Firefox / Netscape Users READ THIS!
By xconspirisist of http://www.technowax.net:
xconspirisist wrote:1. Type "about:config" into the address bar and hit return. Scroll down and look for the following entries:
network.http.pipelining
network.http.proxy.pipelining
network.http.pipelining.maxrequests
Normally the browser will make one request to a web page at a time. When you enable pipelining it will make several at once, which really speeds up page loading.
2. Alter the entries as follows:
Set "network.http.pipelining" to "true"
Set "network.http.proxy.pipelining" to "true"
Set "network.http.pipelining.maxrequests" to some number like 30. This means it will make 30 requests at once.
3. Lastly right-click anywhere and select New-> Integer. Name it "nglayout.initialpaint.delay" and set its value to "0". This value is the amount of time the browser waits before it acts on information it recieves.
If you're using a broadband connection you'll load pages 2-3 times faster now.
And it works, dramatically increasing the loading time. Waiting to see some side-effects though.
Probably not a good idea to use this if you have 56k, it might max out your modem.. it remains to be seen if it can cause any damage yet :)
Red XIII
Sultan Ruler Of The Poles!
Do you want me to test it with my road runner? :D
I got my friend Half Pint to test it and he says it wont work properly , so its a thumbs down it seems :(
Works fine for me still
I've applied those changes but I don't see any difference to be honest.
Freggle
Same here...
