^[\*%]+$#', trim($split_search[$i])) || preg_match('#^[^\*]{1,2}$#', str_replace(array('*', '%'), '', trim($split_search[$i]))))
					$split_search[$i] = '';
					continue;
# Line 416
		// Author name search
		if ( $search_author != '' )
viewtopic.php
# Line 1052
		if ( $user_sig != '' && $userdata['user_allowhtml'] )
# Line 1122
			$user_sig = str_replace('\"', '"', substr(preg_replace('#(\>(((?>([^><]+|(?R)))*)\<))#se', "preg_replace(\$orig_word, \$replacement_word, '\\0')", '>' . $user_sig . '<'), 1, -1));
		$message = str_replace('\"', '"', substr(preg_replace('#(\>(((?>([^><]+|(?R)))*)\<))#se', "preg_replace(\$orig_word, \$replacement_word, '\\0')", '>' . $message . '<'), 1, -1));
			$user_sig = str_replace('\"', '"', substr(@preg_replace('#(\>(((?>([^><]+|(?R)))*)\<))#se', "@preg_replace(\$orig_word, \$replacement_word, '\\0')", '>' . $user_sig . '<'), 1, -1));
		$message = str_replace('\"', '"', substr(@preg_replace('#(\>(((?>([^><]+|(?R)))*)\<))#se', "@preg_replace(\$orig_word, \$replacement_word, '\\0')", '>' . $message . '<'), 1, -1));
#-----[ SAVE/CLOSE ALL FILES ]------------------------------------------
# EoM
Thanks for posting that Rat :D
I'll tell you a funny story, while I was away the one thing that worried me every single day was: "I hope a 2.0.14 hasn't been released". Because usually a new release means a security issue has been resolved, thus with me away we wouldn't be patched and we'd be vulnerable to attacks. First thing I noticed when I logged on was this post :lol:
Luckily the security issue was rated non-critical, and nothing happened to the forum. The forum is now running 2.0.14 :)
Welcome back battye, hope you had a good vacation.
I did, I had a fantastic time :)
Glad you found the post useful. Welcome back, it's nice to have you 'home'.
[quote="battye"while I was away the one thing that worried me every single day was: "I hope a 2.0.14 hasn't been released".[/quote]
and they thought i was mad when i took a quick trip home to fix my connection when it went down today (during a 15 minute break between lessons - no, there aren't any speed cameras on the way home, luckily :-D)
