EnumWindows
This program does a few handy little things. It lets you show, hide, minimize and maximize windows. That includes both visible and invisible windows. In fact... you'd probably be surprised how many windows there are open that you can't see ;)
It's simple to use. Click the EnumWindows button to list all the windows. Right click a window in the list and play around with it. If you have the Visible/Invisible box checked it will display the visible windows. If unchecked it will display all the invisible windows.
As a warning, in general it's a good idea to not mess with the invisible windows unless you're trying to unhide a window that you've hidden. If you're playing around and say maxmize a window you could end up having a fullscreen blank window that you have no way of minimizing and be force to reboot to fix it (believe me I know)
EnumWindows.exe
EnumWindows 1.00a by Ouka
(40 KiB) Downloaded 239 times
EnumWindows Screenshot
EnumWindows 1.00a.JPG (32.2 KiB) Viewed 2481 times
if you get a pogram thta lists them all (as well as child windows) you can do some funny stuff to your task bar :-D
not sure if there is a program for that, but doing it manually i have made the task bar do some really strange things
ok, so i got a little bored... lol
Right click and select "show unnamed" then have a look at the ones under the Shell_TrayWnd one... fun with the task bar :-D
WindowHider.cpp
The source... not that there's anything special in there - someone might find it useful for trying to use Tree View controls or something though.
(5.36 KiB) Downloaded 247 times
WindowHider.exe
Window Hider
(32 KiB) Downloaded 255 times
