I at present have this code...
if (in_array($var, $not_unset))
die('Hacking attempt!');
unset($$var);Moderator: CricketMX Forum Moderators
unset($$var);Thnx... I reverted it and its working now.sputum wrote:The problem is this change in the last phpbb update in the common.php:
# #-----[ FIND ]--------------------------------------------- # if (!in_array($var, $not_unset)) { unset($$var); } # #-----[ REPLACE WITH ]--------------------------------------------- # if (in_array($var, $not_unset)) { die('Hacking attempt!'); } unset($$var);
unset($$var);
unset($$var);
Sort of. It is quite complicated, and I imagine will require a fair few changes.fighteur8 wrote:have you find a solution ?
except the code to change in common.php wich is a security issue...
firstly hi all,fighteur8 wrote:have you find a solution ?
