UQM 2.0 - Predictions Extensions
subvertbeats
Hey battye :)
Before the headers warning, this is output:
12
4
Which looks correct to me.
12 questions in the set, first question in the set with id 4
Okay, now find:
				for($i = 0; $i < $question_id_set_count; $i++ )
AFTER ADD:
echo 'I: ' . $i . '<br />';
echo 'RES: ' . $question_id_set[$i] . '<br /><br />';
Let me know the result
subvertbeats
12
4I: 0
RES: 4
I: 1
RES: 5
I: 2
RES: 6
I: 3
RES: 7
I: 4
RES: 8
I: 5
RES: 9
I: 6
RES: 10
I: 7
RES: 11
I: 8
RES: 12
I: 9
RES: 13
I: 10
RES: 14
I: 11
RES:
As per that extra comma, seems like the code is trying to find a 12th question that doesnt exist with a NULL index?
Yep, I think we've found the culprit. Okay, you can remove all of those testing lines now and replace:
				$question_id_set_count = sizeof($question_id_set);
With
				$question_id_set_count = sizeof($question_id_set) - 1;
subvertbeats
Ok, now we're moving!
I made a simple 3 question quiz yesterday for a boxing event, and had a few forum mods do some dummy answers for testing.
So now we get:
User 377 answered question 1 CORRECTLYUser 377 answered question 1 CORRECTLYUser 55 answered question 1 CORRECTLYUser 88 answered question 1 INCORRECTLY. They entered the answer Fighter B.User 945 answered question 1 CORRECTLYUser 2 answered question 1 CORRECTLYUser 967 answered question 1 CORRECTLYUser 377 answered question 2 INCORRECTLY. They entered the answer Fighter C.User 377 answered question 2 INCORRECTLY. They entered the answer Fighter C.User 55 answered question 2 INCORRECTLY. They entered the answer Draw.User 88 answered question 2 CORRECTLYUser 945 answered question 2 INCORRECTLY. They entered the answer Fighter C.User 2 answered question 2 CORRECTLYUser 967 answered question 2 INCORRECTLY. They entered the answer Fighter C.User 377 answered question 3 INCORRECTLY. They entered the answer Fighter F.User 377 answered question 3 INCORRECTLY. They entered the answer Fighter F.User 55 answered question 3 INCORRECTLY. They entered the answer Fighter F.User 88 answered question 3 INCORRECTLY. They entered the answer Fighter F.User 945 answered question 3 INCORRECTLY. They entered the answer Fighter E.User 2 answered question 3 CORRECTLYUser 967 answered question 3 INCORRECTLY. They entered the answer Fighter E.
Okay, next up is the multiple choice boxes.
FIND:
echo 'Correct answer: <input type="text" name="question' . $row['quiz_question_id'] . '" />';
REPLACE WITH:
				echo 'Correct answer:';
				$ans = 'SELECT quiz_answer FROM ' . QUIZ_DATA_TABLE . '
						WHERE quiz_question_id = ' . $row['quiz_question_id'];
				$ans_res = $db->sql_query($ans);
				while( $ans_row = $db->sql_fetchrow($ans_res) )
					echo '<input type="radio" value="' . $ans_row['quiz_answer'] . '" name="question' . $row['quiz_question_id'] . '" /> ' . $ans_row['quiz_answer'] . '&nbsp;&nbsp;&nbsp;';
I wouldn't mind you trying this file though, as I want to make sure you've got exactly what I've got.
// subvertbeats_quiz.php
define('IN_PHPBB', true);
$phpbb_root_path = (defined('PHPBB_ROOT_PATH')) ? PHPBB_ROOT_PATH : './';
$phpEx = substr(strrchr(__FILE__, '.'), 1);
include($phpbb_root_path . 'common.' . $phpEx);
include($phpbb_root_path . 'includes/functions_quiz.' . $phpEx);
include($phpbb_root_path . 'includes/quiz_stats_class.' . $phpEx);
// Start session management
$user->session_begin();
$auth->acl($user->data);
    if( !$auth->acl_get('a_') )
        die('No access');
        if( $_GET['mode'] == 'deactivate' )
            $deactivate_id = (int) $_GET['id'];
            $sql = "UPDATE " . QUIZ_TABLE . " SET quiz_deactivate = 1
                    WHERE quiz_id = $deactivate_id";
            $db->sql_query($sql);
            die('Quiz id ' . $deactivate_id . ' has been deactivated');
        if( $_GET['mode'] == 'activate' )
            $activate_id = (int) $_GET['id'];
            $sql = "UPDATE " . QUIZ_TABLE . " SET quiz_deactivate = 0
                    WHERE quiz_id = $activate_id";
            die('Quiz id ' . $activate_id . ' has been activated');
        if( $_GET['mode'] == 'enter_answers' )
            if( $_GET['a'] == 'submit' )
                $question_id_hidden = $_POST['questions'];
                $question_id_set = explode(',', $question_id_hidden);
                $users = array();
                $users_information = array();
                    $sql = 'SELECT * FROM ' . QUIZ_STATISTICS_TABLE . '
                            WHERE quiz_question_id = ' . $question_id_set[$i];
                    $result = $db->sql_query($sql);
                    while( $row = $db->sql_fetchrow($result) )
                        $users[$i] = $row['quiz_player'];
                        if( $row['quiz_answer'] == $_POST['question' . $question_id_set[$i]] )
                            echo 'User <strong>' . $row['quiz_player'] . '</strong> answered question <strong>' . $question_id_set[$i] . '</strong> CORRECTLY';
                            $users_information[$row['quiz_player']][] = 'Question ' . $question_id_set[$i] . ' correct';
                            echo 'User <strong>' . $row['quiz_player'] . '</strong> answered question <strong>' . $question_id_set[$i] . '</strong> INCORRECTLY. They entered the answer <strong>' . $row['quiz_answer'] . '</strong>.';
                            $users_information[$row['quiz_player']][] = 'Question ' . $question_id_set[$i] . ' incorrect (' . $row['quiz_answer'] . ')';
                die();
            $quiz_id = (int) $_GET['id'];
            $sql = 'SELECT * FROM ' . QUIZ_QUESTIONS_TABLE . '
                    WHERE quiz_related_id = ' . $quiz_id;
            echo '<form action="subvertbeats_quiz.php?mode=enter_answers&id=' . $quiz_id . '&a=submit" method="post">';
            $question_id_hidden = '';
                $question_id_hidden .= $row['quiz_question_id'] . ',';
                echo '<strong>Question: ' . $row['quiz_question'] . '</strong><br />';
                // echo 'Correct answer: <input type="text" name="question' . $row['quiz_question_id'] . '" />';
                echo '<br /><br />';
            echo '<input type="hidden" value="' . $question_id_hidden . '" name="questions" />';
            echo '<input type="submit" value="Submit" name="submit" />';
            echo '</form>';
            die(); // new
            echo 'Mode types:<br />
                <strong>subvertbeats_quiz.php?mode=deactivate&id=XXX</strong><br />
                <strong>subvertbeats_quiz.php?mode=activate&id=XXX</strong><br />
                <strong>subvertbeats_quiz.php?mode=enter_answers&id=XXX</strong>';
            die();
subvertbeats
Works perfectly. Same result set.
The only diffs shown were where I had modified the name of the file and references throughout the code, but I took your file and used that regardless.
subvertbeats
Next I guess would be to update statistics table?
Okay, great. I'll just address this, as it would look nicer if these are on new lines...
subvertbeats wrote:Ok, now we're moving!
So now we get:
FIND
REPLACE WITH
							echo 'User <strong>' . $row['quiz_player'] . '</strong> answered question <strong>' . $question_id_set[$i] . '</strong> CORRECTLY<br />';
FIND
REPLACE WITH
							echo 'User <strong>' . $row['quiz_player'] . '</strong> answered question <strong>' . $question_id_set[$i] . '</strong> INCORRECTLY. They entered the answer <strong>' . $row['quiz_answer'] . '</strong>.<br />';
Just to confirm, this information about right/wrong answers appears to be correct?
subvertbeats
Yes looks good. Would be nice if we could print forum user name instead of user ID.
User 377 answered question 1 INCORRECTLY. They entered the answer Fighter A.
User 55 answered question 1 INCORRECTLY. They entered the answer Fighter A.
User 88 answered question 1 CORRECTLY
User 945 answered question 1 INCORRECTLY. They entered the answer Fighter A.
User 2 answered question 1 INCORRECTLY. They entered the answer Fighter A.
User 967 answered question 1 INCORRECTLY. They entered the answer Fighter A.
Im user 377 here, and as you can see there are duplicate entries.
I believe this is not an issue with what we're doing her, but instead related to the duplicate statistics issue I reported in the main thread.
Just to confirm Ive never had the flag on to allow multiple submissions.
Regarding the multiple submissions problem you are reporting, can you try and replicate the problem at http://forums.cricketmx.com/quiz.php ? I have switched on "play quiz once" - please continue this discussion in the other thread though :)
Okay, I have included the username instead of the user_id in this code:
There are some SQL queries in loops, which isn't very efficient but for the purposes of what we are doing it's quicker than building temporary arrays, etc, etc.
		die('No access');
				$users = array();
						$user_sql = 'SELECT username FROM ' . USERS_TABLE . '
									 WHERE user_id = ' . $row['quiz_player'];
						$user_result = $db->sql_query($user_sql);
						$user_name_fetch = $db->sql_fetchfield('username');
						$db->sql_freeresult($user_result);
							echo 'User <strong>' . $user_name_fetch . '</strong> answered question <strong>' . $question_id_set[$i] . '</strong> CORRECTLY<br />';
							echo 'User <strong>' . $user_name_fetch . '</strong> answered question <strong>' . $question_id_set[$i] . '</strong> INCORRECTLY. They entered the answer <strong>' . $row['quiz_answer'] . '</strong>.<br />';
				die();
			echo '</form>';
			die(); // new
			die();
subvertbeats
Yep will, do - just wanted to highlight the suspected reason for those duplicate entries instead of you thinking there was a potential issue with the results display code in here.
New code shows usernames - output looks great :)
This is a bit of a test I did for displaying the answers, please let me know the output of this:
		die('No access');
				$users = array();
						$users[$i]['name'] = $user_name_fetch;
				$size_users = sizeof($users);
				for($j = 0; $j < $size_users; $j++ )
					echo '<strong>' . $users[$j]['name'] . '</strong>';
					$size_users_answers = sizeof($users_information[$users[$j]]);
					for($k = 0; $k < $size_users_answers; $k++ )
						echo $users_information[$users[$j]][$k] . '<br />';
				die();
			echo '</form>';
			die(); // new
			die();
subvertbeats
Same outout except the output is followed by:
D
D
D
Okay try this.
FIND:
AFTER ADD
print_r($users_information);
