Need help with a phpBB2 MOD
You mentioned earlier about the customs titles MOD. Can you please post the contents of your viewtopic.php file (in code tags) and I will have a look and make sure there is no conflict.
thesims
 *                               viewtopic.php
 *   begin                : Saturday, Feb 13, 2001
 *   copyright            : (C) 2001 The phpBB Group
 *   email                : support@phpbb.com
 *   $Id: viewtopic.php 6772 2006-12-16 13:11:28Z acydburn $
 *   This program is free software; you can redistribute it and/or modify
 *   it under the terms of the GNU General Public License as published by
 *   the Free Software Foundation; either version 2 of the License, or
 *   (at your option) any later version.
$phpbb_root_path = './';
include($phpbb_root_path . 'extension.inc');
include($phpbb_root_path . 'common.'.$phpEx);
include($phpbb_root_path . 'includes/bbcode.'.$phpEx);
// Start initial var setup
$topic_id = $post_id = 0;
if ( isset($HTTP_GET_VARS[POST_TOPIC_URL]) )
	$topic_id = intval($HTTP_GET_VARS[POST_TOPIC_URL]);
else if ( isset($HTTP_GET_VARS['topic']) )
	$topic_id = intval($HTTP_GET_VARS['topic']);
if ( isset($HTTP_GET_VARS[POST_POST_URL]))
	$post_id = intval($HTTP_GET_VARS[POST_POST_URL]);
$start = ( isset($HTTP_GET_VARS['start']) ) ? intval($HTTP_GET_VARS['start']) : 0;
$start = ($start < 0) ? 0 : $start;
if (!$topic_id && !$post_id)
	message_die(GENERAL_MESSAGE, 'Topic_post_not_exist');
// Find topic id if user requested a newer
// or older topic
if ( isset($HTTP_GET_VARS['view']) && empty($HTTP_GET_VARS[POST_POST_URL]) )
	if ( $HTTP_GET_VARS['view'] == 'newest' )
		if ( isset($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_sid']) || isset($HTTP_GET_VARS['sid']) )
			$session_id = isset($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_sid']) ? $HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_sid'] : $HTTP_GET_VARS['sid'];
			if (!preg_match('/^[A-Za-z0-9]*$/', $session_id))
				$session_id = '';
			if ( $session_id )
				$sql = "SELECT p.post_id
					FROM " . POSTS_TABLE . " p, " . SESSIONS_TABLE . " s,  " . USERS_TABLE . " u
					WHERE s.session_id = '$session_id'
						AND u.user_id = s.session_user_id
						AND p.topic_id = $topic_id
						AND p.post_time >= u.user_lastvisit
					ORDER BY p.post_time ASC
					LIMIT 1";
				if ( !($result = $db->sql_query($sql)) )
					message_die(GENERAL_ERROR, 'Could not obtain newer/older topic information', '', __LINE__, __FILE__, $sql);
				if ( !($row = $db->sql_fetchrow($result)) )
					message_die(GENERAL_MESSAGE, 'No_new_posts_last_visit');
				$post_id = $row['post_id'];
				if (isset($HTTP_GET_VARS['sid']))
					redirect("viewtopic.$phpEx?sid=$session_id&" . POST_POST_URL . "=$post_id#$post_id");
					redirect("viewtopic.$phpEx?" . POST_POST_URL . "=$post_id#$post_id");
		redirect(append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id", true));
	else if ( $HTTP_GET_VARS['view'] == 'next' || $HTTP_GET_VARS['view'] == 'previous' )
		$sql_condition = ( $HTTP_GET_VARS['view'] == 'next' ) ? '>' : '<';
		$sql_ordering = ( $HTTP_GET_VARS['view'] == 'next' ) ? 'ASC' : 'DESC';
		$sql = "SELECT t.topic_id
			FROM " . TOPICS_TABLE . " t, " . TOPICS_TABLE . " t2
			WHERE
				t2.topic_id = $topic_id
				AND t.forum_id = t2.forum_id
				AND t.topic_moved_id = 0
				AND t.topic_last_post_id $sql_condition t2.topic_last_post_id
			ORDER BY t.topic_last_post_id $sql_ordering
			LIMIT 1";
			message_die(GENERAL_ERROR, "Could not obtain newer/older topic information", '', __LINE__, __FILE__, $sql);
		if ( $row = $db->sql_fetchrow($result) )
			$topic_id = intval($row['topic_id']);
			$message = ( $HTTP_GET_VARS['view'] == 'next' ) ? 'No_newer_topics' : 'No_older_topics';
			message_die(GENERAL_MESSAGE, $message);
// This rather complex gaggle of code handles querying for topics but
// also allows for direct linking to a post (and the calculation of which
// page the post is on and the correct display of viewtopic)
$join_sql_table = (!$post_id) ? '' : ", " . POSTS_TABLE . " p, " . POSTS_TABLE . " p2 ";
$join_sql = (!$post_id) ? "t.topic_id = $topic_id" : "p.post_id = $post_id AND t.topic_id = p.topic_id AND p2.topic_id = p.topic_id AND p2.post_id <= $post_id";
$count_sql = (!$post_id) ? '' : ", COUNT(p2.post_id) AS prev_posts";
$order_sql = (!$post_id) ? '' : "GROUP BY p.post_id, t.topic_id, t.topic_title, t.topic_status, t.topic_replies, t.topic_time, t.topic_type, t.topic_vote, t.topic_last_post_id, f.forum_name, f.forum_status, f.forum_id, f.auth_view, f.auth_read, f.auth_post, f.auth_reply, f.auth_edit, f.auth_delete, f.auth_sticky, f.auth_announce, f.auth_pollcreate, f.auth_vote, f.auth_attachments ORDER BY p.post_id ASC";
$sql = "SELECT t.topic_id, t.topic_title, t.topic_status, t.topic_replies, t.topic_time, t.topic_type, t.topic_vote, t.topic_last_post_id, f.forum_name, f.forum_status, f.forum_id, f.auth_view, f.auth_read, f.auth_post, f.auth_reply, f.auth_edit, f.auth_delete, f.auth_sticky, f.auth_announce, f.auth_pollcreate, f.auth_vote, f.auth_attachments" . $count_sql . "
	FROM " . TOPICS_TABLE . " t, " . FORUMS_TABLE . " f" . $join_sql_table . "
	WHERE $join_sql
		AND f.forum_id = t.forum_id
		$order_sql";
	message_die(GENERAL_ERROR, "Could not obtain topic information", '', __LINE__, __FILE__, $sql);
if ( !($forum_topic_data = $db->sql_fetchrow($result)) )
$forum_id = intval($forum_topic_data['forum_id']);
// Start session management
$userdata = session_pagestart($user_ip, $forum_id);
init_userprefs($userdata);
// End session management
// Start auth check
$is_auth = array();
$is_auth = auth(AUTH_ALL, $forum_id, $userdata, $forum_topic_data);
if( !$is_auth['auth_view'] || !$is_auth['auth_read'] )
	if ( !$userdata['session_logged_in'] )
		$redirect = ($post_id) ? POST_POST_URL . "=$post_id" : POST_TOPIC_URL . "=$topic_id";
		$redirect .= ($start) ? "&start=$start" : '';
		redirect(append_sid("login.$phpEx?redirect=viewtopic.$phpEx&$redirect", true));
	$message = ( !$is_auth['auth_view'] ) ? $lang['Topic_post_not_exist'] : sprintf($lang['Sorry_auth_read'], $is_auth['auth_read_type']);
// End auth check
$forum_name = $forum_topic_data['forum_name'];
$topic_title = $forum_topic_data['topic_title'];
$topic_id = intval($forum_topic_data['topic_id']);
$topic_time = $forum_topic_data['topic_time'];
if ($post_id)
	$start = floor(($forum_topic_data['prev_posts'] - 1) / intval($board_config['posts_per_page'])) * intval($board_config['posts_per_page']);
// Is user watching this thread?
if( $userdata['session_logged_in'] )
	$can_watch_topic = TRUE;
	$sql = "SELECT notify_status
		FROM " . TOPICS_WATCH_TABLE . "
		WHERE topic_id = $topic_id
			AND user_id = " . $userdata['user_id'];
		message_die(GENERAL_ERROR, "Could not obtain topic watch information", '', __LINE__, __FILE__, $sql);
		if ( isset($HTTP_GET_VARS['unwatch']) )
			if ( $HTTP_GET_VARS['unwatch'] == 'topic' )
				$is_watching_topic = 0;
				$sql_priority = (SQL_LAYER == "mysql") ? "LOW_PRIORITY" : '';
				$sql = "DELETE $sql_priority FROM " . TOPICS_WATCH_TABLE . "
					message_die(GENERAL_ERROR, "Could not delete topic watch information", '', __LINE__, __FILE__, $sql);
			$template->assign_vars(array(
				'META' => '<meta http-equiv="refresh" content="3;url=' . append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&start=$start") . '">')
			$message = $lang['No_longer_watching'] . '<br /><br />' . sprintf($lang['Click_return_topic'], '<a href="' . append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&start=$start") . '">', '</a>');
			$is_watching_topic = TRUE;
			if ( $row['notify_status'] )
				$sql = "UPDATE $sql_priority " . TOPICS_WATCH_TABLE . "
					SET notify_status = 0
					message_die(GENERAL_ERROR, "Could not update topic watch information", '', __LINE__, __FILE__, $sql);
		if ( isset($HTTP_GET_VARS['watch']) )
			if ( $HTTP_GET_VARS['watch'] == 'topic' )
				$sql = "INSERT $sql_priority INTO " . TOPICS_WATCH_TABLE . " (user_id, topic_id, notify_status)
					VALUES (" . $userdata['user_id'] . ", $topic_id, 0)";
					message_die(GENERAL_ERROR, "Could not insert topic watch information", '', __LINE__, __FILE__, $sql);
			$message = $lang['You_are_watching'] . '<br /><br />' . sprintf($lang['Click_return_topic'], '<a href="' . append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&start=$start") . '">', '</a>');
			redirect(append_sid("login.$phpEx?redirect=viewtopic.$phpEx&" . POST_TOPIC_URL . "=$topic_id&unwatch=topic", true));
		$can_watch_topic = 0;
// Generate a 'Show posts in previous x days' select box. If the postdays var is POSTed
// then get it's value, find the number of topics with dates newer than it (to properly
// handle pagination) and alter the main query
$previous_days = array(0, 1, 7, 14, 30, 90, 180, 364);
$previous_days_text = array($lang['All_Posts'], $lang['1_Day'], $lang['7_Days'], $lang['2_Weeks'], $lang['1_Month'], $lang['3_Months'], $lang['6_Months'], $lang['1_Year']);
if( !empty($HTTP_POST_VARS['postdays']) || !empty($HTTP_GET_VARS['postdays']) )
	$post_days = ( !empty($HTTP_POST_VARS['postdays']) ) ? intval($HTTP_POST_VARS['postdays']) : intval($HTTP_GET_VARS['postdays']);
	$min_post_time = time() - (intval($post_days) * 86400);
	$sql = "SELECT COUNT(p.post_id) AS num_posts
		FROM " . TOPICS_TABLE . " t, " . POSTS_TABLE . " p
		WHERE t.topic_id = $topic_id
			AND p.topic_id = t.topic_id
			AND p.post_time >= $min_post_time";
		message_die(GENERAL_ERROR, "Could not obtain limited topics count information", '', __LINE__, __FILE__, $sql);
	$total_replies = ( $row = $db->sql_fetchrow($result) ) ? intval($row['num_posts']) : 0;
	$limit_posts_time = "AND p.post_time >= $min_post_time ";
	if ( !empty($HTTP_POST_VARS['postdays']))
		$start = 0;
	$total_replies = intval($forum_topic_data['topic_replies']) + 1;
	$limit_posts_time = '';
	$post_days = 0;
$select_post_days = '<select name="postdays">';
for($i = 0; $i < count($previous_days); $i++)
	$selected = ($post_days == $previous_days[$i]) ? ' selected="selected"' : '';
	$select_post_days .= '<option value="' . $previous_days[$i] . '"' . $selected . '>' . $previous_days_text[$i] . '</option>';
$select_post_days .= '</select>';
// Decide how to order the post display
if ( !empty($HTTP_POST_VARS['postorder']) || !empty($HTTP_GET_VARS['postorder']) )
	$post_order = (!empty($HTTP_POST_VARS['postorder'])) ? htmlspecialchars($HTTP_POST_VARS['postorder']) : htmlspecialchars($HTTP_GET_VARS['postorder']);
	$post_time_order = ($post_order == "asc") ? "ASC" : "DESC";
	$post_order = 'asc';
	$post_time_order = 'ASC';
$select_post_order = '<select name="postorder">';
if ( $post_time_order == 'ASC' )
	$select_post_order .= '<option value="asc" selected="selected">' . $lang['Oldest_First'] . '</option><option value="desc">' . $lang['Newest_First'] . '</option>';
	$select_post_order .= '<option value="asc">' . $lang['Oldest_First'] . '</option><option value="desc" selected="selected">' . $lang['Newest_First'] . '</option>';
$select_post_order .= '</select>';
// Go ahead and pull all data for this topic
$sql = "SELECT u.username, u.user_id, u.user_posts, u.user_custom_title, u.user_from, u.user_website, u.user_email, u.user_icq, u.user_aim, u.user_yim, u.user_regdate, u.user_msnm, u.user_viewemail, u.user_rank, u.user_sig, u.user_sig_bbcode_uid, u.user_avatar, u.user_avatar_type, u.user_allowavatar, u.user_allowsmile, p.*,  pt.post_text, pt.post_subject, pt.bbcode_uid
	FROM " . POSTS_TABLE . " p, " . USERS_TABLE . " u, " . POSTS_TEXT_TABLE . " pt
	WHERE p.topic_id = $topic_id
		$limit_posts_time
		AND pt.post_id = p.post_id
		AND u.user_id = p.poster_id
	ORDER BY p.post_time $post_time_order
	LIMIT $start, ".$board_config['posts_per_page'];
	message_die(GENERAL_ERROR, "Could not obtain post/user information.", '', __LINE__, __FILE__, $sql);
$postrow = array();
if ($row = $db->sql_fetchrow($result))
	do
		$postrow[] = $row;
	while ($row = $db->sql_fetchrow($result));
	$db->sql_freeresult($result);
	$total_posts = count($postrow);
   include($phpbb_root_path . 'includes/functions_admin.' . $phpEx);
   sync('topic', $topic_id);
   message_die(GENERAL_MESSAGE, $lang['No_posts_topic']);
$resync = FALSE;
if ($forum_topic_data['topic_replies'] + 1 < $start + count($postrow))
   $resync = TRUE;
elseif ($start + $board_config['posts_per_page'] > $forum_topic_data['topic_replies'])
   $row_id = intval($forum_topic_data['topic_replies']) % intval($board_config['posts_per_page']);
   if ($postrow[$row_id]['post_id'] != $forum_topic_data['topic_last_post_id'] || $start + count($postrow) < $forum_topic_data['topic_replies'])
      $resync = TRUE;
elseif (count($postrow) < $board_config['posts_per_page'])
   $resync = TRUE;
if ($resync)
   $result = $db->sql_query('SELECT COUNT(post_id) AS total FROM ' . POSTS_TABLE . ' WHERE topic_id = ' . $topic_id);
   $row = $db->sql_fetchrow($result);
   $total_replies = $row['total'];
$sql = "SELECT *
	FROM " . RANKS_TABLE . "
	ORDER BY rank_special, rank_min";
	message_die(GENERAL_ERROR, "Could not obtain ranks information.", '', __LINE__, __FILE__, $sql);
$ranksrow = array();
while ( $row = $db->sql_fetchrow($result) )
	$ranksrow[] = $row;
// Define censored word matches
$orig_word = array();
$replacement_word = array();
obtain_word_list($orig_word, $replacement_word);
// Censor topic title
if ( count($orig_word) )
	$topic_title = preg_replace($orig_word, $replacement_word, $topic_title);
// Was a highlight request part of the URI?
$highlight_match = $highlight = '';
if (isset($HTTP_GET_VARS['highlight']))
	// Split words and phrases
	$words = explode(' ', trim(htmlspecialchars($HTTP_GET_VARS['highlight'])));
	for($i = 0; $i < sizeof($words); $i++)
		if (trim($words[$i]) != '')
			$highlight_match .= (($highlight_match != '') ? '|' : '') . str_replace('*', '\w*', preg_quote($words[$i], '#'));
	unset($words);
	$highlight = urlencode($HTTP_GET_VARS['highlight']);
	$highlight_match = phpbb_rtrim($highlight_match, "\\");
// Post, reply and other URL generation for
// templating vars
$new_topic_url = append_sid("posting.$phpEx?mode=newtopic&" . POST_FORUM_URL . "=$forum_id");
$reply_topic_url = append_sid("posting.$phpEx?mode=reply&" . POST_TOPIC_URL . "=$topic_id");
$view_forum_url = append_sid("viewforum.$phpEx?" . POST_FORUM_URL . "=$forum_id");
$view_prev_topic_url = append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&view=previous");
$view_next_topic_url = append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&view=next");
// Mozilla navigation bar
$nav_links['prev'] = array(
	'url' => $view_prev_topic_url,
	'title' => $lang['View_previous_topic']
$nav_links['next'] = array(
	'url' => $view_next_topic_url,
	'title' => $lang['View_next_topic']
$nav_links['up'] = array(
	'url' => $view_forum_url,
	'title' => $forum_name
$reply_img = ( $forum_topic_data['forum_status'] == FORUM_LOCKED || $forum_topic_data['topic_status'] == TOPIC_LOCKED ) ? $images['reply_locked'] : $images['reply_new'];
$reply_alt = ( $forum_topic_data['forum_status'] == FORUM_LOCKED || $forum_topic_data['topic_status'] == TOPIC_LOCKED ) ? $lang['Topic_locked'] : $lang['Reply_to_topic'];
$post_img = ( $forum_topic_data['forum_status'] == FORUM_LOCKED ) ? $images['post_locked'] : $images['post_new'];
$post_alt = ( $forum_topic_data['forum_status'] == FORUM_LOCKED ) ? $lang['Forum_locked'] : $lang['Post_new_topic'];
// Set a cookie for this topic
if ( $userdata['session_logged_in'] )
	$tracking_topics = ( isset($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_t']) ) ? unserialize($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_t']) : array();
	$tracking_forums = ( isset($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_f']) ) ? unserialize($HTTP_COOKIE_VARS[$board_config['cookie_name'] . '_f']) : array();
	if ( !empty($tracking_topics[$topic_id]) && !empty($tracking_forums[$forum_id]) )
		$topic_last_read = ( $tracking_topics[$topic_id] > $tracking_forums[$forum_id] ) ? $tracking_topics[$topic_id] : $tracking_forums[$forum_id];
	else if ( !empty($tracking_topics[$topic_id]) || !empty($tracking_forums[$forum_id]) )
		$topic_last_read = ( !empty($tracking_topics[$topic_id]) ) ? $tracking_topics[$topic_id] : $tracking_forums[$forum_id];
		$topic_last_read = $userdata['user_lastvisit'];
	if ( count($tracking_topics) >= 150 && empty($tracking_topics[$topic_id]) )
		asort($tracking_topics);
		unset($tracking_topics[key($tracking_topics)]);
	$tracking_topics[$topic_id] = time();
	setcookie($board_config['cookie_name'] . '_t', serialize($tracking_topics), 0, $board_config['cookie_path'], $board_config['cookie_domain'], $board_config['cookie_secure']);
// Load templates
	'body' => 'viewtopic_body.tpl')
make_jumpbox('viewforum.'.$phpEx, $forum_id);
// Output page header
$page_title = $lang['View_topic'] .' - ' . $topic_title;
include($phpbb_root_path . 'includes/page_header.'.$phpEx);
// User authorisation levels output
$s_auth_can = ( ( $is_auth['auth_post'] ) ? $lang['Rules_post_can'] : $lang['Rules_post_cannot'] ) . '<br />';
$s_auth_can .= ( ( $is_auth['auth_reply'] ) ? $lang['Rules_reply_can'] : $lang['Rules_reply_cannot'] ) . '<br />';
$s_auth_can .= ( ( $is_auth['auth_edit'] ) ? $lang['Rules_edit_can'] : $lang['Rules_edit_cannot'] ) . '<br />';
$s_auth_can .= ( ( $is_auth['auth_delete'] ) ? $lang['Rules_delete_can'] : $lang['Rules_delete_cannot'] ) . '<br />';
$s_auth_can .= ( ( $is_auth['auth_vote'] ) ? $lang['Rules_vote_can'] : $lang['Rules_vote_cannot'] ) . '<br />';
$topic_mod = '';
if ( $is_auth['auth_mod'] )
	$s_auth_can .= sprintf($lang['Rules_moderate'], "<a href=\"modcp.$phpEx?" . POST_FORUM_URL . "=$forum_id&sid=" . $userdata['session_id'] . '">', '</a>');
	$topic_mod .= "<a href=\"modcp.$phpEx?" . POST_TOPIC_URL . "=$topic_id&mode=delete&sid=" . $userdata['session_id'] . '"><img src="' . $images['topic_mod_delete'] . '" alt="' . $lang['Delete_topic'] . '" title="' . $lang['Delete_topic'] . '" border="0" /></a>&nbsp;';
	$topic_mod .= "<a href=\"modcp.$phpEx?" . POST_TOPIC_URL . "=$topic_id&mode=move&sid=" . $userdata['session_id'] . '"><img src="' . $images['topic_mod_move'] . '" alt="' . $lang['Move_topic'] . '" title="' . $lang['Move_topic'] . '" border="0" /></a>&nbsp;';
	$topic_mod .= ( $forum_topic_data['topic_status'] == TOPIC_UNLOCKED ) ? "<a href=\"modcp.$phpEx?" . POST_TOPIC_URL . "=$topic_id&mode=lock&sid=" . $userdata['session_id'] . '"><img src="' . $images['topic_mod_lock'] . '" alt="' . $lang['Lock_topic'] . '" title="' . $lang['Lock_topic'] . '" border="0" /></a>&nbsp;' : "<a href=\"modcp.$phpEx?" . POST_TOPIC_URL . "=$topic_id&mode=unlock&sid=" . $userdata['session_id'] . '"><img src="' . $images['topic_mod_unlock'] . '" alt="' . $lang['Unlock_topic'] . '" title="' . $lang['Unlock_topic'] . '" border="0" /></a>&nbsp;';
	$topic_mod .= "<a href=\"modcp.$phpEx?" . POST_TOPIC_URL . "=$topic_id&mode=split&sid=" . $userdata['session_id'] . '"><img src="' . $images['topic_mod_split'] . '" alt="' . $lang['Split_topic'] . '" title="' . $lang['Split_topic'] . '" border="0" /></a>&nbsp;';
// Topic watch information
$s_watching_topic = '';
if ( $can_watch_topic )
	if ( $is_watching_topic )
		$s_watching_topic = "<a href=\"viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&unwatch=topic&start=$start&sid=" . $userdata['session_id'] . '">' . $lang['Stop_watching_topic'] . '</a>';
		$s_watching_topic_img = ( isset($images['topic_un_watch']) ) ? "<a href=\"viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&unwatch=topic&start=$start&sid=" . $userdata['session_id'] . '"><img src="' . $images['topic_un_watch'] . '" alt="' . $lang['Stop_watching_topic'] . '" title="' . $lang['Stop_watching_topic'] . '" border="0"></a>' : '';
		$s_watching_topic = "<a href=\"viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&watch=topic&start=$start&sid=" . $userdata['session_id'] . '">' . $lang['Start_watching_topic'] . '</a>';
		$s_watching_topic_img = ( isset($images['Topic_watch']) ) ? "<a href=\"viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&watch=topic&start=$start&sid=" . $userdata['session_id'] . '"><img src="' . $images['Topic_watch'] . '" alt="' . $lang['Start_watching_topic'] . '" title="' . $lang['Start_watching_topic'] . '" border="0"></a>' : '';
// If we've got a hightlight set pass it on to pagination,
// I get annoyed when I lose my highlight after the first page.
$pagination = ( $highlight != '' ) ? generate_pagination("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&postdays=$post_days&postorder=$post_order&highlight=$highlight", $total_replies, $board_config['posts_per_page'], $start) : generate_pagination("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&postdays=$post_days&postorder=$post_order", $total_replies, $board_config['posts_per_page'], $start);
// Send vars to template
	'FORUM_ID' => $forum_id,
    'FORUM_NAME' => $forum_name,
    'TOPIC_ID' => $topic_id,
    'TOPIC_TITLE' => $topic_title,
	'PAGINATION' => $pagination,
	'PAGE_NUMBER' => sprintf($lang['Page_of'], ( floor( $start / intval($board_config['posts_per_page']) ) + 1 ), ceil( $total_replies / intval($board_config['posts_per_page']) )),
	'POST_IMG' => $post_img,
	'REPLY_IMG' => $reply_img,
	'L_AUTHOR' => $lang['Author'],
	'L_MESSAGE' => $lang['Message'],
	'L_POSTED' => $lang['Posted'],
	'L_POST_SUBJECT' => $lang['Post_subject'],
	'L_VIEW_NEXT_TOPIC' => $lang['View_next_topic'],
	'L_VIEW_PREVIOUS_TOPIC' => $lang['View_previous_topic'],
	'L_POST_NEW_TOPIC' => $post_alt,
	'L_POST_REPLY_TOPIC' => $reply_alt,
	'L_BACK_TO_TOP' => $lang['Back_to_top'],
	'L_DISPLAY_POSTS' => $lang['Display_posts'],
	'L_LOCK_TOPIC' => $lang['Lock_topic'],
	'L_UNLOCK_TOPIC' => $lang['Unlock_topic'],
	'L_MOVE_TOPIC' => $lang['Move_topic'],
	'L_SPLIT_TOPIC' => $lang['Split_topic'],
	'L_DELETE_TOPIC' => $lang['Delete_topic'],
	'L_GOTO_PAGE' => $lang['Goto_page'],
	'S_TOPIC_LINK' => POST_TOPIC_URL,
	'S_SELECT_POST_DAYS' => $select_post_days,
	'S_SELECT_POST_ORDER' => $select_post_order,
	'S_POST_DAYS_ACTION' => append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . '=' . $topic_id . "&start=$start"),
	'S_AUTH_LIST' => $s_auth_can,
	'S_TOPIC_ADMIN' => $topic_mod,
	'S_WATCH_TOPIC' => $s_watching_topic,
	'S_WATCH_TOPIC_IMG' => $s_watching_topic_img,
	'U_VIEW_TOPIC' => append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&start=$start&postdays=$post_days&postorder=$post_order&highlight=$highlight"),
	'U_VIEW_FORUM' => $view_forum_url,
	'U_VIEW_OLDER_TOPIC' => $view_prev_topic_url,
	'U_VIEW_NEWER_TOPIC' => $view_next_topic_url,
	'U_POST_NEW_TOPIC' => $new_topic_url,
	'U_POST_REPLY_TOPIC' => $reply_topic_url)
// Does this topic contain a poll?
if ( !empty($forum_topic_data['topic_vote']) )
	$s_hidden_fields = '';
	$sql = "SELECT vd.vote_id, vd.vote_text, vd.vote_start, vd.vote_length, vr.vote_option_id, vr.vote_option_text, vr.vote_result
		FROM " . VOTE_DESC_TABLE . " vd, " . VOTE_RESULTS_TABLE . " vr
		WHERE vd.topic_id = $topic_id
			AND vr.vote_id = vd.vote_id
		ORDER BY vr.vote_option_id ASC";
		message_die(GENERAL_ERROR, "Could not obtain vote data for this topic", '', __LINE__, __FILE__, $sql);
	if ( $vote_info = $db->sql_fetchrowset($result) )
		$vote_options = count($vote_info);
		$vote_id = $vote_info[0]['vote_id'];
		$vote_title = $vote_info[0]['vote_text'];
		$sql = "SELECT vote_id
			FROM " . VOTE_USERS_TABLE . "
			WHERE vote_id = $vote_id
				AND vote_user_id = " . intval($userdata['user_id']);
			message_die(GENERAL_ERROR, "Could not obtain user vote data for this topic", '', __LINE__, __FILE__, $sql);
		$user_voted = ( $row = $db->sql_fetchrow($result) ) ? TRUE : 0;
		if ( isset($HTTP_GET_VARS['vote']) || isset($HTTP_POST_VARS['vote']) )
			$view_result = ( ( ( isset($HTTP_GET_VARS['vote']) ) ? $HTTP_GET_VARS['vote'] : $HTTP_POST_VARS['vote'] ) == 'viewresult' ) ? TRUE : 0;
			$view_result = 0;
		$poll_expired = ( $vote_info[0]['vote_length'] ) ? ( ( $vote_info[0]['vote_start'] + $vote_info[0]['vote_length'] < time() ) ? TRUE : 0 ) : 0;
		if ( $user_voted || $view_result || $poll_expired || !$is_auth['auth_vote'] || $forum_topic_data['topic_status'] == TOPIC_LOCKED )
				'pollbox' => 'viewtopic_poll_result.tpl')
			$vote_results_sum = 0;
			for($i = 0; $i < $vote_options; $i++)
				$vote_results_sum += $vote_info[$i]['vote_result'];
			$vote_graphic = 0;
			$vote_graphic_max = count($images['voting_graphic']);
				$vote_percent = ( $vote_results_sum > 0 ) ? $vote_info[$i]['vote_result'] / $vote_results_sum : 0;
				$vote_graphic_length = round($vote_percent * $board_config['vote_graphic_length']);
				$vote_graphic_img = $images['voting_graphic'][$vote_graphic];
				$vote_graphic = ($vote_graphic < $vote_graphic_max - 1) ? $vote_graphic + 1 : 0;
					$vote_info[$i]['vote_option_text'] = preg_replace($orig_word, $replacement_word, $vote_info[$i]['vote_option_text']);
				$template->assign_block_vars("poll_option", array(
					'POLL_OPTION_CAPTION' => $vote_info[$i]['vote_option_text'],
					'POLL_OPTION_RESULT' => $vote_info[$i]['vote_result'],
					'POLL_OPTION_PERCENT' => sprintf("%.1d%%", ($vote_percent * 100)),
					'POLL_OPTION_IMG' => $vote_graphic_img,
					'POLL_OPTION_IMG_WIDTH' => $vote_graphic_length)
				'L_TOTAL_VOTES' => $lang['Total_votes'],
				'TOTAL_VOTES' => $vote_results_sum)
				'pollbox' => 'viewtopic_poll_ballot.tpl')
					'POLL_OPTION_ID' => $vote_info[$i]['vote_option_id'],
					'POLL_OPTION_CAPTION' => $vote_info[$i]['vote_option_text'])
				'L_SUBMIT_VOTE' => $lang['Submit_vote'],
				'L_VIEW_RESULTS' => $lang['View_results'],
				'U_VIEW_RESULTS' => append_sid("viewtopic.$phpEx?" . POST_TOPIC_URL . "=$topic_id&postdays=$post_days&postorder=$post_order&vote=viewresult"))
			$s_hidden_fields = '<input type="hidden" name="topic_id" value="' . $topic_id . '" /><input type="hidden" name="mode" value="vote" />';
			$vote_title = preg_replace($orig_word, $replacement_word, $vote_title);
		$s_hidden_fields .= '<input type="hidden" name="sid" value="' . $userdata['session_id'] . '" />';
			'POLL_QUESTION' => $vote_title,
			'S_HIDDEN_FIELDS' => $s_hidden_fields,
			'S_POLL_ACTION' => append_sid("posting.$phpEx?mode=vote&" . POST_TOPIC_URL . "=$topic_id"))
		$template->assign_var_from_handle('POLL_DISPLAY', 'pollbox');
// Update the topic view counter
$sql = "UPDATE " . TOPICS_TABLE . "
	SET topic_views = topic_views + 1
	WHERE topic_id = $topic_id";
if ( !$db->sql_query($sql) )
	message_die(GENERAL_ERROR, "Could not update topic views.", '', __LINE__, __FILE__, $sql);
// Okay, let's do the loop, yeah come on baby let's do the loop
// and it goes like this ...
for($i = 0; $i < $total_posts; $i++)
	$poster_id = $postrow[$i]['user_id'];
	$poster = ( $poster_id == ANONYMOUS ) ? $lang['Guest'] : $postrow[$i]['username'];
	$post_date = create_date($board_config['default_dateformat'], $postrow[$i]['post_time'], $board_config['board_timezone']);
	$poster_posts = ( $postrow[$i]['user_id'] != ANONYMOUS ) ? $lang['Posts'] . ': ' . $postrow[$i]['user_posts'] : '';
	$poster_from = ( $postrow[$i]['user_from'] && $postrow[$i]['user_id'] != ANONYMOUS ) ? $lang['Location'] . ': ' . $postrow[$i]['user_from'] : '';
	$poster_userflags = ( $postrow[$i]['user_flagslang'] && $postrow[$i]['user_id'] != ANONYMOUS ) ? str_replace(array('cn', 'de', 'es', 'gr', 'il', 'it', ','), array('<img src="http://centerian.free.fr/langdawson/images/languages/cn.png" />', '<img src="http://centerian.free.fr/langdawson/images/languages/de.png" />', '<img src="http://centerian.free.fr/langdawson/images/languages/es.png" />', '<img src="http://centerian.free.fr/langdawson/images/languages/gr.png" />', '<img src="http://centerian.free.fr/langdawson/images/languages/il.png" />', '<img src="http://centerian.free.fr/langdawson/images/languages/it.png" />', ''), $postrow[$i]['user_flagslang']) : '';
	$poster_joined = ( $postrow[$i]['user_id'] != ANONYMOUS ) ? $lang['Joined'] . ': ' . create_date($lang['DATE_FORMAT'], $postrow[$i]['user_regdate'], $board_config['board_timezone']) : '';
	$poster_avatar = '';
	if ( $postrow[$i]['user_avatar_type'] && $poster_id != ANONYMOUS && $postrow[$i]['user_allowavatar'] )
		switch( $postrow[$i]['user_avatar_type'] )
			case USER_AVATAR_UPLOAD:
				$poster_avatar = ( $board_config['allow_avatar_upload'] ) ? '<img src="' . $board_config['avatar_path'] . '/' . $postrow[$i]['user_avatar'] . '" alt="" border="0" />' : '';
				break;
			case USER_AVATAR_REMOTE:
				$poster_avatar = ( $board_config['allow_avatar_remote'] ) ? '<img src="' . $postrow[$i]['user_avatar'] . '" alt="" border="0" />' : '';
				break;
			case USER_AVATAR_GALLERY:
				$poster_avatar = ( $board_config['allow_avatar_local'] ) ? '<img src="' . $board_config['avatar_gallery_path'] . '/' . $postrow[$i]['user_avatar'] . '" alt="" border="0" />' : '';
				break;
	// Define the little post icon
	if ( $userdata['session_logged_in'] && $postrow[$i]['post_time'] > $userdata['user_lastvisit'] && $postrow[$i]['post_time'] > $topic_last_read )
		$mini_post_img = $images['icon_minipost_new'];
		$mini_post_alt = $lang['New_post'];
		$mini_post_img = $images['icon_minipost'];
		$mini_post_alt = $lang['Post'];
	$mini_post_url = append_sid("viewtopic.$phpEx?" . POST_POST_URL . '=' . $postrow[$i]['post_id']) . '#' . $postrow[$i]['post_id'];
	// Generate ranks, set them to empty string initially.
	$poster_rank = '';
	$rank_image = '';
	$custom_title = '';
	if ( $postrow[$i]['user_id'] == ANONYMOUS )
	else if ( $postrow[$i]['user_rank'] )
		for($j = 0; $j < count($ranksrow); $j++)
			if ( $postrow[$i]['user_rank'] == $ranksrow[$j]['rank_id'] && $ranksrow[$j]['rank_special'] )
				$poster_rank = $ranksrow[$j]['rank_title'];
				$rank_image = ( $ranksrow[$j]['rank_image'] ) ? '<img src="' . $ranksrow[$j]['rank_image'] . '" alt="' . $poster_rank . '" title="' . $poster_rank . '" border="0" /><br />' : '';
			if ( $postrow[$i]['user_posts'] >= $ranksrow[$j]['rank_min'] && !$ranksrow[$j]['rank_special'] )
if ( !empty($postrow[$i]['user_custom_title']) )
		switch( $board_config['custom_title_mode'] )
			case CUSTOM_TITLE_MODE_INDEPENDENT:
				$custom_title = $postrow[$i]['user_custom_title'] . '<br />';
				break;
			case CUSTOM_TITLE_MODE_REPLACE_RANK:
				$poster_rank = $postrow[$i]['user_custom_title'];
				break;
			case CUSTOM_TITLE_MODE_REPLACE_BOTH:
				$rank_image = '';
				break;
			default:
				break;
	// Handle anon users posting with usernames
	if ( $poster_id == ANONYMOUS && $postrow[$i]['post_username'] != '' )
		$poster = $postrow[$i]['post_username'];
		$poster_rank = $lang['Guest'];
	$temp_url = '';
	if ( $poster_id != ANONYMOUS )
		$temp_url = append_sid("profile.$phpEx?mode=viewprofile&" . POST_USERS_URL . "=$poster_id");
		$profile_img = '<a href="' . $temp_url . '"><img src="' . $images['icon_profile'] . '" alt="' . $lang['Read_profile'] . '" title="' . $lang['Read_profile'] . '" border="0" /></a>';
		$profile = '<a href="' . $temp_url . '">' . $lang['Read_profile'] . '</a>';
		$temp_url = append_sid("privmsg.$phpEx?mode=post&" . POST_USERS_URL . "=$poster_id");
		$pm_img = '<a href="' . $temp_url . '"><img src="' . $images['icon_pm'] . '" alt="' . $lang['Send_private_message'] . '" title="' . $lang['Send_private_message'] . '" border="0" /></a>';
		$pm = '<a href="' . $temp_url . '">' . $lang['Send_private_message'] . '</a>';
		if ( !empty($postrow[$i]['user_viewemail']) || $is_auth['auth_mod'] )
			$email_uri = ( $board_config['board_email_form'] ) ? append_sid("profile.$phpEx?mode=email&" . POST_USERS_URL .'=' . $poster_id) : 'mailto:' . $postrow[$i]['user_email'];
			$email_img = '<a href="' . $email_uri . '"><img src="' . $images['icon_email'] . '" alt="' . $lang['Send_email'] . '" title="' . $lang['Send_email'] . '" border="0" /></a>';
			$email = '<a href="' . $email_uri . '">' . $lang['Send_email'] . '</a>';
			$email_img = '';
			$email = '';
		$www_img = ( $postrow[$i]['user_website'] ) ? '<a href="' . $postrow[$i]['user_website'] . '" target="_userwww"><img src="' . $images['icon_www'] . '" alt="' . $lang['Visit_website'] . '" title="' . $lang['Visit_website'] . '" border="0" /></a>' : '';
		$www = ( $postrow[$i]['user_website'] ) ? '<a href="' . $postrow[$i]['user_website'] . '" target="_userwww">' . $lang['Visit_website'] . '</a>' : '';
		if ( !empty($postrow[$i]['user_icq']) )
			$icq_status_img = '<a href="http://wwp.icq.com/' . $postrow[$i]['user_icq'] . '#pager"><img src="http://web.icq.com/whitepages/online?icq=' . $postrow[$i]['user_icq'] . '&img=5" width="18" height="18" border="0" /></a>';
			$icq_img = '<a href="http://wwp.icq.com/scripts/search.dll?to=' . $postrow[$i]['user_icq'] . '"><img src="' . $images['icon_icq'] . '" alt="' . $lang['ICQ'] . '" title="' . $lang['ICQ'] . '" border="0" /></a>';
			$icq =  '<a href="http://wwp.icq.com/scripts/search.dll?to=' . $postrow[$i]['user_icq'] . '">' . $lang['ICQ'] . '</a>';
			$icq_status_img = '';
			$icq_img = '';
			$icq = '';
		$aim_img = ( $postrow[$i]['user_aim'] ) ? '<a href="aim:goim?screenname=' . $postrow[$i]['user_aim'] . '&message=Hello+Are+you+there?"><img src="' . $images['icon_aim'] . '" alt="' . $lang['AIM'] . '" title="' . $lang['AIM'] . '" border="0" /></a>' : '';
		$aim = ( $postrow[$i]['user_aim'] ) ? '<a href="aim:goim?screenname=' . $postrow[$i]['user_aim'] . '&message=Hello+Are+you+there?">' . $lang['AIM'] . '</a>' : '';
		$msn_img = ( $postrow[$i]['user_msnm'] ) ? '<a href="' . $temp_url . '"><img src="' . $images['icon_msnm'] . '" alt="' . $lang['MSNM'] . '" title="' . $lang['MSNM'] . '" border="0" /></a>' : '';
		$msn = ( $postrow[$i]['user_msnm'] ) ? '<a href="' . $temp_url . '">' . $lang['MSNM'] . '</a>' : '';
		$yim_img = ( $postrow[$i]['user_yim'] ) ? '<a href="http://edit.yahoo.com/config/send_webmesg?.target=' . $postrow[$i]['user_yim'] . '&.src=pg"><img src="' . $images['icon_yim'] . '" alt="' . $lang['YIM'] . '" title="' . $lang['YIM'] . '" border="0" /></a>' : '';
		$yim = ( $postrow[$i]['user_yim'] ) ? '<a href="http://edit.yahoo.com/config/send_webmesg?.target=' . $postrow[$i]['user_yim'] . '&.src=pg">' . $lang['YIM'] . '</a>' : '';
		$profile_img = '';
		$profile = '';
		$pm_img = '';
		$pm = '';
		$email_img = '';
		$email = '';
		$www_img = '';
		$www = '';
		$icq_img = '';
		$icq = '';
		$aim_img = '';
		$aim = '';
		$msn_img = '';
		$msn = '';
		$yim_img = '';
		$yim = '';
	$temp_url = append_sid("posting.$phpEx?mode=quote&" . POST_POST_URL . "=" . $postrow[$i]['post_id']);
	$quote_img = '<a href="' . $temp_url . '"><img src="' . $images['icon_quote'] . '" alt="' . $lang['Reply_with_quote'] . '" title="' . $lang['Reply_with_quote'] . '" border="0" /></a>';
	$quote = '<a href="' . $temp_url . '">' . $lang['Reply_with_quote'] . '</a>';
	$temp_url = append_sid("search.$phpEx?search_author=" . urlencode($postrow[$i]['username']) . "&showresults=posts");
	$search_img = '<a href="' . $temp_url . '"><img src="' . $images['icon_search'] . '" alt="' . sprintf($lang['Search_user_posts'], $postrow[$i]['username']) . '" title="' . sprintf($lang['Search_user_posts'], $postrow[$i]['username']) . '" border="0" /></a>';
	$search = '<a href="' . $temp_url . '">' . sprintf($lang['Search_user_posts'], $postrow[$i]['username']) . '</a>';
	if ( ( $userdata['user_id'] == $poster_id && $is_auth['auth_edit'] ) || $is_auth['auth_mod'] )
		$temp_url = append_sid("posting.$phpEx?mode=editpost&" . POST_POST_URL . "=" . $postrow[$i]['post_id']);
		$edit_img = '<a href="' . $temp_url . '"><img src="' . $images['icon_edit'] . '" alt="' . $lang['Edit_delete_post'] . '" title="' . $lang['Edit_delete_post'] . '" border="0" /></a>';
		$edit = '<a href="' . $temp_url . '">' . $lang['Edit_delete_post'] . '</a>';
		$edit_img = '';
		$edit = '';
		$temp_url = "modcp.$phpEx?mode=ip&" . POST_POST_URL . "=" . $postrow[$i]['post_id'] . "&" . POST_TOPIC_URL . "=" . $topic_id . "&sid=" . $userdata['session_id'];
		$ip_img = '<a href="' . $temp_url . '"><img src="' . $images['icon_ip'] . '" alt="' . $lang['View_IP'] . '" title="' . $lang['View_IP'] . '" border="0" /></a>';
		$ip = '<a href="' . $temp_url . '">' . $lang['View_IP'] . '</a>';
		$temp_url = "posting.$phpEx?mode=delete&" . POST_POST_URL . "=" . $postrow[$i]['post_id'] . "&sid=" . $userdata['session_id'];
		$delpost_img = '<a href="' . $temp_url . '"><img src="' . $images['icon_delpost'] . '" alt="' . $lang['Delete_post'] . '" title="' . $lang['Delete_post'] . '" border="0" /></a>';
		$delpost = '<a href="' . $temp_url . '">' . $lang['Delete_post'] . '</a>';
		$ip_img = '';
		$ip = '';
		if ( $userdata['user_id'] == $poster_id && $is_auth['auth_delete'] && $forum_topic_data['topic_last_post_id'] == $postrow[$i]['post_id'] )
			$delpost_img = '';
			$delpost = '';
	$post_subject = ( $postrow[$i]['post_subject'] != '' ) ? $postrow[$i]['post_subject'] : '';
	$message = $postrow[$i]['post_text'];
	$bbcode_uid = $postrow[$i]['bbcode_uid'];
	$user_sig = ( $postrow[$i]['enable_sig'] && $postrow[$i]['user_sig'] != '' && $board_config['allow_sig'] ) ? $postrow[$i]['user_sig'] : '';
	$user_sig_bbcode_uid = $postrow[$i]['user_sig_bbcode_uid'];
	// Note! The order used for parsing the message _is_ important, moving things around could break any
	// output
	// If the board has HTML off but the post has HTML
	// on then we process it, else leave it alone
	if ( !$board_config['allow_html'] || !$userdata['user_allowhtml'])
		if ( $user_sig != '' )
			$user_sig = preg_replace('#(<)([\/]?.*?)(>)#is', "<\\2>", $user_sig);
		if ( $postrow[$i]['enable_html'] )
			$message = preg_replace('#(<)([\/]?.*?)(>)#is', "<\\2>", $message);
	// Parse message and/or sig for BBCode if reqd
	if ($user_sig != '' && $user_sig_bbcode_uid != '')
		$user_sig = ($board_config['allow_bbcode']) ? bbencode_second_pass($user_sig, $user_sig_bbcode_uid) : preg_replace("/\:$user_sig_bbcode_uid/si", '', $user_sig);
	if ($bbcode_uid != '')
		$message = ($board_config['allow_bbcode']) ? bbencode_second_pass($message, $bbcode_uid) : preg_replace("/\:$bbcode_uid/si", '', $message);
		$user_sig = make_clickable($user_sig);
	$message = make_clickable($message);
	// Parse smilies
	if ( $board_config['allow_smilies'] )
		if ( $postrow[$i]['user_allowsmile'] && $user_sig != '' )
			$user_sig = smilies_pass($user_sig);
		if ( $postrow[$i]['enable_smilies'] )
			$message = smilies_pass($message);
	// Highlight active words (primarily for search)
	if ($highlight_match)
		// This has been back-ported from 3.0 CVS
		$message = preg_replace('#(?!<.*)(?<!\w)(' . $highlight_match . ')(?!\w|[^<>]*>)#i', '<b style="color:#'.$theme['fontcolor3'].'">\1</b>', $message);
	// Replace naughty words
	if (count($orig_word))
		$post_subject = preg_replace($orig_word, $replacement_word, $post_subject);
		if ($user_sig != '')
			$user_sig = str_replace('\"', '"', substr(@preg_replace('#(\>(((?>([^><]+|(?R)))*)\<))#se', "@preg_replace(\$orig_word, \$replacement_word, '\\0')", '>' . $user_sig . '<'), 1, -1));
		$message = str_replace('\"', '"', substr(@preg_replace('#(\>(((?>([^><]+|(?R)))*)\<))#se', "@preg_replace(\$orig_word, \$replacement_word, '\\0')", '>' . $message . '<'), 1, -1));
	// Replace newlines (we use this rather than nl2br because
	// till recently it wasn't XHTML compliant)
		$user_sig = '<br />_________________<br />' . str_replace("\n", "\n<br />\n", $user_sig);
	$message = str_replace("\n", "\n<br />\n", $message);
	// Editing information
	if ( $postrow[$i]['post_edit_count'] )
		$l_edit_time_total = ( $postrow[$i]['post_edit_count'] == 1 ) ? $lang['Edited_time_total'] : $lang['Edited_times_total'];
		$l_edited_by = '<br /><br />' . sprintf($l_edit_time_total, $poster, create_date($board_config['default_dateformat'], $postrow[$i]['post_edit_time'], $board_config['board_timezone']), $postrow[$i]['post_edit_count']);
		$l_edited_by = '';
	// Again this will be handled by the templating
	// code at some point
	$row_color = ( !($i % 2) ) ? $theme['td_color1'] : $theme['td_color2'];
	$row_class = ( !($i % 2) ) ? $theme['td_class1'] : $theme['td_class2'];
	$template->assign_block_vars('postrow', array(
		'ROW_COLOR' => '#' . $row_color,
		'ROW_CLASS' => $row_class,
		'POSTER_NAME' => $poster,
		'CUSTOM_TITLE' => $custom_title,
		'POSTER_RANK' => $poster_rank,
		'RANK_IMAGE' => $rank_image,
		'POSTER_JOINED' => $poster_joined,
		'POSTER_POSTS' => $poster_posts,
		'POSTER_FROM' => $poster_from,
		'POSTER_USERFLAGS' => $poster_userflags,
		'POSTER_AVATAR' => $poster_avatar,
		'POST_DATE' => $post_date,
		'POST_SUBJECT' => $post_subject,
		'MESSAGE' => $message,
		'SIGNATURE' => $user_sig,
		'EDITED_MESSAGE' => $l_edited_by,
		'MINI_POST_IMG' => $mini_post_img,
		'PROFILE_IMG' => $profile_img,
		'PROFILE' => $profile,
		'SEARCH_IMG' => $search_img,
		'SEARCH' => $search,
		'PM_IMG' => $pm_img,
		'PM' => $pm,
		'EMAIL_IMG' => $email_img,
		'EMAIL' => $email,
		'WWW_IMG' => $www_img,
		'WWW' => $www,
		'ICQ_STATUS_IMG' => $icq_status_img,
		'ICQ_IMG' => $icq_img,
		'ICQ' => $icq,
		'AIM_IMG' => $aim_img,
		'AIM' => $aim,
		'MSN_IMG' => $msn_img,
		'MSN' => $msn,
		'YIM_IMG' => $yim_img,
		'YIM' => $yim,
		'EDIT_IMG' => $edit_img,
		'EDIT' => $edit,
		'QUOTE_IMG' => $quote_img,
		'QUOTE' => $quote,
		'IP_IMG' => $ip_img,
		'IP' => $ip,
		'DELETE_IMG' => $delpost_img,
		'DELETE' => $delpost,
		'L_MINI_POST_ALT' => $mini_post_alt,
		'U_MINI_POST' => $mini_post_url,
		'U_POST_ID' => $postrow[$i]['post_id'])
$template->pparse('body');
include($phpbb_root_path . 'includes/page_tail.'.$phpEx);
Okay, FIND in viewtopic.php
AFTER ADD
// TESTING
echo 'USER FLAGS: ' . $postrow[$i]['user_flagslang'] . '<br />';
// END TESTING
Now view any topic, and tell me what you see (I imagine you will get a bit of text at the top of the page).
thesims
USER FLAGS: appears right above the thread title, in the top left corner.
Okay, now undo that change (so remove that // TESTING bit I gave above).
In viewtopic.php, FIND
      $limit_posts_time
on that first line, see u.user_custom_title, ?
AFTER THAT, ADD:
user_flagslang,
So that line will look like: SELECT u.username, u.user_id, u.user_posts, u.user_custom_title, u.user_custom_title, u.user_from, etc etc
thesims
We're almost there ! I get /languagImage/de.png" />Image
 *                               viewtopic.php
// or older topic
				$session_id = '';
			if ( $session_id )
					LIMIT 1";
			WHERE
			LIMIT 1";
	WHERE $join_sql
		$order_sql";
// Start auth check
$is_auth = array();
// End auth check
if ($post_id)
		$start = 0;
	$post_days = 0;
$sql = "SELECT u.username, u.user_id, u.user_posts, u.user_custom_title, user_flagslang, u.user_from, u.user_website, u.user_email, u.user_icq, u.user_aim, u.user_yim, u.user_regdate, u.user_msnm, u.user_viewemail, u.user_rank, u.user_sig, u.user_sig_bbcode_uid, u.user_avatar, u.user_avatar_type, u.user_allowavatar, u.user_allowsmile, p.*,  pt.post_text, pt.post_subject, pt.bbcode_uid
		$limit_posts_time
$postrow = array();
	do
		$postrow[] = $row;
$resync = FALSE;
   $resync = TRUE;
      $resync = TRUE;
   $resync = TRUE;
if ($resync)
$sql = "SELECT *
	$ranksrow[] = $row;
	unset($words);
// templating vars
// Load templates
$topic_mod = '';
			$view_result = 0;
			$vote_graphic = 0;
				break;
				break;
				break;
	$poster_rank = '';
	$rank_image = '';
	$custom_title = '';
				break;
				break;
				$rank_image = '';
				break;
			default:
				break;
	$temp_url = '';
			$email_img = '';
			$email = '';
			$icq_img = '';
			$icq = '';
		$profile_img = '';
		$profile = '';
		$pm_img = '';
		$pm = '';
		$email_img = '';
		$email = '';
		$www_img = '';
		$www = '';
		$icq_img = '';
		$icq = '';
		$aim_img = '';
		$aim = '';
		$msn_img = '';
		$msn = '';
		$yim_img = '';
		$yim = '';
		$edit_img = '';
		$edit = '';
		$ip_img = '';
		$ip = '';
			$delpost_img = '';
			$delpost = '';
	// output
	// Parse smilies
		$l_edited_by = '';
		'PM' => $pm,
		'EMAIL' => $email,
		'WWW' => $www,
		'ICQ' => $icq,
		'AIM' => $aim,
		'MSN' => $msn,
		'YIM' => $yim,
		'EDIT' => $edit,
		'QUOTE' => $quote,
		'IP' => $ip,
Okay, find in viewtopic.php:
Replace with:
// user language flags
$expl_flags = explode(',', $postrow[$i]['user_flagslang']);
$poster_userflags = '';
for($q = 0, $q_count = sizeof($expl_flags); $q < $q_count; $q++ )
$poster_userflags .= ($expl_flags[$q] == 'cn') ? '<img src="http://centerian.free.fr/langdawson/images/languages/cn.png" /> ' : '';
$poster_userflags .= ($expl_flags[$q] == 'de') ? '<img src="http://centerian.free.fr/langdawson/images/languages/de.png" /> ' : '';
$poster_userflags .= ($expl_flags[$q] == 'es') ? '<img src="http://centerian.free.fr/langdawson/images/languages/es.png" /> ' : '';
$poster_userflags .= ($expl_flags[$q] == 'gr') ? '<img src="http://centerian.free.fr/langdawson/images/languages/gr.png" /> ' : '';
$poster_userflags .= ($expl_flags[$q] == 'il') ? '<img src="http://centerian.free.fr/langdawson/images/languages/il.png" /> ' : '';
$poster_userflags .= ($expl_flags[$q] == 'it') ? '<img src="http://centerian.free.fr/langdawson/images/languages/iy.png" /> ' : '';
Save and re-upload. How does that work?
EDIT: I had $expl_flags[$i] instead of $expl_flags[$q] ... so if you made this edit, please re-do it.
thesims
Parse error: syntax error, unexpected $end in /mnt/128/sdb/5/1/centerian/langdawson/viewtopic.php on line 1244
Never mind, it does display flags, but only one. I wrote de,it but the German flag is the only one appearing.
That usually means you tried to access the page before the file had finished uploading. It could also mean missing brackets, but the code I put in the post above seems okay.
Did you see the edit I put above? I accidentally used the letter i instead of q, so please re-do that code above. I have edited the post with the correct code.
thesims wrote:Never mind, it does display flags, but only one. I wrote de,it but the German flag is the only one appearing.
I just want to make sure you saw the edit, and that you used:
It must say [$q] after $expl_flags as you can see. (for example: $expl_flags[$q] == 'cn')
thesims
Awesome, works now ! Had to correct a little mistake you made, it was it.png instead of iy.png :P
Okay, that's good. Can you post a screenshot? I'd like to see how it looks now :)
thesims
http://centerian.free.fr/langdawson/images/flagMOD.jpg
Is there any way to reduce the space between the post number and the flags ? it's not that important but I think it would look tidier.
Anyway, thanks a lot for your help, I really, really.... really appreciate. The one other person who offered to help me tried to get the login info to the admin account on the forum and I didn't trust him at all. I am glad you offered to write the MOD for me. We need more people like you on the Internet, lol. :D
Oh and do you want me to mention your name somewhere ?
I can give you the credits for the MOD and add a link if you wish.
That looks great :)
To reduce the gap, in viewtopic_body.tpl FIND:
<br /><br />{postrow.POSTER_USERFLAGS}
REPLACE WITH
When you upgrade to phpBB3, be sure to give this thread a bump and we'll work something out for the new version :)
Out of interest, who is the model in your avatar? =D> =P~
thesims
I have done that already, there's only one <br /> in that screenshot.
Sounds good, I will keep this forum in my bookmarks. :)
And the actor is called C.S. Lee, he had roles in Dexter, Chuck and The Sopranos. Funny guy.
