Need help with a phpBB2 MOD
You mentioned earlier about the customs titles MOD. Can you please post the contents of your viewtopic.php file (in code tags) and I will have a look and make sure there is no conflict.
* viewtopic.php
* begin : Saturday, Feb 13, 2001
* copyright : (C) 2001 The phpBB Group
* email : support@phpbb.com
* $Id: viewtopic.php 6772 2006-12-16 13:11:28Z acydburn $
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
$phpbb_root_path = './';
include($phpbb_root_path . 'includes/bbcode.'.$phpEx);
// Start initial var setup
$topic_id = $post_id = 0;
if ( isset($HTTP_GET_VARS[POST_TOPIC_URL]) )
$topic_id = intval($HTTP_GET_VARS[POST_TOPIC_URL]);
else if ( isset($HTTP_GET_VARS['topic']) )
$topic_id = intval($HTTP_GET_VARS['topic']);
if ( isset($HTTP_GET_VARS[POST_POST_URL]))
$post_id = intval($HTTP_GET_VARS[POST_POST_URL]);
$start = ( isset($HTTP_GET_VARS['start']) ) ? intval($HTTP_GET_VARS['start']) : 0;
$start = ($start < 0) ? 0 : $start;
if (!$topic_id && !$post_id)
message_die(GENERAL_MESSAGE, 'Topic_post_not_exist');
// Find topic id if user requested a newer
// or older topic
if ( isset($HTTP_GET_VARS['view']) && empty($HTTP_GET_VARS[POST_POST_URL]) )
if ( $HTTP_GET_VARS['view'] == 'newest' )
if ( isset($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_sid']) || isset($HTTP_GET_VARS['sid']) )
$session_id = isset($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_sid']) ? $HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_sid'] : $HTTP_GET_VARS['sid'];
if (!preg_match('/^[A-Za-z0-9]*$/', $session_id))
$session_id = '';
if ( $session_id )
$sql = "SELECT p.post_id
FROM " . POSTS_TABLE . " p, " . SESSIONS_TABLE . " s, " . USERS_TABLE . " u
WHERE s.session_id = '$session_id'
AND u.user_id = s.session_user_id
AND p.topic_id = $topic_id
AND p.post_time >= u.user_lastvisit
ORDER BY p.post_time ASC
LIMIT 1";
if ( !($result = $db->sql_query($sql)) )
message_die(GENERAL_ERROR, 'Could not obtain newer/older topic information', '', __LINE__, __FILE__, $sql);
if ( !($row = $db->sql_fetchrow($result)) )
message_die(GENERAL_MESSAGE, 'No_new_posts_last_visit');
$post_id = $row['post_id'];
if (isset($HTTP_GET_VARS['sid']))
redirect("viewtopic.$phpEx?sid=$session_id&" . POST_POST_URL . "=$post_id#$post_id");
redirect("viewtopic.$phpEx?" . POST_POST_URL . "=$post_id#$post_id");
redirect(append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id", true));
else if ( $HTTP_GET_VARS['view'] == 'next' || $HTTP_GET_VARS['view'] == 'previous' )
$sql_condition = ( $HTTP_GET_VARS['view'] == 'next' ) ? '>' : '<';
$sql_ordering = ( $HTTP_GET_VARS['view'] == 'next' ) ? 'ASC' : 'DESC';
$sql = "SELECT t.topic_id
FROM " . TOPICS_TABLE . " t, " . TOPICS_TABLE . " t2
WHERE
t2.topic_id = $topic_id
AND t.forum_id = t2.forum_id
AND t.topic_moved_id = 0
AND t.topic_last_post_id $sql_condition t2.topic_last_post_id
ORDER BY t.topic_last_post_id $sql_ordering
LIMIT 1";
message_die(GENERAL_ERROR, "Could not obtain newer/older topic information", '', __LINE__, __FILE__, $sql);
if ( $row = $db->sql_fetchrow($result) )
$topic_id = intval($row['topic_id']);
$message = ( $HTTP_GET_VARS['view'] == 'next' ) ? 'No_newer_topics' : 'No_older_topics';
message_die(GENERAL_MESSAGE, $message);
// This rather complex gaggle of code handles querying for topics but
// also allows for direct linking to a post (and the calculation of which
// page the post is on and the correct display of viewtopic)
$join_sql_table = (!$post_id) ? '' : ", " . POSTS_TABLE . " p, " . POSTS_TABLE . " p2 ";
$join_sql = (!$post_id) ? "t.topic_id = $topic_id" : "p.post_id = $post_id AND t.topic_id = p.topic_id AND p2.topic_id = p.topic_id AND p2.post_id <= $post_id";
$count_sql = (!$post_id) ? '' : ", COUNT(p2.post_id) AS prev_posts";
$order_sql = (!$post_id) ? '' : "GROUP BY p.post_id, t.topic_id, t.topic_title, t.topic_status, t.topic_replies, t.topic_time, t.topic_type, t.topic_vote, t.topic_last_post_id, f.forum_name, f.forum_status, f.forum_id, f.auth_view, f.auth_read, f.auth_post, f.auth_reply, f.auth_edit, f.auth_delete, f.auth_sticky, f.auth_announce, f.auth_pollcreate, f.auth_vote, f.auth_attachments ORDER BY p.post_id ASC";
$sql = "SELECT t.topic_id, t.topic_title, t.topic_status, t.topic_replies, t.topic_time, t.topic_type, t.topic_vote, t.topic_last_post_id, f.forum_name, f.forum_status, f.forum_id, f.auth_view, f.auth_read, f.auth_post, f.auth_reply, f.auth_edit, f.auth_delete, f.auth_sticky, f.auth_announce, f.auth_pollcreate, f.auth_vote, f.auth_attachments" . $count_sql . "
FROM " . TOPICS_TABLE . " t, " . FORUMS_TABLE . " f" . $join_sql_table . "
WHERE $join_sql
AND f.forum_id = t.forum_id
$order_sql";
message_die(GENERAL_ERROR, "Could not obtain topic information", '', __LINE__, __FILE__, $sql);
if ( !($forum_topic_data = $db->sql_fetchrow($result)) )
$forum_id = intval($forum_topic_data['forum_id']);
$userdata = session_pagestart($user_ip, $forum_id);
init_userprefs($userdata);
// End session management
// Start auth check
$is_auth = array();
$is_auth = auth(AUTH_ALL, $forum_id, $userdata, $forum_topic_data);
if( !$is_auth['auth_view'] || !$is_auth['auth_read'] )
if ( !$userdata['session_logged_in'] )
$redirect = ($post_id) ? POST_POST_URL . "=$post_id" : POST_TOPIC_URL . "=$topic_id";
$redirect .= ($start) ? "&start=$start" : '';
redirect(append_sid("login.$phpEx?redirect=viewtopic.$phpEx&$redirect", true));
$message = ( !$is_auth['auth_view'] ) ? $lang['Topic_post_not_exist'] : sprintf($lang['Sorry_auth_read'], $is_auth['auth_read_type']);
// End auth check
$forum_name = $forum_topic_data['forum_name'];
$topic_title = $forum_topic_data['topic_title'];
$topic_id = intval($forum_topic_data['topic_id']);
$topic_time = $forum_topic_data['topic_time'];
if ($post_id)
$start = floor(($forum_topic_data['prev_posts'] - 1) / intval($board_config['posts_per_page'])) * intval($board_config['posts_per_page']);
// Is user watching this thread?
if( $userdata['session_logged_in'] )
$can_watch_topic = TRUE;
$sql = "SELECT notify_status
FROM " . TOPICS_WATCH_TABLE . "
WHERE topic_id = $topic_id
AND user_id = " . $userdata['user_id'];
message_die(GENERAL_ERROR, "Could not obtain topic watch information", '', __LINE__, __FILE__, $sql);
if ( isset($HTTP_GET_VARS['unwatch']) )
if ( $HTTP_GET_VARS['unwatch'] == 'topic' )
$is_watching_topic = 0;
$sql_priority = (SQL_LAYER == "mysql") ? "LOW_PRIORITY" : '';
$sql = "DELETE $sql_priority FROM " . TOPICS_WATCH_TABLE . "
message_die(GENERAL_ERROR, "Could not delete topic watch information", '', __LINE__, __FILE__, $sql);
$template->assign_vars(array(
'META' => '<meta http-equiv="refresh" content="3;url=' . append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&start=$start") . '">')
$message = $lang['No_longer_watching'] . '<br /><br />' . sprintf($lang['Click_return_topic'], '<a href="' . append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&start=$start") . '">', '</a>');
$is_watching_topic = TRUE;
if ( $row['notify_status'] )
$sql = "UPDATE $sql_priority " . TOPICS_WATCH_TABLE . "
SET notify_status = 0
message_die(GENERAL_ERROR, "Could not update topic watch information", '', __LINE__, __FILE__, $sql);
if ( isset($HTTP_GET_VARS['watch']) )
if ( $HTTP_GET_VARS['watch'] == 'topic' )
$sql = "INSERT $sql_priority INTO " . TOPICS_WATCH_TABLE . " (user_id, topic_id, notify_status)
VALUES (" . $userdata['user_id'] . ", $topic_id, 0)";
message_die(GENERAL_ERROR, "Could not insert topic watch information", '', __LINE__, __FILE__, $sql);
$message = $lang['You_are_watching'] . '<br /><br />' . sprintf($lang['Click_return_topic'], '<a href="' . append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&start=$start") . '">', '</a>');
redirect(append_sid("login.$phpEx?redirect=viewtopic.$phpEx&" . POST_TOPIC_URL . "=$topic_id&unwatch=topic", true));
$can_watch_topic = 0;
// Generate a 'Show posts in previous x days' select box. If the postdays var is POSTed
// then get it's value, find the number of topics with dates newer than it (to properly
// handle pagination) and alter the main query
$previous_days = array(0, 1, 7, 14, 30, 90, 180, 364);
$previous_days_text = array($lang['All_Posts'], $lang['1_Day'], $lang['7_Days'], $lang['2_Weeks'], $lang['1_Month'], $lang['3_Months'], $lang['6_Months'], $lang['1_Year']);
if( !empty($HTTP_POST_VARS['postdays']) || !empty($HTTP_GET_VARS['postdays']) )
$post_days = ( !empty($HTTP_POST_VARS['postdays']) ) ? intval($HTTP_POST_VARS['postdays']) : intval($HTTP_GET_VARS['postdays']);
$min_post_time = time() - (intval($post_days) * 86400);
$sql = "SELECT COUNT(p.post_id) AS num_posts
FROM " . TOPICS_TABLE . " t, " . POSTS_TABLE . " p
WHERE t.topic_id = $topic_id
AND p.topic_id = t.topic_id
AND p.post_time >= $min_post_time";
message_die(GENERAL_ERROR, "Could not obtain limited topics count information", '', __LINE__, __FILE__, $sql);
$total_replies = ( $row = $db->sql_fetchrow($result) ) ? intval($row['num_posts']) : 0;
$limit_posts_time = "AND p.post_time >= $min_post_time ";
if ( !empty($HTTP_POST_VARS['postdays']))
$start = 0;
$total_replies = intval($forum_topic_data['topic_replies']) + 1;
$limit_posts_time = '';
$post_days = 0;
$select_post_days = '<select name="postdays">';
for($i = 0; $i < count($previous_days); $i++)
$selected = ($post_days == $previous_days[$i]) ? ' selected="selected"' : '';
$select_post_days .= '<option value="' . $previous_days[$i] . '"' . $selected . '>' . $previous_days_text[$i] . '</option>';
$select_post_days .= '</select>';
// Decide how to order the post display
if ( !empty($HTTP_POST_VARS['postorder']) || !empty($HTTP_GET_VARS['postorder']) )
$post_order = (!empty($HTTP_POST_VARS['postorder'])) ? htmlspecialchars($HTTP_POST_VARS['postorder']) : htmlspecialchars($HTTP_GET_VARS['postorder']);
$post_time_order = ($post_order == "asc") ? "ASC" : "DESC";
$post_order = 'asc';
$post_time_order = 'ASC';
$select_post_order = '<select name="postorder">';
if ( $post_time_order == 'ASC' )
$select_post_order .= '<option value="asc" selected="selected">' . $lang['Oldest_First'] . '</option><option value="desc">' . $lang['Newest_First'] . '</option>';
$select_post_order .= '<option value="asc">' . $lang['Oldest_First'] . '</option><option value="desc" selected="selected">' . $lang['Newest_First'] . '</option>';
$select_post_order .= '</select>';
// Go ahead and pull all data for this topic
$sql = "SELECT u.username, u.user_id, u.user_posts, u.user_custom_title, u.user_from, u.user_website, u.user_email, u.user_icq, u.user_aim, u.user_yim, u.user_regdate, u.user_msnm, u.user_viewemail, u.user_rank, u.user_sig, u.user_sig_bbcode_uid, u.user_avatar, u.user_avatar_type, u.user_allowavatar, u.user_allowsmile, p.*, pt.post_text, pt.post_subject, pt.bbcode_uid
FROM " . POSTS_TABLE . " p, " . USERS_TABLE . " u, " . POSTS_TEXT_TABLE . " pt
WHERE p.topic_id = $topic_id
$limit_posts_time
AND pt.post_id = p.post_id
AND u.user_id = p.poster_id
ORDER BY p.post_time $post_time_order
LIMIT $start, ".$board_config['posts_per_page'];
message_die(GENERAL_ERROR, "Could not obtain post/user information.", '', __LINE__, __FILE__, $sql);
$postrow = array();
if ($row = $db->sql_fetchrow($result))
do
$postrow[] = $row;
while ($row = $db->sql_fetchrow($result));
$db->sql_freeresult($result);
$total_posts = count($postrow);
include($phpbb_root_path . 'includes/functions_admin.' . $phpEx);
sync('topic', $topic_id);
message_die(GENERAL_MESSAGE, $lang['No_posts_topic']);
$resync = FALSE;
if ($forum_topic_data['topic_replies'] + 1 < $start + count($postrow))
$resync = TRUE;
elseif ($start + $board_config['posts_per_page'] > $forum_topic_data['topic_replies'])
$row_id = intval($forum_topic_data['topic_replies']) % intval($board_config['posts_per_page']);
if ($postrow[$row_id]['post_id'] != $forum_topic_data['topic_last_post_id'] || $start + count($postrow) < $forum_topic_data['topic_replies'])
$resync = TRUE;
elseif (count($postrow) < $board_config['posts_per_page'])
$resync = TRUE;
if ($resync)
$result = $db->sql_query('SELECT COUNT(post_id) AS total FROM ' . POSTS_TABLE . ' WHERE topic_id = ' . $topic_id);
$total_replies = $row['total'];
$sql = "SELECT *
FROM " . RANKS_TABLE . "
ORDER BY rank_special, rank_min";
message_die(GENERAL_ERROR, "Could not obtain ranks information.", '', __LINE__, __FILE__, $sql);
$ranksrow = array();
while ( $row = $db->sql_fetchrow($result) )
$ranksrow[] = $row;
// Define censored word matches
$orig_word = array();
$replacement_word = array();
obtain_word_list($orig_word, $replacement_word);
// Censor topic title
if ( count($orig_word) )
$topic_title = preg_replace($orig_word, $replacement_word, $topic_title);
// Was a highlight request part of the URI?
$highlight_match = $highlight = '';
if (isset($HTTP_GET_VARS['highlight']))
// Split words and phrases
$words = explode(' ', trim(htmlspecialchars($HTTP_GET_VARS['highlight'])));
for($i = 0; $i < sizeof($words); $i++)
if (trim($words[$i]) != '')
$highlight_match .= (($highlight_match != '') ? '|' : '') . str_replace('*', '\w*', preg_quote($words[$i], '#'));
unset($words);
$highlight = urlencode($HTTP_GET_VARS['highlight']);
$highlight_match = phpbb_rtrim($highlight_match, "\\");
// Post, reply and other URL generation for
// templating vars
$new_topic_url = append_sid("posting.$phpEx?mode=newtopic&" . POST_FORUM_URL . "=$forum_id");
$reply_topic_url = append_sid("posting.$phpEx?mode=reply&" . POST_TOPIC_URL . "=$topic_id");
$view_forum_url = append_sid("viewforum.$phpEx?" . POST_FORUM_URL . "=$forum_id");
$view_prev_topic_url = append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&view=previous");
$view_next_topic_url = append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&view=next");
// Mozilla navigation bar
$nav_links['prev'] = array(
'url' => $view_prev_topic_url,
'title' => $lang['View_previous_topic']
$nav_links['next'] = array(
'url' => $view_next_topic_url,
'title' => $lang['View_next_topic']
$nav_links['up'] = array(
'url' => $view_forum_url,
'title' => $forum_name
$reply_img = ( $forum_topic_data['forum_status'] == FORUM_LOCKED || $forum_topic_data['topic_status'] == TOPIC_LOCKED ) ? $images['reply_locked'] : $images['reply_new'];
$reply_alt = ( $forum_topic_data['forum_status'] == FORUM_LOCKED || $forum_topic_data['topic_status'] == TOPIC_LOCKED ) ? $lang['Topic_locked'] : $lang['Reply_to_topic'];
$post_img = ( $forum_topic_data['forum_status'] == FORUM_LOCKED ) ? $images['post_locked'] : $images['post_new'];
$post_alt = ( $forum_topic_data['forum_status'] == FORUM_LOCKED ) ? $lang['Forum_locked'] : $lang['Post_new_topic'];
// Set a cookie for this topic
if ( $userdata['session_logged_in'] )
$tracking_topics = ( isset($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_t']) ) ? unserialize($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_t']) : array();
$tracking_forums = ( isset($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_f']) ) ? unserialize($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_f']) : array();
if ( !empty($tracking_topics[$topic_id]) && !empty($tracking_forums[$forum_id]) )
$topic_last_read = ( $tracking_topics[$topic_id] > $tracking_forums[$forum_id] ) ? $tracking_topics[$topic_id] : $tracking_forums[$forum_id];
else if ( !empty($tracking_topics[$topic_id]) || !empty($tracking_forums[$forum_id]) )
$topic_last_read = ( !empty($tracking_topics[$topic_id]) ) ? $tracking_topics[$topic_id] : $tracking_forums[$forum_id];
$topic_last_read = $userdata['user_lastvisit'];
if ( count($tracking_topics) >= 150 && empty($tracking_topics[$topic_id]) )
asort($tracking_topics);
unset($tracking_topics[key($tracking_topics)]);
$tracking_topics[$topic_id] = time();
setcookie($board_config['cookie_name'] . '_t', serialize($tracking_topics), 0, $board_config['cookie_path'], $board_config['cookie_domain'], $board_config['cookie_secure']);
// Load templates
'body' => 'viewtopic_body.tpl')
make_jumpbox('viewforum.'.$phpEx, $forum_id);
// Output page header
$page_title = $lang['View_topic'] .' - ' . $topic_title;
include($phpbb_root_path . 'includes/page_header.'.$phpEx);
// User authorisation levels output
$s_auth_can = ( ( $is_auth['auth_post'] ) ? $lang['Rules_post_can'] : $lang['Rules_post_cannot'] ) . '<br />';
$s_auth_can .= ( ( $is_auth['auth_reply'] ) ? $lang['Rules_reply_can'] : $lang['Rules_reply_cannot'] ) . '<br />';
$s_auth_can .= ( ( $is_auth['auth_edit'] ) ? $lang['Rules_edit_can'] : $lang['Rules_edit_cannot'] ) . '<br />';
$s_auth_can .= ( ( $is_auth['auth_delete'] ) ? $lang['Rules_delete_can'] : $lang['Rules_delete_cannot'] ) . '<br />';
$s_auth_can .= ( ( $is_auth['auth_vote'] ) ? $lang['Rules_vote_can'] : $lang['Rules_vote_cannot'] ) . '<br />';
$topic_mod = '';
if ( $is_auth['auth_mod'] )
$s_auth_can .= sprintf($lang['Rules_moderate'], "<a href=\"modcp.$phpEx?" . POST_FORUM_URL . "=$forum_id&sid=" . $userdata['session_id'] . '">', '</a>');
$topic_mod .= "<a href=\"modcp.$phpEx?" . POST_TOPIC_URL . "=$topic_id&mode=delete&sid=" . $userdata['session_id'] . '"><img src="' . $images['topic_mod_delete'] . '" alt="' . $lang['Delete_topic'] . '" title="' . $lang['Delete_topic'] . '" border="0" /></a> ';
$topic_mod .= "<a href=\"modcp.$phpEx?" . POST_TOPIC_URL . "=$topic_id&mode=move&sid=" . $userdata['session_id'] . '"><img src="' . $images['topic_mod_move'] . '" alt="' . $lang['Move_topic'] . '" title="' . $lang['Move_topic'] . '" border="0" /></a> ';
$topic_mod .= ( $forum_topic_data['topic_status'] == TOPIC_UNLOCKED ) ? "<a href=\"modcp.$phpEx?" . POST_TOPIC_URL . "=$topic_id&mode=lock&sid=" . $userdata['session_id'] . '"><img src="' . $images['topic_mod_lock'] . '" alt="' . $lang['Lock_topic'] . '" title="' . $lang['Lock_topic'] . '" border="0" /></a> ' : "<a href=\"modcp.$phpEx?" . POST_TOPIC_URL . "=$topic_id&mode=unlock&sid=" . $userdata['session_id'] . '"><img src="' . $images['topic_mod_unlock'] . '" alt="' . $lang['Unlock_topic'] . '" title="' . $lang['Unlock_topic'] . '" border="0" /></a> ';
$topic_mod .= "<a href=\"modcp.$phpEx?" . POST_TOPIC_URL . "=$topic_id&mode=split&sid=" . $userdata['session_id'] . '"><img src="' . $images['topic_mod_split'] . '" alt="' . $lang['Split_topic'] . '" title="' . $lang['Split_topic'] . '" border="0" /></a> ';
// Topic watch information
$s_watching_topic = '';
if ( $can_watch_topic )
if ( $is_watching_topic )
$s_watching_topic = "<a href=\"viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&unwatch=topic&start=$start&sid=" . $userdata['session_id'] . '">' . $lang['Stop_watching_topic'] . '</a>';
$s_watching_topic_img = ( isset($images['topic_un_watch']) ) ? "<a href=\"viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&unwatch=topic&start=$start&sid=" . $userdata['session_id'] . '"><img src="' . $images['topic_un_watch'] . '" alt="' . $lang['Stop_watching_topic'] . '" title="' . $lang['Stop_watching_topic'] . '" border="0"></a>' : '';
$s_watching_topic = "<a href=\"viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&watch=topic&start=$start&sid=" . $userdata['session_id'] . '">' . $lang['Start_watching_topic'] . '</a>';
$s_watching_topic_img = ( isset($images['Topic_watch']) ) ? "<a href=\"viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&watch=topic&start=$start&sid=" . $userdata['session_id'] . '"><img src="' . $images['Topic_watch'] . '" alt="' . $lang['Start_watching_topic'] . '" title="' . $lang['Start_watching_topic'] . '" border="0"></a>' : '';
// If we've got a hightlight set pass it on to pagination,
// I get annoyed when I lose my highlight after the first page.
$pagination = ( $highlight != '' ) ? generate_pagination("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&postdays=$post_days&postorder=$post_order&highlight=$highlight", $total_replies, $board_config['posts_per_page'], $start) : generate_pagination("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&postdays=$post_days&postorder=$post_order", $total_replies, $board_config['posts_per_page'], $start);
// Send vars to template
'FORUM_ID' => $forum_id,
'FORUM_NAME' => $forum_name,
'TOPIC_ID' => $topic_id,
'TOPIC_TITLE' => $topic_title,
'PAGINATION' => $pagination,
'PAGE_NUMBER' => sprintf($lang['Page_of'], ( floor( $start / intval($board_config['posts_per_page']) ) + 1 ), ceil( $total_replies / intval($board_config['posts_per_page']) )),
'POST_IMG' => $post_img,
'REPLY_IMG' => $reply_img,
'L_AUTHOR' => $lang['Author'],
'L_MESSAGE' => $lang['Message'],
'L_POSTED' => $lang['Posted'],
'L_POST_SUBJECT' => $lang['Post_subject'],
'L_VIEW_NEXT_TOPIC' => $lang['View_next_topic'],
'L_VIEW_PREVIOUS_TOPIC' => $lang['View_previous_topic'],
'L_POST_NEW_TOPIC' => $post_alt,
'L_POST_REPLY_TOPIC' => $reply_alt,
'L_BACK_TO_TOP' => $lang['Back_to_top'],
'L_DISPLAY_POSTS' => $lang['Display_posts'],
'L_LOCK_TOPIC' => $lang['Lock_topic'],
'L_UNLOCK_TOPIC' => $lang['Unlock_topic'],
'L_MOVE_TOPIC' => $lang['Move_topic'],
'L_SPLIT_TOPIC' => $lang['Split_topic'],
'L_DELETE_TOPIC' => $lang['Delete_topic'],
'L_GOTO_PAGE' => $lang['Goto_page'],
'S_TOPIC_LINK' => POST_TOPIC_URL,
'S_SELECT_POST_DAYS' => $select_post_days,
'S_SELECT_POST_ORDER' => $select_post_order,
'S_POST_DAYS_ACTION' => append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . '=' . $topic_id . "&start=$start"),
'S_AUTH_LIST' => $s_auth_can,
'S_TOPIC_ADMIN' => $topic_mod,
'S_WATCH_TOPIC' => $s_watching_topic,
'S_WATCH_TOPIC_IMG' => $s_watching_topic_img,
'U_VIEW_TOPIC' => append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&start=$start&postdays=$post_days&postorder=$post_order&highlight=$highlight"),
'U_VIEW_FORUM' => $view_forum_url,
'U_VIEW_OLDER_TOPIC' => $view_prev_topic_url,
'U_VIEW_NEWER_TOPIC' => $view_next_topic_url,
'U_POST_NEW_TOPIC' => $new_topic_url,
'U_POST_REPLY_TOPIC' => $reply_topic_url)
// Does this topic contain a poll?
if ( !empty($forum_topic_data['topic_vote']) )
$s_hidden_fields = '';
$sql = "SELECT vd.vote_id, vd.vote_text, vd.vote_start, vd.vote_length, vr.vote_option_id, vr.vote_option_text, vr.vote_result
FROM " . VOTE_DESC_TABLE . " vd, " . VOTE_RESULTS_TABLE . " vr
WHERE vd.topic_id = $topic_id
AND vr.vote_id = vd.vote_id
ORDER BY vr.vote_option_id ASC";
message_die(GENERAL_ERROR, "Could not obtain vote data for this topic", '', __LINE__, __FILE__, $sql);
if ( $vote_info = $db->sql_fetchrowset($result) )
$vote_options = count($vote_info);
$vote_id = $vote_info[0]['vote_id'];
$vote_title = $vote_info[0]['vote_text'];
$sql = "SELECT vote_id
FROM " . VOTE_USERS_TABLE . "
WHERE vote_id = $vote_id
AND vote_user_id = " . intval($userdata['user_id']);
message_die(GENERAL_ERROR, "Could not obtain user vote data for this topic", '', __LINE__, __FILE__, $sql);
$user_voted = ( $row = $db->sql_fetchrow($result) ) ? TRUE : 0;
if ( isset($HTTP_GET_VARS['vote']) || isset($HTTP_POST_VARS['vote']) )
$view_result = ( ( ( isset($HTTP_GET_VARS['vote']) ) ? $HTTP_GET_VARS['vote'] : $HTTP_POST_VARS['vote'] ) == 'viewresult' ) ? TRUE : 0;
$view_result = 0;
$poll_expired = ( $vote_info[0]['vote_length'] ) ? ( ( $vote_info[0]['vote_start'] + $vote_info[0]['vote_length'] < time() ) ? TRUE : 0 ) : 0;
if ( $user_voted || $view_result || $poll_expired || !$is_auth['auth_vote'] || $forum_topic_data['topic_status'] == TOPIC_LOCKED )
'pollbox' => 'viewtopic_poll_result.tpl')
$vote_results_sum = 0;
for($i = 0; $i < $vote_options; $i++)
$vote_results_sum += $vote_info[$i]['vote_result'];
$vote_graphic = 0;
$vote_graphic_max = count($images['voting_graphic']);
$vote_percent = ( $vote_results_sum > 0 ) ? $vote_info[$i]['vote_result'] / $vote_results_sum : 0;
$vote_graphic_length = round($vote_percent * $board_config['vote_graphic_length']);
$vote_graphic_img = $images['voting_graphic'][$vote_graphic];
$vote_graphic = ($vote_graphic < $vote_graphic_max - 1) ? $vote_graphic + 1 : 0;
$vote_info[$i]['vote_option_text'] = preg_replace($orig_word, $replacement_word, $vote_info[$i]['vote_option_text']);
$template->assign_block_vars("poll_option", array(
'POLL_OPTION_CAPTION' => $vote_info[$i]['vote_option_text'],
'POLL_OPTION_RESULT' => $vote_info[$i]['vote_result'],
'POLL_OPTION_PERCENT' => sprintf("%.1d%%", ($vote_percent * 100)),
'POLL_OPTION_IMG' => $vote_graphic_img,
'POLL_OPTION_IMG_WIDTH' => $vote_graphic_length)
'L_TOTAL_VOTES' => $lang['Total_votes'],
'TOTAL_VOTES' => $vote_results_sum)
'pollbox' => 'viewtopic_poll_ballot.tpl')
'POLL_OPTION_ID' => $vote_info[$i]['vote_option_id'],
'POLL_OPTION_CAPTION' => $vote_info[$i]['vote_option_text'])
'L_SUBMIT_VOTE' => $lang['Submit_vote'],
'L_VIEW_RESULTS' => $lang['View_results'],
'U_VIEW_RESULTS' => append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&postdays=$post_days&postorder=$post_order&vote=viewresult"))
$s_hidden_fields = '<input type="hidden" name="topic_id" value="' . $topic_id . '" /><input type="hidden" name="mode" value="vote" />';
$vote_title = preg_replace($orig_word, $replacement_word, $vote_title);
$s_hidden_fields .= '<input type="hidden" name="sid" value="' . $userdata['session_id'] . '" />';
'POLL_QUESTION' => $vote_title,
'S_HIDDEN_FIELDS' => $s_hidden_fields,
'S_POLL_ACTION' => append_sid("posting.$phpEx?mode=vote&" . POST_TOPIC_URL . "=$topic_id"))
$template->assign_var_from_handle('POLL_DISPLAY', 'pollbox');
// Update the topic view counter
$sql = "UPDATE " . TOPICS_TABLE . "
SET topic_views = topic_views + 1
WHERE topic_id = $topic_id";
if ( !$db->sql_query($sql) )
message_die(GENERAL_ERROR, "Could not update topic views.", '', __LINE__, __FILE__, $sql);
// Okay, let's do the loop, yeah come on baby let's do the loop
// and it goes like this ...
for($i = 0; $i < $total_posts; $i++)
$poster_id = $postrow[$i]['user_id'];
$poster = ( $poster_id == ANONYMOUS ) ? $lang['Guest'] : $postrow[$i]['username'];
$post_date = create_date($board_config['default_dateformat'], $postrow[$i]['post_time'], $board_config['board_timezone']);
$poster_posts = ( $postrow[$i]['user_id'] != ANONYMOUS ) ? $lang['Posts'] . ': ' . $postrow[$i]['user_posts'] : '';
$poster_from = ( $postrow[$i]['user_from'] && $postrow[$i]['user_id'] != ANONYMOUS ) ? $lang['Location'] . ': ' . $postrow[$i]['user_from'] : '';
$poster_userflags = ( $postrow[$i]['user_flagslang'] && $postrow[$i]['user_id'] != ANONYMOUS ) ? str_replace(array('cn', 'de', 'es', 'gr', 'il', 'it', ','), array('<img src="http://centerian.free.fr/langdawson/images/languages/cn.png" />', '<img src="http://centerian.free.fr/langdawson/images/languages/de.png" />', '<img src="http://centerian.free.fr/langdawson/images/languages/es.png" />', '<img src="http://centerian.free.fr/langdawson/images/languages/gr.png" />', '<img src="http://centerian.free.fr/langdawson/images/languages/il.png" />', '<img src="http://centerian.free.fr/langdawson/images/languages/it.png" />', ''), $postrow[$i]['user_flagslang']) : '';
$poster_joined = ( $postrow[$i]['user_id'] != ANONYMOUS ) ? $lang['Joined'] . ': ' . create_date($lang['DATE_FORMAT'], $postrow[$i]['user_regdate'], $board_config['board_timezone']) : '';
$poster_avatar = '';
if ( $postrow[$i]['user_avatar_type'] && $poster_id != ANONYMOUS && $postrow[$i]['user_allowavatar'] )
switch( $postrow[$i]['user_avatar_type'] )
case USER_AVATAR_UPLOAD:
$poster_avatar = ( $board_config['allow_avatar_upload'] ) ? '<img src="' . $board_config['avatar_path'] . '/' . $postrow[$i]['user_avatar'] . '" alt="" border="0" />' : '';
break;
case USER_AVATAR_REMOTE:
$poster_avatar = ( $board_config['allow_avatar_remote'] ) ? '<img src="' . $postrow[$i]['user_avatar'] . '" alt="" border="0" />' : '';
break;
case USER_AVATAR_GALLERY:
$poster_avatar = ( $board_config['allow_avatar_local'] ) ? '<img src="' . $board_config['avatar_gallery_path'] . '/' . $postrow[$i]['user_avatar'] . '" alt="" border="0" />' : '';
break;
// Define the little post icon
if ( $userdata['session_logged_in'] && $postrow[$i]['post_time'] > $userdata['user_lastvisit'] && $postrow[$i]['post_time'] > $topic_last_read )
$mini_post_img = $images['icon_minipost_new'];
$mini_post_alt = $lang['New_post'];
$mini_post_img = $images['icon_minipost'];
$mini_post_alt = $lang['Post'];
$mini_post_url = append_sid("viewtopic.$phpEx?" . POST_POST_URL . '=' . $postrow[$i]['post_id']) . '#' . $postrow[$i]['post_id'];
// Generate ranks, set them to empty string initially.
$poster_rank = '';
$rank_image = '';
$custom_title = '';
if ( $postrow[$i]['user_id'] == ANONYMOUS )
else if ( $postrow[$i]['user_rank'] )
for($j = 0; $j < count($ranksrow); $j++)
if ( $postrow[$i]['user_rank'] == $ranksrow[$j]['rank_id'] && $ranksrow[$j]['rank_special'] )
$poster_rank = $ranksrow[$j]['rank_title'];
$rank_image = ( $ranksrow[$j]['rank_image'] ) ? '<img src="' . $ranksrow[$j]['rank_image'] . '" alt="' . $poster_rank . '" title="' . $poster_rank . '" border="0" /><br />' : '';
if ( $postrow[$i]['user_posts'] >= $ranksrow[$j]['rank_min'] && !$ranksrow[$j]['rank_special'] )
if ( !empty($postrow[$i]['user_custom_title']) )
switch( $board_config['custom_title_mode'] )
case CUSTOM_TITLE_MODE_INDEPENDENT:
$custom_title = $postrow[$i]['user_custom_title'] . '<br />';
break;
case CUSTOM_TITLE_MODE_REPLACE_RANK:
$poster_rank = $postrow[$i]['user_custom_title'];
break;
case CUSTOM_TITLE_MODE_REPLACE_BOTH:
$rank_image = '';
break;
default:
break;
// Handle anon users posting with usernames
if ( $poster_id == ANONYMOUS && $postrow[$i]['post_username'] != '' )
$poster = $postrow[$i]['post_username'];
$poster_rank = $lang['Guest'];
$temp_url = '';
if ( $poster_id != ANONYMOUS )
$temp_url = append_sid("profile.$phpEx?mode=viewprofile&" . POST_USERS_URL . "=$poster_id");
$profile_img = '<a href="' . $temp_url . '"><img src="' . $images['icon_profile'] . '" alt="' . $lang['Read_profile'] . '" title="' . $lang['Read_profile'] . '" border="0" /></a>';
$profile = '<a href="' . $temp_url . '">' . $lang['Read_profile'] . '</a>';
$temp_url = append_sid("privmsg.$phpEx?mode=post&" . POST_USERS_URL . "=$poster_id");
$pm_img = '<a href="' . $temp_url . '"><img src="' . $images['icon_pm'] . '" alt="' . $lang['Send_private_message'] . '" title="' . $lang['Send_private_message'] . '" border="0" /></a>';
$pm = '<a href="' . $temp_url . '">' . $lang['Send_private_message'] . '</a>';
if ( !empty($postrow[$i]['user_viewemail']) || $is_auth['auth_mod'] )
$email_uri = ( $board_config['board_email_form'] ) ? append_sid("profile.$phpEx?mode=email&" . POST_USERS_URL .'=' . $poster_id) : 'mailto:' . $postrow[$i]['user_email'];
$email_img = '<a href="' . $email_uri . '"><img src="' . $images['icon_email'] . '" alt="' . $lang['Send_email'] . '" title="' . $lang['Send_email'] . '" border="0" /></a>';
$email = '<a href="' . $email_uri . '">' . $lang['Send_email'] . '</a>';
$email_img = '';
$email = '';
$www_img = ( $postrow[$i]['user_website'] ) ? '<a href="' . $postrow[$i]['user_website'] . '" target="_userwww"><img src="' . $images['icon_www'] . '" alt="' . $lang['Visit_website'] . '" title="' . $lang['Visit_website'] . '" border="0" /></a>' : '';
$www = ( $postrow[$i]['user_website'] ) ? '<a href="' . $postrow[$i]['user_website'] . '" target="_userwww">' . $lang['Visit_website'] . '</a>' : '';
if ( !empty($postrow[$i]['user_icq']) )
$icq_status_img = '<a href="http://wwp.icq.com/' . $postrow[$i]['user_icq'] . '#pager"><img src="http://web.icq.com/whitepages/online?icq=' . $postrow[$i]['user_icq'] . '&img=5" width="18" height="18" border="0" /></a>';
$icq_img = '<a href="http://wwp.icq.com/scripts/search.dll?to=' . $postrow[$i]['user_icq'] . '"><img src="' . $images['icon_icq'] . '" alt="' . $lang['ICQ'] . '" title="' . $lang['ICQ'] . '" border="0" /></a>';
$icq = '<a href="http://wwp.icq.com/scripts/search.dll?to=' . $postrow[$i]['user_icq'] . '">' . $lang['ICQ'] . '</a>';
$icq_status_img = '';
$icq_img = '';
$icq = '';
$aim_img = ( $postrow[$i]['user_aim'] ) ? '<a href="aim:goim?screenname=' . $postrow[$i]['user_aim'] . '&message=Hello+Are+you+there?"><img src="' . $images['icon_aim'] . '" alt="' . $lang['AIM'] . '" title="' . $lang['AIM'] . '" border="0" /></a>' : '';
$aim = ( $postrow[$i]['user_aim'] ) ? '<a href="aim:goim?screenname=' . $postrow[$i]['user_aim'] . '&message=Hello+Are+you+there?">' . $lang['AIM'] . '</a>' : '';
$msn_img = ( $postrow[$i]['user_msnm'] ) ? '<a href="' . $temp_url . '"><img src="' . $images['icon_msnm'] . '" alt="' . $lang['MSNM'] . '" title="' . $lang['MSNM'] . '" border="0" /></a>' : '';
$msn = ( $postrow[$i]['user_msnm'] ) ? '<a href="' . $temp_url . '">' . $lang['MSNM'] . '</a>' : '';
$yim_img = ( $postrow[$i]['user_yim'] ) ? '<a href="http://edit.yahoo.com/config/send_webmesg?.target=' . $postrow[$i]['user_yim'] . '&.src=pg"><img src="' . $images['icon_yim'] . '" alt="' . $lang['YIM'] . '" title="' . $lang['YIM'] . '" border="0" /></a>' : '';
$yim = ( $postrow[$i]['user_yim'] ) ? '<a href="http://edit.yahoo.com/config/send_webmesg?.target=' . $postrow[$i]['user_yim'] . '&.src=pg">' . $lang['YIM'] . '</a>' : '';
$profile_img = '';
$profile = '';
$pm_img = '';
$pm = '';
$email_img = '';
$email = '';
$www_img = '';
$www = '';
$icq_img = '';
$icq = '';
$aim_img = '';
$aim = '';
$msn_img = '';
$msn = '';
$yim_img = '';
$yim = '';
$temp_url = append_sid("posting.$phpEx?mode=quote&" . POST_POST_URL . "=" . $postrow[$i]['post_id']);
$quote_img = '<a href="' . $temp_url . '"><img src="' . $images['icon_quote'] . '" alt="' . $lang['Reply_with_quote'] . '" title="' . $lang['Reply_with_quote'] . '" border="0" /></a>';
$quote = '<a href="' . $temp_url . '">' . $lang['Reply_with_quote'] . '</a>';
$temp_url = append_sid("search.$phpEx?search_author=" . urlencode($postrow[$i]['username']) . "&showresults=posts");
$search_img = '<a href="' . $temp_url . '"><img src="' . $images['icon_search'] . '" alt="' . sprintf($lang['Search_user_posts'], $postrow[$i]['username']) . '" title="' . sprintf($lang['Search_user_posts'], $postrow[$i]['username']) . '" border="0" /></a>';
$search = '<a href="' . $temp_url . '">' . sprintf($lang['Search_user_posts'], $postrow[$i]['username']) . '</a>';
if ( ( $userdata['user_id'] == $poster_id && $is_auth['auth_edit'] ) || $is_auth['auth_mod'] )
$temp_url = append_sid("posting.$phpEx?mode=editpost&" . POST_POST_URL . "=" . $postrow[$i]['post_id']);
$edit_img = '<a href="' . $temp_url . '"><img src="' . $images['icon_edit'] . '" alt="' . $lang['Edit_delete_post'] . '" title="' . $lang['Edit_delete_post'] . '" border="0" /></a>';
$edit = '<a href="' . $temp_url . '">' . $lang['Edit_delete_post'] . '</a>';
$edit_img = '';
$edit = '';
$temp_url = "modcp.$phpEx?mode=ip&" . POST_POST_URL . "=" . $postrow[$i]['post_id'] . "&" . POST_TOPIC_URL . "=" . $topic_id . "&sid=" . $userdata['session_id'];
$ip_img = '<a href="' . $temp_url . '"><img src="' . $images['icon_ip'] . '" alt="' . $lang['View_IP'] . '" title="' . $lang['View_IP'] . '" border="0" /></a>';
$ip = '<a href="' . $temp_url . '">' . $lang['View_IP'] . '</a>';
$temp_url = "posting.$phpEx?mode=delete&" . POST_POST_URL . "=" . $postrow[$i]['post_id'] . "&sid=" . $userdata['session_id'];
$delpost_img = '<a href="' . $temp_url . '"><img src="' . $images['icon_delpost'] . '" alt="' . $lang['Delete_post'] . '" title="' . $lang['Delete_post'] . '" border="0" /></a>';
$delpost = '<a href="' . $temp_url . '">' . $lang['Delete_post'] . '</a>';
$ip_img = '';
$ip = '';
if ( $userdata['user_id'] == $poster_id && $is_auth['auth_delete'] && $forum_topic_data['topic_last_post_id'] == $postrow[$i]['post_id'] )
$delpost_img = '';
$delpost = '';
$post_subject = ( $postrow[$i]['post_subject'] != '' ) ? $postrow[$i]['post_subject'] : '';
$message = $postrow[$i]['post_text'];
$bbcode_uid = $postrow[$i]['bbcode_uid'];
$user_sig = ( $postrow[$i]['enable_sig'] && $postrow[$i]['user_sig'] != '' && $board_config['allow_sig'] ) ? $postrow[$i]['user_sig'] : '';
$user_sig_bbcode_uid = $postrow[$i]['user_sig_bbcode_uid'];
// Note! The order used for parsing the message _is_ important, moving things around could break any
// output
// If the board has HTML off but the post has HTML
// on then we process it, else leave it alone
if ( !$board_config['allow_html'] || !$userdata['user_allowhtml'])
if ( $user_sig != '' )
$user_sig = preg_replace('#(<)([\/]?.*?)(>)#is', "<\\2>", $user_sig);
if ( $postrow[$i]['enable_html'] )
$message = preg_replace('#(<)([\/]?.*?)(>)#is', "<\\2>", $message);
// Parse message and/or sig for BBCode if reqd
if ($user_sig != '' && $user_sig_bbcode_uid != '')
$user_sig = ($board_config['allow_bbcode']) ? bbencode_second_pass($user_sig, $user_sig_bbcode_uid) : preg_replace("/\:$user_sig_bbcode_uid/si", '', $user_sig);
if ($bbcode_uid != '')
$message = ($board_config['allow_bbcode']) ? bbencode_second_pass($message, $bbcode_uid) : preg_replace("/\:$bbcode_uid/si", '', $message);
$user_sig = make_clickable($user_sig);
$message = make_clickable($message);
// Parse smilies
if ( $board_config['allow_smilies'] )
if ( $postrow[$i]['user_allowsmile'] && $user_sig != '' )
$user_sig = smilies_pass($user_sig);
if ( $postrow[$i]['enable_smilies'] )
$message = smilies_pass($message);
// Highlight active words (primarily for search)
if ($highlight_match)
// This has been back-ported from 3.0 CVS
$message = preg_replace('#(?!<.*)(?<!\w)(' . $highlight_match . ')(?!\w|[^<>]*>)#i', '<b style="color:#'.$theme['fontcolor3'].'">\1</b>', $message);
// Replace naughty words
if (count($orig_word))
$post_subject = preg_replace($orig_word, $replacement_word, $post_subject);
if ($user_sig != '')
$user_sig = str_replace('\"', '"', substr(@preg_replace('#(\>(((?>([^><]+|(?R)))*)\<))#se', "@preg_replace(\$orig_word, \$replacement_word, '\\0')", '>' . $user_sig . '<'), 1, -1));
$message = str_replace('\"', '"', substr(@preg_replace('#(\>(((?>([^><]+|(?R)))*)\<))#se', "@preg_replace(\$orig_word, \$replacement_word, '\\0')", '>' . $message . '<'), 1, -1));
// Replace newlines (we use this rather than nl2br because
// till recently it wasn't XHTML compliant)
$user_sig = '<br />_________________<br />' . str_replace("\n", "\n<br />\n", $user_sig);
$message = str_replace("\n", "\n<br />\n", $message);
// Editing information
if ( $postrow[$i]['post_edit_count'] )
$l_edit_time_total = ( $postrow[$i]['post_edit_count'] == 1 ) ? $lang['Edited_time_total'] : $lang['Edited_times_total'];
$l_edited_by = '<br /><br />' . sprintf($l_edit_time_total, $poster, create_date($board_config['default_dateformat'], $postrow[$i]['post_edit_time'], $board_config['board_timezone']), $postrow[$i]['post_edit_count']);
$l_edited_by = '';
// Again this will be handled by the templating
// code at some point
$row_color = ( !($i % 2) ) ? $theme['td_color1'] : $theme['td_color2'];
$row_class = ( !($i % 2) ) ? $theme['td_class1'] : $theme['td_class2'];
$template->assign_block_vars('postrow', array(
'ROW_COLOR' => '#' . $row_color,
'ROW_CLASS' => $row_class,
'POSTER_NAME' => $poster,
'CUSTOM_TITLE' => $custom_title,
'POSTER_RANK' => $poster_rank,
'RANK_IMAGE' => $rank_image,
'POSTER_JOINED' => $poster_joined,
'POSTER_POSTS' => $poster_posts,
'POSTER_FROM' => $poster_from,
'POSTER_USERFLAGS' => $poster_userflags,
'POSTER_AVATAR' => $poster_avatar,
'POST_DATE' => $post_date,
'POST_SUBJECT' => $post_subject,
'MESSAGE' => $message,
'SIGNATURE' => $user_sig,
'EDITED_MESSAGE' => $l_edited_by,
'MINI_POST_IMG' => $mini_post_img,
'PROFILE_IMG' => $profile_img,
'PROFILE' => $profile,
'SEARCH_IMG' => $search_img,
'SEARCH' => $search,
'PM_IMG' => $pm_img,
'PM' => $pm,
'EMAIL_IMG' => $email_img,
'EMAIL' => $email,
'WWW_IMG' => $www_img,
'WWW' => $www,
'ICQ_STATUS_IMG' => $icq_status_img,
'ICQ_IMG' => $icq_img,
'ICQ' => $icq,
'AIM_IMG' => $aim_img,
'AIM' => $aim,
'MSN_IMG' => $msn_img,
'MSN' => $msn,
'YIM_IMG' => $yim_img,
'YIM' => $yim,
'EDIT_IMG' => $edit_img,
'EDIT' => $edit,
'QUOTE_IMG' => $quote_img,
'QUOTE' => $quote,
'IP_IMG' => $ip_img,
'IP' => $ip,
'DELETE_IMG' => $delpost_img,
'DELETE' => $delpost,
'L_MINI_POST_ALT' => $mini_post_alt,
'U_MINI_POST' => $mini_post_url,
'U_POST_ID' => $postrow[$i]['post_id'])
$template->pparse('body');
include($phpbb_root_path . 'includes/page_tail.'.$phpEx);
?>Okay, FIND in viewtopic.php
AFTER ADD
Now view any topic, and tell me what you see (I imagine you will get a bit of text at the top of the page).
$poster_userflags = ( $postrow[$i]['user_flagslang'] && $postrow[$i]['user_id'] != ANONYMOUS ) ? str_replace(array('cn', 'de', 'es', 'gr', 'il', 'it', ','), array('<img src="http://centerian.free.fr/langdawson/images/languages/cn.png" />', '<img src="http://centerian.free.fr/langdawson/images/languages/de.png" />', '<img src="http://centerian.free.fr/langdawson/images/languages/es.png" />', '<img src="http://centerian.free.fr/langdawson/images/languages/gr.png" />', '<img src="http://centerian.free.fr/langdawson/images/languages/il.png" />', '<img src="http://centerian.free.fr/langdawson/images/languages/it.png" />', ''), $postrow[$i]['user_flagslang']) : '';Code: Select all
// TESTING
echo 'USER FLAGS: ' . $postrow[$i]['user_flagslang'] . '<br />';
// END TESTINGCricketMX.com in 2022: Still the home of bat's, rat's and other farmyard animals!
Okay, now undo that change (so remove that // TESTING bit I gave above).
In viewtopic.php, FIND
on that first line, see u.user_custom_title, ?
AFTER THAT, ADD:
So that line will look like: SELECT u.username, u.user_id, u.user_posts, u.user_custom_title, u.user_custom_title, u.user_from, etc etc
$limit_posts_time
LIMIT $start, ".$board_config['posts_per_page'];AFTER THAT, ADD:
user_flagslang,So that line will look like: SELECT u.username, u.user_id, u.user_posts, u.user_custom_title, u.user_custom_title, u.user_from, etc etc
We're almost there ! I get /languag
/de.png" />
/de.png" />
* viewtopic.php
// or older topic
$session_id = '';
if ( $session_id )
LIMIT 1";
WHERE
LIMIT 1";
WHERE $join_sql
$order_sql";
// Start auth check
$is_auth = array();
// End auth check
if ($post_id)
$start = 0;
$post_days = 0;
$sql = "SELECT u.username, u.user_id, u.user_posts, u.user_custom_title, user_flagslang, u.user_from, u.user_website, u.user_email, u.user_icq, u.user_aim, u.user_yim, u.user_regdate, u.user_msnm, u.user_viewemail, u.user_rank, u.user_sig, u.user_sig_bbcode_uid, u.user_avatar, u.user_avatar_type, u.user_allowavatar, u.user_allowsmile, p.*, pt.post_text, pt.post_subject, pt.bbcode_uid
$limit_posts_time
$postrow = array();
do
$postrow[] = $row;
$resync = FALSE;
$resync = TRUE;
$resync = TRUE;
$resync = TRUE;
if ($resync)
$sql = "SELECT *
$ranksrow[] = $row;
unset($words);
// templating vars
// Load templates
$topic_mod = '';
$view_result = 0;
$vote_graphic = 0;
break;
break;
break;
$poster_rank = '';
$rank_image = '';
$custom_title = '';
break;
break;
$rank_image = '';
break;
default:
break;
$temp_url = '';
$email_img = '';
$email = '';
$icq_img = '';
$icq = '';
$profile_img = '';
$profile = '';
$pm_img = '';
$pm = '';
$email_img = '';
$email = '';
$www_img = '';
$www = '';
$icq_img = '';
$icq = '';
$aim_img = '';
$aim = '';
$msn_img = '';
$msn = '';
$yim_img = '';
$yim = '';
$edit_img = '';
$edit = '';
$ip_img = '';
$ip = '';
$delpost_img = '';
$delpost = '';
// output
// Parse smilies
$l_edited_by = '';
'PM' => $pm,
'EMAIL' => $email,
'WWW' => $www,
'ICQ' => $icq,
'AIM' => $aim,
'MSN' => $msn,
'YIM' => $yim,
'EDIT' => $edit,
'QUOTE' => $quote,
'IP' => $ip,
?>Okay, find in viewtopic.php:
Replace with:
Save and re-upload. How does that work?
EDIT: I had $expl_flags[$i] instead of $expl_flags[$q] ... so if you made this edit, please re-do it.
// user language flags
$expl_flags = explode(',', $postrow[$i]['user_flagslang']);
$poster_userflags = '';
for($q = 0, $q_count = sizeof($expl_flags); $q < $q_count; $q++ )
$poster_userflags .= ($expl_flags[$q] == 'cn') ? '<img src="http://centerian.free.fr/langdawson/images/languages/cn.png" /> ' : '';
$poster_userflags .= ($expl_flags[$q] == 'de') ? '<img src="http://centerian.free.fr/langdawson/images/languages/de.png" /> ' : '';
$poster_userflags .= ($expl_flags[$q] == 'es') ? '<img src="http://centerian.free.fr/langdawson/images/languages/es.png" /> ' : '';
$poster_userflags .= ($expl_flags[$q] == 'gr') ? '<img src="http://centerian.free.fr/langdawson/images/languages/gr.png" /> ' : '';
$poster_userflags .= ($expl_flags[$q] == 'il') ? '<img src="http://centerian.free.fr/langdawson/images/languages/il.png" /> ' : '';
$poster_userflags .= ($expl_flags[$q] == 'it') ? '<img src="http://centerian.free.fr/langdawson/images/languages/iy.png" /> ' : '';
} Save and re-upload. How does that work?
Parse error: syntax error, unexpected $end in /mnt/128/sdb/5/1/centerian/langdawson/viewtopic.php on line 1244
That usually means you tried to access the page before the file had finished uploading. It could also mean missing brackets, but the code I put in the post above seems okay.
Did you see the edit I put above? I accidentally used the letter i instead of q, so please re-do that code above. I have edited the post with the correct code.
I just want to make sure you saw the edit, and that you used:thesims wrote:Never mind, it does display flags, but only one. I wrote de,it but the German flag is the only one appearing.
} CricketMX.com in 2022: Still the home of bat's, rat's and other farmyard animals!
Okay, that's good. Can you post a screenshot? I'd like to see how it looks now
http://centerian.free.fr/langdawson/images/flagMOD.jpgAnyway, thanks a lot for your help, I really, really.... really appreciate. The one other person who offered to help me tried to get the login info to the admin account on the forum and I didn't trust him at all. I am glad you offered to write the MOD for me. We need more people like you on the Internet, lol.
Oh and do you want me to mention your name somewhere ?
I can give you the credits for the MOD and add a link if you wish.
That looks great
To reduce the gap, in viewtopic_body.tpl FIND:
<br /><br />{postrow.POSTER_USERFLAGS}Code: Select all
<br />{postrow.POSTER_USERFLAGS}Out of interest, who is the model in your avatar?
