Thanks everyone for your patience.
Thanks for the offer Lugsciath, I was on vacation but I am back now and I have some good news. I think UQM is ready for a public release. I have finished the ACP now, and I am satisfied that it is in working order. I will send out a testing version to anyone who wants it, but in all likelihood I will release a full beta (I am sure it is ready for Beta, after all it has been in pre-alpha for a long time
) tomorrow or maybe Christmas Day if people want it as a Christmas present
I'm pleased to announce the first public Beta of the Ultimate Quiz MOD v2.0.0
It is available for download at http://www.cmxmods.net/downloads/Ultima ... eta_1b.zip
Be sure to manually run (automatic installer will come soon) the SQL queries first before uploading the files, and to access the ACP module do the following:
Any questions, please feel free to ask
To access the quiz page, go to /quiz.php (I will have an image ready for a header link soon hopefully)IMPORTANT: To install the ACP module go to the phpBB3 ACP -> SYSTEM -> Module Management -> Click "Administration Control Panel" -> select ACP_QUIZ_INDEX_TITLE from the "Add module" list in the bottom right. Follow the instructions and refresh the ACP and the quiz tab should appear at the top.
thx a lot battye for the first release xD
Thank you for waiting so patiently for it!darkonia wrote:thx a lot battye for the first release xD
Merry Christmas!
hello,
I try to add a gain points.
I use the mod simply point system
I create a table and access acp
but I know that this function may depend, but I do not know or place
can you help me please
I did several test, but without result
thank you
// start addon point system
$sql = 'SELECT *
FROM ' . QUIZ_POINT_TABLE . "
WHERE id = '" . $db->sql_escape($id) . "'";
$results = $db->sql_query($sql);
$row = $db->sql_fetchrow($results);
$point = $row['point'];
$sql = 'UPDATE ' . USERS_TABLE . "
SET user_points = user_points + '" . $point . "'
WHERE '" . $user->data['user_points'] . "'";
// end point system I did several test, but without result
thank you
Hi xpmen, implementing cash/points functionality is one of my aims - probably for beta 2 (which will be out pretty soon, probably this week to give an indication).
In the mean time though, something like this:
FIND in quiz.php
AFTER ADD
The number 5 represents the number of points for a correct answer. So if you got 2 correct you would get 10 points, 3 correct = 15 points... etc. But you can just edit the number 5 to any number you want.
When I implement this feature you will be able to edit it from the ACP and choose which currency (ie. user_points, user_dollars, etc) to use, it will be very easy
I haven't tested that code above, but it should work.
FIND in quiz.php
// Delete all temporary/progressive data and update the view count of the quiz
// We'll use the stats array as it looks nicer, and loosely related anyway
$statistical_sql[] = "DELETE FROM " . QUIZ_PROGRESSIVE_TABLE . " WHERE quiz_progress_id = $submit_quiz_progressive_id";
$statistical_sql[] = "UPDATE " . QUIZ_TABLE . " SET quiz_views = quiz_views + 1 WHERE quiz_id = $quiz_id";Code: Select all
$new_points = $number_of_correct_answers * 5; // change number 5 to whatever a correct answer is worth
$statistical_sql[] = "UPDATE " . USERS_TABLE . " SET user_points = user_points + $new_points WHERE user_id = " . $user->data['user_id'];When I implement this feature you will be able to edit it from the ACP and choose which currency (ie. user_points, user_dollars, etc) to use, it will be very easy
a big thank you
its works perfectly
thank you
I made the French language
you want?
its works perfectly
thank you
you want?
Yes, the French language would be fantastic. Thank you
If you want, upload it as a zip attachment in a post here so that other people can download it if they want. Thanks.
I am still investigating why the foreign characters are not working. I did run those particular variables through utf8_normalize_nfc() so I will need to take a closer look at the code. Thanks for telling me
if I can allow myself a suggestion,
it'll be good to have on every page of the quiz link and stat quiz
(I was already added myself)
Hello and thanks for this great mod
I post here what I posted on phpbb.com :
joebart72 wrote:I've also a problem with accents :
And all my tables are in UTF8_BIN...
I think navlinks in the html files would be helpful...
And 3 bugs :
1/ One of my members managed to post a quiz outside a category. So nobody can go into the quiz.
2/ One of my members managed to make a question with 4 answers but she has not selected the good reply. Se was able to submit the quiz.
3/ We are 4 to have been able to play three time the same quiz...
xpmen and joebart, I haven't got an icon yet. As soon as I do I will add the header link
joebart:
Can you ask her what exactly she did in order to not select the correct answer? Was it multiple choice or true false (or even input answer)? Thanks
I am working on the accents
joebart:
Thanks, I tried this myself and I was able to reproduce this. I'm sorry, I'll fix it now.1/ One of my members managed to post a quiz outside a category. So nobody can go into the quiz.
I tried this a couple of times, but no matter what I do I get the error:2/ One of my members managed to make a question with 4 answers but she has not selected the good reply. Se was able to submit the quiz.
You haven't selected one or more radio boxes, meaning you still need to select a multiple choice and/or true/false answer, or you have not yet filled in the quiz name and category.I'll need to take a look at this, but can you check if in the ACP "Allow saved quizzes" is set to "no"? Thanks3/ We are 4 to have been able to play three time the same quiz...
As I said, just need to get an icon first
If you or anyone else knows how to use Photoshop, I just want a 16x14 like this
except with the question mark inside a square instead of a speech bubble
to the problem of accents, it can not come phpmyadmin
but rather quiz.php
I made different test, no result
also with this code
or
I am still looking
for links, I add this in each html page
I had to install the direct link, because I had a conflict with the statistical mod phpbb
but rather quiz.php
also with this code
htmlspecialchars_decode(smilies_pass(censor_text(Code: Select all
utf8_normalize_nfc(request_var(I am still looking
<div class="panel">
<div class="inner"><span class="corners-top"><span></span></span>
<ul class="linklist">
<li><a href="quiz.php">Retour au Quizz</a> • <a href="quiz.php?mode=submit">{L_SUBMIT_QUIZ}</a> • <a href="quiz.php?mode=stats">{L_QUIZ_STATISTICS}</a><!-- IF CAN_ACCESS_CP --> • <a href="{U_CP}">{L_QUIZ_CP_LOWER}</a><!-- ENDIF --></li>
</ul>
<span class="corners-bottom"><span></span></span></div>
</div>
