Get the release from hereRoboMX 1.51Code: Select all
* Fixed bug in emoticons manager causing similar emoticons being displayed incorrectly. Example: If you had an emoticon :-)) and :-) RoboMX mapped :-)) to :-) +)
http://mxcontrol.sourceforge.net/module ... it&lid=141
And the source code from here
http://mxcontrol.sourceforge.net/module ... it&lid=142
Also theres an inportant update to the Winamp plugin
http://mxcontrol.sourceforge.net/module ... it&lid=143Install AFTER you installed RoboMX 1.51
This Update fixes a crashbug in the Extended Winamp Report Plugin when you clear the playlist in Winamp
Cheers Bender And thanx to all the folks at MxControl
