SQL Error
leagcooks
hi, Please can you help.
Ive installed the Ultimate Quiz Mode, Ive done all the sql updates and added all the files, But when i click on quizzes i get this error....
An Error Occurred
DEBUG MODE
SQL Error : 1054 Unknown column 'quiz_category' in 'where clause'
Line : 151
File : functions_quiz.php
More details here....
http://www.tbppbguideforums.info/bpb/quiz.php
Thanks in advance ;-)
Lea.
Now it says:
An Error Occurred
DEBUG MODE
SQL Error : 1054 Unknown column 'category_permissions' in 'where clause'
Line : 1017
File : quiz.php
Have you been making more alterations, or does the error you posted only appear once you are logged in?
leagcooks
Hi Battye,
Sorry i am logged in when it says that error.
So it must also have the error you show when your not logged in.
Lea.
leagcooks
Nobody help then ???? :( :(
Lea.
Was this a fresh install or were you upgrading from a previous version?
leagcooks
Hi Battye,
This was a fresh install.
lea.
When you say you've done the SQL updates, how did you do them?
leagcooks
The same i do all sql updates on mods, I used a FTP client and uploaded the Install file.
Went off the Install notes to install.
Lea.
Did you get the green messages to show that it was successful?
leagcooks
No Got some red messages aswell.
Lea.
Did you note down which were the red ones (these are the ones that failed)?
leagcooks
No didint sorry, Normally they can be fixed by seeing the error it says when you try and load the page..
Ive never wrote down the red errors, Sorry.
Lea.
Do you have phpMyAdmin? It is a program so you can view what is in your database.
leagcooks
yes i can view everything in the databse battye
Lea.
leagcooks
This is what i get in red ;-)
CREATE TABLE phpbb_quiz ( `quiz_id` int(10) NOT NULL default '0', `quiz_name` varchar(200) NOT NULL default '', `quiz_author` int(10) NOT NULL default '0', `quiz_enabled` int(1) NOT NULL default '0', `quiz_category` int(5) NOT NULL default '0', `quiz_type` varchar(20) NOT NULL default '0', `quiz_plays` int(5) NOT NULL default '0');
CREATE TABLE phpbb_quiz_categories ( `category_id` int(5) NOT NULL default '0', `category_password` VARCHAR( 100 ) NOT NULL default '', `category_name` varchar(140) NOT NULL default '', `category_permissions` int(1) NOT NULL default '0', `category_description` varchar(255) NOT NULL default '');
CREATE TABLE phpbb_quiz_statistics ( `stats_id` int(5) NOT NULL default '', `quiz_id` int(10) NOT NULL default '', `user_id` int(10) NOT NULL default '', `stats_correct` INT(5) NOT NULL default '0', `stats_incorrect` INT(5) NOT NULL default '0', `stats_percentage` INT(3) NOT NULL default '0');
CREATE TABLE phpbb_quiz_multiple_choice_data ( `quiz_id` int(10) NOT NULL default '0', `question_id` int(10) NOT NULL default '0', `quiz_question` text NOT NULL, `quiz_alternates` text NOT NULL, `quiz_answer` text NOT NULL);
CREATE TABLE phpbb_quiz_true_false_data ( `quiz_id` int(10) NOT NULL default '0', `question_id` int(10) NOT NULL default '0', `quiz_question` text NOT NULL, `quiz_answer` text NOT NULL);
CREATE TABLE phpbb_quiz_input_data ( `quiz_id` int(10) NOT NULL default '0', `question_id` int(10) NOT NULL default '0', `quiz_question` text NOT NULL, `quiz_answer` text NOT NULL)
ALTER TABLE phpbb_sessions ADD `session_quiz_categories` VARCHAR( 255 ) NOT NULL;
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_show_answers', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Register_Play', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Post_Count_Play', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Post_Requirement', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Play_Once', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Author_Play', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Min_Max_Questions', '5,10')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Author_Mod', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Banned', '')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Moderators', '')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Stats_Display', '10')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Mod_Submit', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Cash_Currency', 'user_points')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Cash_Incorrect', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Cash_Correct', '1')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_Cash_Tax', '2')
INSERT INTO phpbb_config (config_name, config_value) VALUES ('Quiz_CashMOD_On', '1')
