UQM 2.0 - Predictions Extensions
subvertbeats
- Know-It-All
Not as yet, didnt want to try and confuse different issues, and at the moment my hosts phpMyAdmin interface seems to be down
Alright. Here is the new file, this has the statistics SQL query in it (so you should get the stats visible on the stats page now).
// subvertbeats_quiz.php
$phpbb_root_path = (defined('PHPBB_ROOT_PATH')) ? PHPBB_ROOT_PATH : './';
include($phpbb_root_path . 'includes/functions_quiz.' . $phpEx);
include($phpbb_root_path . 'includes/quiz_stats_class.' . $phpEx);
// Start session management
$user->session_begin();
$auth->acl($user->data);
if( !$auth->acl_get('a_') )
die('No access');
else
if( $_GET['mode'] == 'deactivate' )
$deactivate_id = (int) $_GET['id'];
$sql = "UPDATE " . QUIZ_TABLE . " SET quiz_deactivate = 1
WHERE quiz_id = $deactivate_id";
$db->sql_query($sql);
die('Quiz id ' . $deactivate_id . ' has been deactivated');
if( $_GET['mode'] == 'activate' )
$activate_id = (int) $_GET['id'];
$sql = "UPDATE " . QUIZ_TABLE . " SET quiz_deactivate = 0
WHERE quiz_id = $activate_id";
die('Quiz id ' . $activate_id . ' has been activated');
if( $_GET['mode'] == 'enter_answers' )
if( $_GET['a'] == 'submit' )
$question_id_hidden = $_POST['questions'];
$question_id_set = explode(',', $question_id_hidden);
$question_id_set_count = sizeof($question_id_set) - 1;
$users = array();
$users_information = array();
$users_names = array();
for($i = 0; $i < $question_id_set_count; $i++ )
$sql = 'SELECT * FROM ' . QUIZ_STATISTICS_TABLE . '
WHERE quiz_question_id = ' . $question_id_set[$i];
$users[$i] = $row['quiz_player'];
$user_sql = 'SELECT username FROM ' . USERS_TABLE . '
WHERE user_id = ' . $row['quiz_player'];
$user_result = $db->sql_query($user_sql);
$user_name_fetch = $db->sql_fetchfield('username');
$db->sql_freeresult($user_result);
$users_names[$row['quiz_player']] = $user_name_fetch;
$is_correct = 0;
$is_incorrect = 0;
if( $row['quiz_answer'] == $_POST['question' . $question_id_set[$i]] )
echo 'User <strong>' . $user_name_fetch . '</strong> answered question <strong>' . $question_id_set[$i] . '</strong> CORRECTLY<br />';
$users_information[$row['quiz_player']]['quiz_correct']++;
$users_information[$row['quiz_player']]['quiz_id'] = $row['quiz_id'];
$users_information[$row['quiz_player']]['info'] = 'Question ' . $question_id_set[$i] . ' correct';
else
echo 'User <strong>' . $user_name_fetch . '</strong> answered question <strong>' . $question_id_set[$i] . '</strong> INCORRECTLY. They entered the answer <strong>' . $row['quiz_answer'] . '</strong>.<br />';
$users_information[$row['quiz_player']]['quiz_incorrect']++;
$users_information[$row['quiz_player']]['info'] = 'Question ' . $question_id_set[$i] . ' incorrect (' . $row['quiz_answer'] . ')';
/* for( $j = 0, $j_count = sizeof($users); $j < $j_count; $j++ )
echo 'Username: ' . $users_names[$users[$j]] . '<br />';
echo '-- Correct: ' . $users_information[$users[$j]]['quiz_correct'] . '<br />';
echo '-- Incorrect: ' . $users_information[$users[$j]]['quiz_incorrect'] . '<br />';
echo '-- Quiz ID: ' . $users_information[$users[$j]]['quiz_id'] . '<br />';
foreach($users_names as $key => $val)
// $key is the user_id, $val is the username
$correct_answers = ($users_information[$key]['quiz_correct']) ? $users_information[$key]['quiz_correct'] : 0;
$incorrect_answers = ($users_information[$key]['quiz_incorrect']) ? $users_information[$key]['quiz_incorrect'] : 0;
$quiz_id_key = $users_information[$key]['quiz_id'];
echo 'Info for ' . $val . ';<br />';
echo '-- Correct: ' . $correct_answers . '<br />';
echo '-- Incorrect: ' . $incorrect_answers . '<br />';
echo '-- Quiz ID: ' . $quiz_id_key . '<br />';
$statistical_overview_setup[] = array(
'quiz_id' => (int) $quiz_id_key,
'quiz_correct' => (int) $correct_answers,
'quiz_incorrect' => (int) $incorrect_answers,
'user_id' => (int) $key,
'quiz_time' => (int) 0,
$db->sql_multi_insert(QUIZ_STATISTICS_OVERVIEW_TABLE, $sql_ary);
echo 'SQL Query entered';
die();
$quiz_id = (int) $_GET['id'];
$sql = 'SELECT * FROM ' . QUIZ_QUESTIONS_TABLE . '
WHERE quiz_related_id = ' . $quiz_id;
echo '<form action="subvertbeats_quiz.php?mode=enter_answers&id=' . $quiz_id . '&a=submit" method="post">';
$question_id_hidden = '';
$question_id_hidden .= $row['quiz_question_id'] . ',';
echo '<strong>Question: ' . $row['quiz_question'] . '</strong><br />';
// echo 'Correct answer: <input type="text" name="question' . $row['quiz_question_id'] . '" />';
echo 'Correct answer:';
$ans = 'SELECT quiz_answer FROM ' . QUIZ_DATA_TABLE . '
WHERE quiz_question_id = ' . $row['quiz_question_id'];
$ans_res = $db->sql_query($ans);
while( $ans_row = $db->sql_fetchrow($ans_res) )
echo '<input type="radio" value="' . $ans_row['quiz_answer'] . '" name="question' . $row['quiz_question_id'] . '" /> ' . $ans_row['quiz_answer'] . ' ';
echo '<br /><br />';
echo '<input type="hidden" value="' . $question_id_hidden . '" name="questions" />';
echo '<input type="submit" value="Submit" name="submit" />';
echo '</form>';
die(); // new
else
echo 'Mode types:<br />
<strong>subvertbeats_quiz.php?mode=deactivate&id=XXX</strong><br />
<strong>subvertbeats_quiz.php?mode=activate&id=XXX</strong><br />
<strong>subvertbeats_quiz.php?mode=enter_answers&id=XXX</strong>';
die();
?>CricketMX.com in 2022: Still the home of bat's, rat's and other farmyard animals!
subvertbeats
- Know-It-All
Looks good.
I was having a hard time working out the stats properly, so I just deleted all the existing quizzes and created a new one.
When I enter it I see no questions. I think I remember seeing this issue in the main UQM thread so going to have a look there now
I think you are looking for this: http://www.phpbb.com/community/viewtopi ... #p11802285subvertbeats wrote:Looks good.
subvertbeats
- Know-It-All
Hmmm yes, thanks....though Ive made thouse changes and still have the same issue....
edit - might well be the value of config_value - just checking now...
Yeah, this is explained at http://www.phpbb.com/community/viewtopi ... #p11813005subvertbeats wrote:Hmmm yes, thanks....though Ive made thouse changes and still have the same issue....
subvertbeats
- Know-It-All
Yep its fixed now....I can play the quizzes....
Ok.....heres whats Ive noticed
- Created quiz
- Entered myself
- Got 2 others to enter
- Deactivated quiz
- Entered answers for quiz
On the Enter answers page, the order of questions was mixed up somehow - The first question in the quiz (out of 3 total questions) appeared second in the list in this page
- Viewed statistics
Statistics are blank apart from it showing that this quiz was viewed 3 times.
- Created quiz
- Entered myself
- Deactivated quiz
- Viewed statistics
Have you regained access to phpMyAdmin?
I'd like to know if phpbb_quiz_statistics_overview is empty or if there is data in it. Thanks.
subvertbeats
- Know-It-All
Hey battye....It looks empty
Argh! It was a typo
FIND
REPLACE WITH
FIND
$db->sql_multi_insert(QUIZ_STATISTICS_OVERVIEW_TABLE, $sql_ary);Code: Select all
$db->sql_multi_insert(QUIZ_STATISTICS_OVERVIEW_TABLE, $statistical_overview_setup);CricketMX.com in 2022: Still the home of bat's, rat's and other farmyard animals!
subvertbeats
- Know-It-All
Hey battye
Good find!
Ok, so, statistics look correct, apart from the Most correct answers table seems to be out of whack....
This time on the answer entry page, the order of Qs was completely reversed:
Q3
Q2
Q1
Good find!
Best results
Competition name Competition player Correct Incorrect Percentage
Heres my test comp subvertbeats 2 1 67%
Heres my test comp Dent 2 1 67%
Most played
Competition name Author Submission date Views
Heres my test comp subvertbeats Fri Jan 22, 2010 2:57 pm 2
subvertbeats 4 2 67%
Q3
Q2
Q1
To fix the question order, find:
REPLACE WITH
If you empty (EMPTY in phpMyAdmin) the phpbb_quiz_statistics_overview table (only that table) and re-run the script... do the statistics appear okay then?
WHERE quiz_question_id = ' . $question_id_set[$i];Code: Select all
WHERE quiz_question_id = ' . $question_id_set[$i] . '
ORDER BY quiz_question_id ASC';If you empty (EMPTY in phpMyAdmin) the phpbb_quiz_statistics_overview table (only that table) and re-run the script... do the statistics appear okay then?
subvertbeats
- Know-It-All
table emptied ans scripe re-ran (assume you menat to re-enter and submit the answers)
As you can see that Most Correct answers table is still incorrect, but different to how it was before (user Dent vs subvertbeats)Competition name Competition player Correct Incorrect Percentage
Most played
Dent 4 2 67%
I think we can put it down to a bug in UQM v2.0.0 beta 3... see, my stats at http://forums.cricketmx.com/quiz.php?mode=stats don't look right for "most correct answers" either. For some reason I appear three times. So there is probably something wrong with the SQL query.
So for this script, that is all that needs doing? Are you satisfied with the output screens or would you prefer it in a different format? (this is fairly easy to do, as long as you don't ask for tables or css or anything
subvertbeats
- Know-It-All
Id like tables, with css
Being serious for a moment, I feel most indebted to you for all of your kind help, THANK YOU!
If we could comment out the parts of the code that shows each users answers for each question (else this screen will have lots of data) that would be good.
In terms of format - the primary requirement is a list of users (ordered - ascending on number of incorrect answers)
eg:
QUIZ ID: 8 QUIZ NAME: XXXXXXXXXXXXXXX
dent (correct: 5, incorrect 0)
subvertbeats (correct 5, incorrect 0)
jodie (correct 4, incorrect 1)
pete (correct 3, incorrect 2)
dave (correct 3, incorrect 2)
donald (correct 2, incorrect 3)
duck (correct 1, incorrect 4)
terriblepicker (correct 0, incorrect 5)
Is that something easily achievable ?
When thats done, I think we can go live!
eg:
