BendMX 3.9.9 Alpha 1
Jimmys444
  • BendMX 3.9.9 Alpha 1
    Yes here it is back: MXControls most popular, most loved and most hated Tool since the beginning of this project: BendMX!! This version has been adjusted to work with WinMX 3.53 and later. PLEASE NOTE: THis is an Alpha-Test version and not all features are working yet. I am not sure if I finish this, it has been lying on my harddisk for a while now and because of all the requests I get I decided to release what I have done so far. Following is a list of features of the new BendMX, bold entries are new to BendMX 3.9.9, italic entries are disabled in this version of BendMX but will be available again in later versions
    - IP Client support (users of Rabbit/MCS/RoboMX/roSe will know what this is)
    - Advanced userlist menu
    - Soundeffects
    - MXSound plugin
    - HTML logging plugin
    - Lagtest- and OnEnter plugins
    - Autoload correct commandset for each server into the commandscroller
    - Textricks, colored Texttricks
    - System-, Download and Serverstatistics
    - Wordfilters
    - Simple built-in Bot
    - much more
    Features that have been removed and will not come back due to the different design of WinMX 3.53 and later:
    - Advanced chatformatting
    Download:
    BendMX 3.9.9 Alpha 1 Installer
    BendMX 3.9.9 Alpha 1 Sourcecode
EnJoY :wink: 8) :D
I know there will be a lot of happy people now :)
Thanks for the update Jimmys :)
Jimmys444
EnJoY :wink: 8) :D
Jimmys444
All links is updated and is work! :wink: 8)
I have installed BendMX for 3.53 / 3.54 and it works perfectly. Thanks Bender and Jimmys! :D :D :D 8)
And I'll be adding it very soon. :)
Jimmys444
Is have only one problem! and i bilive bender goes soon to fix it!
Check this topic: MXControl - WinMX crashes in /all command :wink: 8)
Jimmys444 wrote:Autoload correct commandset for each server into the commandscroller
Uhuh. Well I just installed this and instead of a command set, I have one command..... "Example Command" which is, frankly, about as much use as a chocolate teapot. :/
Suggestions anyone?
Forget it. Fixed it by reinstalling. Must have had a duff download. :/
Jimmys444
Rat wrote:Forget it. Fixed it by reinstalling. Must have had a duff download. :/
np :wink: 8) :D
StorbinC
Nice Guy
Nice Guy
Location: Sometimes here & sometimes there but never near
COOL I GOT BENDMX BACK!!!
welcome home old freind, you have been missed since the days of 3.31
sometime u feel like a nut
sometimes you don't
bluetit
just installed new version of winmx and bend but how do you change the fonts in chat. I have changed the fonts in Transfer window but cant remember how to change them in the channel thanx all
JASON
BendMX doesn't have the text formatting options, Would've thought a good luck would've indicated that... But to change WinMX fonts is easy go into settings>appearance>change large font... btw If I were you I'd be sure to always check the bold option for your font too ;)
