UQM 2.0 - Predictions Extensions
Hmm, damn.
Try this:
// subvertbeats_quiz.php
$phpbb_root_path = (defined('PHPBB_ROOT_PATH')) ? PHPBB_ROOT_PATH : './';
include($phpbb_root_path . 'includes/functions_quiz.' . $phpEx);
include($phpbb_root_path . 'includes/quiz_stats_class.' . $phpEx);
// Start session management
$user->session_begin();
$auth->acl($user->data);
	if( !$auth->acl_get('a_') )
		die('No access');
	else
		if( $_GET['mode'] == 'deactivate' )
			$deactivate_id = (int) $_GET['id'];
			$sql = "UPDATE " . QUIZ_TABLE . " SET quiz_deactivate = 1
					WHERE quiz_id = $deactivate_id";
			$db->sql_query($sql);
			die('Quiz id ' . $deactivate_id . ' has been deactivated');
		if( $_GET['mode'] == 'activate' )
			$activate_id = (int) $_GET['id'];
			$sql = "UPDATE " . QUIZ_TABLE . " SET quiz_deactivate = 0
					WHERE quiz_id = $activate_id";
			die('Quiz id ' . $activate_id . ' has been activated');
		if( $_GET['mode'] == 'enter_answers' )
			if( $_GET['a'] == 'submit' )
				$question_id_hidden = $_POST['questions'];
				$question_id_set = explode(',', $question_id_hidden);
				$question_id_set_count = sizeof($question_id_set) - 1;
				$users = array();
				$users_information = array();
				for($i = 0; $i < $question_id_set_count; $i++ )
					$sql = 'SELECT * FROM ' . QUIZ_STATISTICS_TABLE . '
							WHERE quiz_question_id = ' . $question_id_set[$i];
						$users[$i] = $row['quiz_player'];
						$user_sql = 'SELECT username FROM ' . USERS_TABLE . '
									 WHERE user_id = ' . $row['quiz_player'];
						$user_result = $db->sql_query($user_sql);
						$user_name_fetch = $db->sql_fetchfield('username');
						$db->sql_freeresult($user_result);
						$users[$i]['name'] = $user_name_fetch;
						$is_correct = 0;
						$is_incorrect = 0;
						if( $row['quiz_answer'] == $_POST['question' . $question_id_set[$i]] )
							echo 'User <strong>' . $user_name_fetch . '</strong> answered question <strong>' . $question_id_set[$i] . '</strong> CORRECTLY<br />';
							$users_information[$user_name_fetch][] = 'Question ' . $question_id_set[$i] . ' correct';
						$is_correct++;
						else
							echo 'User <strong>' . $user_name_fetch . '</strong> answered question <strong>' . $question_id_set[$i] . '</strong> INCORRECTLY. They entered the answer <strong>' . $row['quiz_answer'] . '</strong>.<br />';
							$users_information[$user_name_fetch][] = 'Question ' . $question_id_set[$i] . ' incorrect (' . $row['quiz_answer'] . ')';
						$is_incorrect++;
						// stats
						$statistical_overview_setup[] = array(
							'quiz_id'			=> (int) $row['quiz_id'],
  							'quiz_correct'		=> (int) $is_correct,
  							'quiz_incorrect'	=> (int) $is_incorrect,
 							'user_id'			=> (int) $row['quiz_player'],
 							'quiz_time'			=> (int) 0,
				for( $j = 0, $j_count = sizeof($users); $j < $j_count; $j++ )
					echo 'NAME: ' . $users[$j]['name'] . '<br />';
				print_r($users_information);
				// Enter stats
				$db->sql_multi_insert(QUIZ_STATISTICS_OVERVIEW_TABLE, $statistical_overview_setup);
				die();
			$quiz_id = (int) $_GET['id'];
			$sql = 'SELECT * FROM ' . QUIZ_QUESTIONS_TABLE . '
					WHERE quiz_related_id = ' . $quiz_id;
			echo '<form action="subvertbeats_quiz.php?mode=enter_answers&id=' . $quiz_id . '&a=submit" method="post">';
			$question_id_hidden = '';
				$question_id_hidden .= $row['quiz_question_id'] . ',';
				echo '<strong>Question: ' . $row['quiz_question'] . '</strong><br />';
				// echo 'Correct answer: <input type="text" name="question' . $row['quiz_question_id'] . '" />';
				echo 'Correct answer:';
				$ans = 'SELECT quiz_answer FROM ' . QUIZ_DATA_TABLE . '
						WHERE quiz_question_id = ' . $row['quiz_question_id'];
				$ans_res = $db->sql_query($ans);
				while( $ans_row = $db->sql_fetchrow($ans_res) )
					echo '<input type="radio" value="' . $ans_row['quiz_answer'] . '" name="question' . $row['quiz_question_id'] . '" /> ' . $ans_row['quiz_answer'] . '&nbsp;&nbsp;&nbsp;';
				echo '<br /><br />';
			echo '<input type="hidden" value="' . $question_id_hidden . '" name="questions" />';
			echo '<input type="submit" value="Submit" name="submit" />';
			echo '</form>';
			die(); // new
		else
			echo 'Mode types:<br />
				<strong>subvertbeats_quiz.php?mode=deactivate&id=XXX</strong><br />
				<strong>subvertbeats_quiz.php?mode=activate&id=XXX</strong><br />
				<strong>subvertbeats_quiz.php?mode=enter_answers&id=XXX</strong>';
			die();
subvertbeats
Ok, no errors, and the following output (as before):
User subvertbeats answered question 1 INCORRECTLY. They entered the answer Fighter A.
User Lyoto answered question 1 INCORRECTLY. They entered the answer Fighter A.
User Kamara666 answered question 1 CORRECTLY
User Nezerous answered question 1 INCORRECTLY. They entered the answer Fighter A.
User Dent answered question 1 INCORRECTLY. They entered the answer Fighter A.
User Dragonfoxy answered question 1 INCORRECTLY. They entered the answer Fighter A.
User subvertbeats answered question 2 INCORRECTLY. They entered the answer Fighter C.
User Lyoto answered question 2 INCORRECTLY. They entered the answer Draw.
User Kamara666 answered question 2 CORRECTLY
User Nezerous answered question 2 INCORRECTLY. They entered the answer Fighter C.
User Dent answered question 2 CORRECTLY
User Dragonfoxy answered question 2 INCORRECTLY. They entered the answer Fighter C.
User subvertbeats answered question 3 INCORRECTLY. They entered the answer Fighter F.
User Lyoto answered question 3 INCORRECTLY. They entered the answer Fighter F.
User Kamara666 answered question 3 INCORRECTLY. They entered the answer Fighter F.
User Nezerous answered question 3 INCORRECTLY. They entered the answer Fighter E.
User Dent answered question 3 CORRECTLY
User Dragonfoxy answered question 3 INCORRECTLY. They entered the answer Fighter E.
Array ( [subvertbeats] => Array ( [0] => Question 1 incorrect (Fighter A) [1] => Question 1 incorrect (Fighter A) [2] => Question 2 incorrect (Fighter C) [3] => Question 2 incorrect (Fighter C) [4] => Question 3 incorrect (Fighter F) [5] => Question 3 incorrect (Fighter F) ) [Lyoto] => Array ( [0] => Question 1 incorrect (Fighter A) [1] => Question 2 incorrect (Draw) [2] => Question 3 incorrect (Fighter F) ) [Kamara666] => Array ( [0] => Question 1 correct [1] => Question 2 correct [2] => Question 3 incorrect (Fighter F) ) [Nezerous] => Array ( [0] => Question 1 incorrect (Fighter A) [1] => Question 2 incorrect (Fighter C) [2] => Question 3 incorrect (Fighter E) ) [Dent] => Array ( [0] => Question 1 incorrect (Fighter A) [1] => Question 2 correct [2] => Question 3 correct ) [Dragonfoxy] => Array ( [0] => Question 1 incorrect (Fighter A) [1] => Question 2 incorrect (Fighter C) [2] => Question 3 incorrect (Fighter E) ) )
Hmm, it means the database query for statistics worked but I just thought about it. It won't be recording the stats correctly. I think the only way we can do this correctly is to continue down the path of having it display by users (and then running the statistics for each user within each loop).
Essentially, we need to get the Array ( [subvertbeats] => Array ( [... working correctly.
Try this and let me know what happens :)
		die('No access');
	else
				$users = array();
				$users_names = array();
						$users_names[$row['quiz_player']] = $user_name_fetch;
						$is_correct = 0;
						$is_incorrect = 0;
							$users_information[$row['quiz_player']]['quiz_correct']++;
							$users_information[$row['quiz_player']]['quiz_id'] = $row['quiz_id'];
							$users_information[$row['quiz_player']]['info'] = 'Question ' . $question_id_set[$i] . ' correct';
						else
							$users_information[$row['quiz_player']]['quiz_incorrect']++;
							$users_information[$row['quiz_player']]['info'] = 'Question ' . $question_id_set[$i] . ' incorrect (' . $row['quiz_answer'] . ')';
					echo 'Username: ' . $users_names[$users[$j]] . '<br />';
					echo '-- Correct: ' .  $users_information[$users[$j]]['quiz_correct'] . '<br />';
					echo '-- Incorrect: ' .  $users_information[$users[$j]]['quiz_incorrect'] . '<br />';
					echo '-- Quiz ID: ' .  $users_information[$users[$j]]['quiz_id'] . '<br />';
				die();
			echo '</form>';
			die(); // new
		else
			die();
subvertbeats
Hmm ok.....
The most important thing is (on a per quiz basis) being able to see a sorted list of users, with the following information for each user:
Correct Answers
Incorrect answers
And the list should be sorted in ascending order on the number of incorrect answers.
Anything else is not really so important.
Just about to try the new code above
subvertbeats
output:
Username: Dragonfoxy
-- Correct:
-- Incorrect: 3
-- Quiz ID: 1
-- Correct:
-- Incorrect: 3
-- Quiz ID: 1
-- Correct:
-- Incorrect: 3
-- Quiz ID: 1
Array ( [377] => Array ( [quiz_incorrect] => 6 [quiz_id] => 1 [info] => Question 3 incorrect (Fighter F) ) [55] => Array ( [quiz_incorrect] => 3 [quiz_id] => 1 [info] => Question 3 incorrect (Fighter F) ) [88] => Array ( [quiz_correct] => 2 [quiz_id] => 1 [info] => Question 3 incorrect (Fighter F) [quiz_incorrect] => 1 ) [945] => Array ( [quiz_incorrect] => 3 [quiz_id] => 1 [info] => Question 3 incorrect (Fighter E) ) [2] => Array ( [quiz_incorrect] => 1 [quiz_id] => 1 [info] => Question 3 correct [quiz_correct] => 2 ) [967] => Array ( [quiz_incorrect] => 3 [quiz_id] => 1 [info] => Question 3 incorrect (Fighter E) ) )
FIND
BEFORE ADD:
				print_r($users);
				print_r($users_names);
subvertbeats
Output seems to be the same
-- Correct:
-- Incorrect: 3
-- Quiz ID: 1
-- Correct:
-- Incorrect: 3
-- Quiz ID: 1
-- Correct:
-- Incorrect: 3
-- Quiz ID: 1
Array ( [0] => 967 [1] => 967 [2] => 967 ) Array ( [377] => subvertbeats [55] => Lyoto [88] => Kamara666 [945] => Nezerous [2] => Dent [967] => Dragonfoxy ) Array ( [377] => Array ( [quiz_incorrect] => 6 [quiz_id] => 1 [info] => Question 3 incorrect (Fighter F) ) [55] => Array ( [quiz_incorrect] => 3 [quiz_id] => 1 [info] => Question 3 incorrect (Fighter F) ) [88] => Array ( [quiz_correct] => 2 [quiz_id] => 1 [info] => Question 3 incorrect (Fighter F) [quiz_incorrect] => 1 ) [945] => Array ( [quiz_incorrect] => 3 [quiz_id] => 1 [info] => Question 3 incorrect (Fighter E) ) [2] => Array ( [quiz_incorrect] => 1 [quiz_id] => 1 [info] => Question 3 correct [quiz_correct] => 2 ) [967] => Array ( [quiz_incorrect] => 3 [quiz_id] => 1 [info] => Question 3 incorrect (Fighter E) ) )
Not quite, there is a little bit here: Array ( [0] => 967 [1] => 967 [2] => 967 ) Array ( [377] => subvertbeats [55] => Lyoto [88] => Kamara666 [945] => Nezerous [2] => Dent [967] => Dragonfoxy )
That is different, and quite helpful. Sorry this bit is causing some problems, I didn't expect it would take this long.
subvertbeats
Please battye, you really should not be apologizing - Im extremely grateful for you going out of your way to help.
Try this:
		die('No access');
	else
				$users = array();
						$is_correct = 0;
						$is_incorrect = 0;
						else
				/* for( $j = 0, $j_count = sizeof($users); $j < $j_count; $j++ )
				foreach($users_names as $key => $val)
					// $key is the user_id, $val is the username
					echo 'Info for ' . $val . ';<br />';
					echo '-- Correct: ' .  $users_information[$key]['quiz_correct'] . '<br />';
					echo '-- Incorrect: ' .  $users_information[$key]['quiz_incorrect'] . '<br />';
					echo '-- Quiz ID: ' .  $users_information[$key]['quiz_id'] . '<br />';
				die();
			echo '</form>';
			die(); // new
		else
			die();
subvertbeats
Getting there!
after the initial output we get:
Info for subvertbeats;
-- Correct:
-- Incorrect: 6
-- Quiz ID: 1
Info for Lyoto;
-- Correct:
-- Incorrect: 3
-- Quiz ID: 1
Info for Kamara666;
-- Correct: 2
-- Incorrect: 1
-- Quiz ID: 1
Info for Nezerous;
-- Correct:
-- Incorrect: 3
-- Quiz ID: 1
Info for Dent;
-- Correct: 2
-- Incorrect: 1
-- Quiz ID: 1
Info for Dragonfoxy;
-- Correct:
-- Incorrect: 3
-- Quiz ID: 1
Okay, this should fix the problem of some users having a blank field for "correct". It should be 0.
Is the "Info for" areas matching the initial output? ie. the number of correct/incorrect answers is right?
		die('No access');
	else
				$users = array();
						$is_correct = 0;
						$is_incorrect = 0;
						else
					$correct_answers = ($users_information[$key]['quiz_correct']) ? $users_information[$key]['quiz_correct'] : 0;
					$incorrect_answers = ($users_information[$key]['quiz_incorrect']) ? $users_information[$key]['quiz_incorrect'] : 0;
					$quiz_id_key = $users_information[$key]['quiz_id'];
					echo '-- Correct: ' .  $correct_answers . '<br />';
					echo '-- Incorrect: ' .  $incorrect_answers . '<br />';
					echo '-- Quiz ID: ' . $quiz_id_key . '<br />';
				die();
			echo '</form>';
			die(); // new
		else
			die();
subvertbeats
New output
-- Correct: 0
-- Incorrect: 6
-- Quiz ID: 1
Info for Lyoto;
-- Correct: 0
-- Incorrect: 3
-- Quiz ID: 1
Info for Kamara666;
-- Correct: 2
-- Incorrect: 1
-- Quiz ID: 1
Info for Nezerous;
-- Correct: 0
-- Incorrect: 3
-- Quiz ID: 1
Info for Dent;
-- Correct: 2
-- Incorrect: 1
-- Quiz ID: 1
-- Correct: 0
-- Incorrect: 3
-- Quiz ID: 1
And yes, the data here matches the actual submitted data x-ref'd with the correct answers.
Of course it looks a little off due to my double entires in this particular quiz
Were you able to replicate that double-entry problem here at CMX?
