Hacking Attempt
Swader
So what do I need to do....
I at present have this code...
      if (in_array($var, $not_unset))
         die('Hacking attempt!');
      unset($$var);
Should I replace it with the other one.??
Swader
sputum wrote:The problem is this change in the last phpbb update in the common.php:
#-----[ FIND ]---------------------------------------------
      if (!in_array($var, $not_unset))
         unset($$var);
#-----[ REPLACE WITH ]---------------------------------------------
      unset($$var);
Thnx... I reverted it and its working now.
Guyz who have updated to the latest 2.0..21 version do this....
      unset($$var);
         unset($$var);
sputum
thats a workaround, but i guess its kind of a security problem...
i guess the quiz mod has to be modieifed...
btw: majorflame bookmakers mod has the same Problem!
Ah, thank you for finding that. I will investigate it and see what is happening.
fighteur8
have you find a solution ?
except the code to change in common.php wich is a security issue...
:wink:
fighteur8 wrote:have you find a solution ?
:wink:
Sort of. It is quite complicated, and I imagine will require a fair few changes.
MetaneT
:wink:
firstly hi all,
thanks to the coders of this cool mod :D
I got the same Hacking Attemp problem before I did the code changes u gave above.
Now it is well working but I wondered if the changes makes any security issue?
sorry for my bad english
Fixed, download 1.3.1 from:
http://www.cmxmods.net/quiz.php
Nano
I'm running phpBB 2.0.21 with Cash Mod.. and upgraded from Quiz mod 1.3.0 to 1.3.3 however I still have the problem "Hacking Attempt" when a user submits their answers to a quiz. I've searched all day today for answers to this persisting issue, and frequently I see that 1.3.1 fixed this, however I cannot find where to download 1.3.1, only 1.3.3. Are there instructions in 1.3.1 that are not in 1.3.3 that will help me fix this? As in SQL changes or anything? The included quiz_install and quiz_updater seem to make no changes in SQL tables updating 1.3.0>1.3.3. If the changes are in included files I've uploaded them all... if the changes are in Files to Edit section of instructions I've done those too.. but the problem persists. Any ideas? Everything else works perfectly only the Hacking Attempt when user submits answers /boggle.
v1.3.1: here
v1.3.2: here
and of course, 1.3.3 is available at cmxmods.net :)
Thanks for registering! :)
Nano
Ahh thanks for the links and quick reply :) I'll try em out later on this afternoon.
You're welcome :)
Welcome to the forum, feel free to check out our OT Forum :)
