Badlang
Lunatic_UK1958
I seem to be having no end of problems with the BadLang in Metis. It gives 2 warnings, one straight after the other, then promptly kicks the offender!
I have search the forums and see that this was apparantly fixed in an earlier version. I am running v1.51 RoboMx, v2.60 of Metis & v4.50b.20050227-0730 of Ouka.
I have the following line in my MXC.xml:
<include file="badlang.xml"/>
<BadwordPenalty enable="1" exclude="1"/>
<AutoKick enable="0" warnings="2"/>
<BadLangWarning value="Please go easy on the swearing, %NAME%, thankyou."/>
<BadLangPreKick value="You have been warned, %NAME%. Too much swearing is not permitted. You are the weakest link, goodbye."/>
<RedirectCommand value="/kick %RAWNAME%"/>
The 'lookup' on the offending word in the badlang.xml, works perfect, but it just warns and kicks.
Any ideas?
I beleive the answer you seek is to be found in the Metis.chm file in the Metis folder in Program Files .
I,m actually suprised it kicks as you have that function turned off in your script
Heres an extract from the help file
Autokick feature of Badword Penalty
Enables or disables the autokick feature of the Badword Penalty. If enabled and a user exceeds his maximum number of warnings he gets kicked or redirected from the channel (RCMS required)
Element name: Autokick
Attribute 1: enable (1 is enabled, 0 is disabled)
Attribute 2: warnings (number of warnings before a user gets kicked, greater or equal to 1)
Default 1: 1
Default 2: 3
<AutoKick enable="1" warnings="3"/>
Badword Penalty
Enables or disables the Badword Penalty.
Element name: BadwordPenalty
Attribute 2: exclude (Exclude users and usergroups stated in the badword from penalty, 1 is yes, 0 is no)
Default 1: 1
Default 2: 1
I think what might be the problem is the delay between its own output .
Botoutput Flood protection
Sets the time in milliseconds, Metis waits between posting its reponses. This is to avoid Metis Spamming the channel with message too fast.
Element name: BotFloodControl
Attribute: value (greater or equal to zero)
Default: 2000
<BotFloodControl value="2000"/>
