Page 10 of 21
Posted: Tue Mar 22, 2005 3:03 pm
by TheHawks
Lunatic wrote:When I ban a user, where is the list of bans stored? It seems that the ban is only in effect for as long as the server is running, surely not! When hosting with WinMx it gets stored in the config file.
Lunatic When you ban a user and want to save it just add it to your ChatStartUp
#admincmd /banip xxx.xxx.xxx.xx so now when you startup your room it adds the bans
And about
Ouka adding more stuff like + next to nick i Guess? that can be Done or having more than Two user level that would be great...
Posted: Tue Mar 22, 2005 10:09 pm
by JASON
TheHawks wrote:and about not connecting the Only One that i had problems connecting with was RoboMX, DraconisMX, Afterthought .Rabbit and Nushi had no problems connecting Not sure why they dont get In the rooms. I get This When I try to connect <Admin> Illegal Client Blocked:
Turn off the cracker block
#admincmd crackerblockoff
And yeah there is a problem I'm told with the newest release, although running it as a host I found none of these problems at all and have been able to join using my LAN and loopback addresses with the majority of winmx compatible clients, mainly all the above mentioned.
Can find both versions new and an older release that Im currently using by following
link
Logging an Ouka hosted room
Posted: Tue Mar 22, 2005 10:27 pm
by Lunatic_UK1958
One other thing: Is it possible to log an ouka hosted room from within ouka and without having to use a 'bot'?
Re: Logging an Ouka hosted room
Posted: Tue Mar 22, 2005 10:34 pm
by JASON
Lunatic_UK1958 wrote:One other thing: Is it possible to log an ouka hosted room from within ouka and without having to use a 'bot'?
/login CoHost Pass Code
#usercmd inputpasscode CoHost Pass Code
/login Admin Pass Code
#usercmd inputpasscode Admin Pass Code
You will see these appear in your channel
22:29:39 <Admin> Passcode Accepted: JASON³666_13953 [CoHost]
22:30:06 <Admin> Passcode Accepted: JASON³666_13953 [Admin]
Admin Pass Code & CoHost Pass Code are actually the default settings for logins so be sure to change these by clicking onto the settings tab and were it says Admin Code and CoHost Code enter your own personal passwords here for both levels
PS. OK!. I Read this post again, did you mean?
Login? or simply log chat. . . think I got it right by your post saying "logging into" if I read it wrong to log chat from winmx 3.5x type /log <filename> and your logs will save to x:program\ files\winmx.
Hope that helps you or atleast clears things up
Posted: Wed Mar 23, 2005 1:09 pm
by Lunatic_UK1958
Not quite what I meant. I know I can log a chat in WinMx & also by using Metis, but can I do it within Ouka itself?
Posted: Wed Mar 23, 2005 1:25 pm
by JASON
/me slaps himself
No, sorry
Ouka's chatserver doesn't have an internal loggin function. .
hi guys
Posted: Thu Mar 24, 2005 5:20 am
by ELEphantman
i finally registered so i may join this forum
ATM im wondering about the buffer overflow i get from shareguard (but its only once in a while) i have edited my search with colors & newlines to make it look good, & my results i brought down to 4(wich is not alot)
plus i got this buddy of mine that cant get in my room for some reason & dont know why? i keep gettin name blocked but hes not banned or nothing lol
3. whats armblock for?
Posted: Thu Mar 24, 2005 6:11 am
by Protoman X
ELEphantman wrote:ATM im wondering about the buffer overflow i get from shareguard
With all the formatting shareguard is trying to send more characters in one post than WinMX will allow.
ELEphantman wrote:plus i got this buddy of mine that cant get in my room for some reason & dont know why? i keep gettin name blocked but hes not banned or nothing lol
check your RCMSConfig.txt to make sure there's nothing in the trader block list that this person has in their name. You can also disable trader block with #admincmd traderblockoff
ELEphantman wrote:3. whats armblock for?
to quote myself from
this thread...
I wrote:MXArms is a very old and long defunct Japanese channel attacking program that could spam channel by joining and exiting a few hundred times. It also used Nushi's MXhook.dll to copy the channel list from WinMX so MXArms could be used to spam the entire list. It was made by the "chatroom destruction commitee" and the default name that was used for the spamming was an RTF crash code. It's pretty much useless now since it hasn't been updated to connect to 3.5x rooms.
Posted: Tue Mar 29, 2005 2:10 pm
by me here
Also a good source all in one page for Ouka is the tutorial we have on it at....
http://forums.cricketmx.com/viewtopic.php?t=1709
That topic has from basic information to the commands and what they do on it for anyone interested..
FYI.. I talked with Ouka bout my WPN list problem so for now I just have to manually reset my primaries each day but unticking the "Room is Visible" setting..
hi
Posted: Tue Mar 29, 2005 5:11 pm
by ELEphantman
i had trouble with listing to , so i just set ports in mcs server & opened tht now my ouka room is full of peeps
Posted: Mon Apr 04, 2005 12:36 am
by quicksilver
Yet again Oukas server production line is rolling along merrily with this latest version (450c 2nd April)
This is his latest release , but its uncertain whether the robomx entry problem has been solved , no doubt we will hear more from the users
Posted: Mon Apr 04, 2005 2:47 am
by TheHawks
It Works every thing is all ok
Posted: Mon Apr 04, 2005 2:55 am
by ELEphantman
thnx QuickSilver That was quick glad to see ouka is workin hard for us cause this server ROCKZ!!!
Posted: Mon Apr 04, 2005 12:27 pm
by Jimmys444
TheHawks wrote:It Works every thing is all ok
Tha same problem with connection of
RoboMX yester day in @
Jason room and Jason goes in older version
15:19:53] Info: Room is powered by Ouka Chat Server 4.50b.20050227-0730
Posted: Mon Apr 04, 2005 12:52 pm
by TheHawks
I ForGot That I Was Using RoBoMx 2.00Pre
