Get it here (Exeemlite 0.18 )
http://thefreehost.org/exeemlite018.exe
Read about it here
http://www.slyck.com/news.php?story=641
It looks like Swarm Networks makes all beta clients log into a central server to get a node list. It seems they patched thier server and are blocking exlite nodes from loging in to its central server, so much for decentralisation .
They may set a dangerous precedent if they can show they can actually controll the network in this way if authetication is still used in the final version .
Try this registry hack from the xlite FAQ
Ill post it as text so you can check it out before you run it .
Copy and paste it save it as nodes.reg and run the script
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\exeem]
"key"=dword:06ea9260
"upload_rate"=dword:00000000
"download_rate"=dword:00000000
"confirm_exit"=dword:00000001
"open_transfers"=""
"win_x"=dword:0000001e
"win_y"=dword:0000001e
"win_width"=dword:000002f0
"win_height"=dword:00000199
"active_tab"=dword:00000002
"num_users"=dword:0000013"
"username"="eXlite"
"num_files"=dword:000004d3
"amount_shared"=dword:0005829a
"link_win_x"=dword:00000032
"link_win_y"=dword:00000064
"link_win_width"=dword:00000154
"nodes"="0 147.229.187.143 4000 2005 01 21 6 43 0 24.43.186.225 4000 2005 01 21 6 43 0 67.181.105.6 4000 2005 01 21 6 43 0 200.222.117.68 4000 2005 01 21 6 43 0 203.218.224.125 4000 2005 01 21 6 43 0 203.198.111.201 4000 2005 01 21 6 43 1 68.198.147.13 8000 2005 01 21 6 43 1 12.223.209.63 4000 2005 01 21 6 43 1 219.79.122.206 4000 2005 01 21 6 43 1 222.166.182.89 4000 2005 01 21 6 43 1
81.155.241.250 4000 2005 01 21 6 43 1 203.218.1.13 4000 2005 01 21 6 43 2 65.24.182.171 4000 2005 01 21 6 43 2 218.165.113.172 4011 2005 01 21 6 43 2 128.173.13.231 49201 2005 01 21 6 43 2 212.30.6.228 4000 2005 01 21 6 43"
"segments"="1 0 0"
"serial"="" Code: Select all
"username"="eXlite"
"nodes"="0 147.229.187.143 4000 2005 01 21 6 43 0 24.43.186.225 4000 2005 01 21 6 43 0 67.181.105.6 4000 2005 01 21 6 43 0 200.222.117.68 4000 2005 01 21 6 43 0 203.218.224.125 4000 2005 01 21 6 43 0 203.198.111.201 4000 2005 01 21 6 43 1 68.198.147.13 8000 2005 01 21 6 43 1 12.223.209.63 4000 2005 01 21 6 43 1 219.79.122.206 4000 2005 01 21 6 43 1 222.166.182.89 4000 2005 01 21 6 43 1 81.155.241.250 4000 2005 01 21 6 43 1 203.218.1.13 4000 2005 01 21 6 43 2 65.24.182.171 4000 2005 01 21 6 43 2 218.165.113.172 4011 2005 01 21 6 43 2 128.173.13.231 49201 2005 01 21 6 43 2 212.30.6.228 4000 2005 01 21 6 43"
"segments"="1 0 0"
"serial"=""Thanx to Aussie Mat and Fusen for these postsI made the node.reg file I'm hosting for irc channel smaller, this just as someone said before will manually add a list of nodes for you to connect to the network with as like the above user said the logon part of the network is centralized but after that its stay on till there are no users left
